Old March 10th, 2016, 03:52 PM   #1
Jetfoi
Jetfoi's Avatar
Motorcycle(s): 2013 zx6r and 1995 250r
Rebuilding the bike and then....
So my bikes been apart for over a year. It's a slow rebuild based on money and spending time with kids and family. So I changed the headlight removed the gauge cluster removed the handbrake and clutch lever (they are still off). I replaced the petcock on the tank and rebuilt the carb. I'm more then positive everything was put back together but I wanted to start it today to make sure 1) the new peacock didn't leak like the old and 2) make sure the carb didn't gunk up again.
When I went to start the bike I got nothing. No click or anything however the headlight and turn signals work. The battery is on a tender so it is charged. Would not having the clutch lever on cause this issue or not having the brake level on? Also is there something in the electrical system connected to the gauge cluster that could be causing this?
Am I just rushing to conclusions? Thanks for the help guys and gals
spend all the spare time on two wheels
Jetfoi is offline   Reply With Quote
Old March 10th, 2016, 03:55 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Need to jump together the two wires for the clutch switch.
Goin' fast on slow bikes!
Old March 10th, 2016, 04:10 PM   #3
Jetfoi
Jetfoi's Avatar
Already read that in the wiki page on this site. No luck. I feel I may be in 1st gear and can't put the bike in neutral.
Old March 10th, 2016, 04:29 PM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
rock the bike back and forth a bit. kickstand down? check that safety switch.
My Cafe Racer Build
My intro post
Old March 10th, 2016, 04:33 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Kill switch wires on the right side pod maybe? Those will kill the start too.
Old March 10th, 2016, 05:51 PM   #6
HoneyBadgerRy
HoneyBadgerRy's Avatar
Along with what they said, its worth a shot checking fuses.
Old March 11th, 2016, 05:25 PM   #7
Jetfoi
Jetfoi's Avatar
The fuses are all good but thanks. I'll post in a week just waiting on new levers and then I'll go through everything
Old March 25th, 2016, 07:18 AM   #8
Jetfoi
Jetfoi's Avatar
ended up being the clutch safety switch and I was looping the wrong two wires together. Thanks for all the help!
Rebuilding the bike and new issue... Jetfoi 1986 - 2007 Ninja 250R Tech Talk 2 March 10th, 2016 04:31 PM
what to consider when rebuilding an engine? MrAtom General Motorcycling Discussion 15 April 22nd, 2015 09:50 PM
Rebuilding Questions eulark 1986 - 2007 Ninja 250R Tech Talk 171 September 19th, 2013 05:58 PM
New member rebuilding a '10 in Houston iBang New Members 6 March 30th, 2012 06:15 AM
Rebuilding a motor... saber63 1986 - 2007 Ninja 250R Tech Talk 3 May 16th, 2011 11:42 AM
