Closed Thread
Old August 8th, 2013, 06:48 AM   #1
Redgeneral
Redgeneral's Avatar
Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650
Why you shouldn't leave your Swingarms Spools on
So I figured I would pass on a tidbit of information so no one else learns this lesson the hard way as I have.
I left my swingarm spools on thinking it wouldn't be an issue. I was out for a ride and must've hit a hole or bump big enough to almost bottom out the rear suspension. The right side spool made contact with the bottom of the stock exhaust and broke the welds holding the spool mount. This wouldn't have been an issue, but the weld took some of the swingarm with it.
I'm not sure if this will affect any 250 owners as the exhaust hangs much higher, but I think the 300's exhaust is very similarly placed to this bike. Either way it's always good to know. Learn from my mistakes.
This was on a 2011 ZX-6R.
Redgeneral is offline
Old August 8th, 2013, 06:57 AM   #2
BlueJeepYJ
Lets go ride!
BlueJeepYJ's Avatar
Motorcycle(s): Ninja 650
WOW Thats crazy! Does the ZX-6R owners manual tell you not to leave the swing arm spools in during riding? If not and that was caused during "normal" riding, I would be filing a claim with Kawasaki ASAP! That's some pretty serious damage!
Good Luck!
In the Atlanta/ North Georgia Area? Join the North Georgia Riders! www.northgariders.com
BlueJeepYJ is offline
Old August 8th, 2013, 06:59 AM   #3
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Nemesis is offline
Old August 8th, 2013, 07:00 AM   #4
Bones85
Hopefully this isn't an issue for the 250's. My spools have been on my bike for over a year now
Haven't had any problems yet though.
Bones85 is offline
Old August 8th, 2013, 07:09 AM   #5
This has been an issue on new-gen 250's that have been lowered, but I've never heard of an issue on a non-lowered bike. Is your ZX-6R at stock height?
Alex is offline
Old August 8th, 2013, 07:21 AM   #6
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Wow, that sucks. No problems so far with my 300.
ninjamunky85 is offline
Old August 8th, 2013, 08:07 AM   #7
GHill762
GHill762's Avatar
Motorcycle(s): ZX-3R (ok, ex300)
spool instructions recommend thread-loc.. they are meant to be left in.. like asked above, is your bike lowered? I don't think it's possible for mine to touch, my swingarm would have to come up really high.. the tire would rub the undertail first...
GHill762 is offline
Old August 8th, 2013, 08:16 AM   #8
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Needs a title change to "Why you shouldn't leave your stock exhuast on"
rojoracing53 is offline
Old August 8th, 2013, 10:44 AM   #9
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
I really think it must have been a lowered zx6r or have a very VERY poorly setup suspension.
I did some tests on mine and the 2013 zx6r spools didn't come close to hitting the exhaust. I know the 2013 is different, but I am fairly certain the exhaust/swing arms are identical.
Note: I have aftermarket (proper) exhaust, but I marked on the swing arm were the stock should sit. There was at least inches of clearance.
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline
Old August 8th, 2013, 12:40 PM   #10
Redgeneral
Redgeneral's Avatar
Couldn't agree more.
That being said. This bike is not lowered. The suspension is set to factory settings (I know, i know....I've been meaning to set this up properly) and I'm not a huge guy (weighing in 165lbs).
The owner's manual does not say to take spools off, but then again is never says to put spools on either. Since there's no such thing as 'Kawasaki spools' these are considered an aftermarket part, and therefore 'use at own risk'.
This is not a case of Kawasaki being wrong in any way. So there's no finger pointing. It is a case of warning people to pay attention to even these little things. I had left these spools on the bike never even considering that this could happen.
I'm just hoping to educate, and maybe someone else can avoid making my mistakes.
Old August 8th, 2013, 12:46 PM   #11
Sounds like the biggest mistake was hitting a honkin' HUGE bump. It takes a lot to reach bottom on any bike that isn't suffering from terminally poor setup.
adouglas is offline
Old August 8th, 2013, 12:49 PM   #12
Redgeneral
Redgeneral's Avatar
From now on I will either be only putting in spools to lift the bike up for maintenance/washing etc then taking them out. Or picking up a rear stand that lifts with paddles from the bottom of the swingarm.
Those spools are not there for any kind of crash resistance, they are so precariously welded on that they wouldn't withstand a crash very well. They're basically just tack welded on.
Old August 8th, 2013, 12:51 PM   #13
Redgeneral
Redgeneral's Avatar
Agreed 100%.
Old August 8th, 2013, 12:54 PM   #14
Weird. I'm not a small guy, and have had spools on every sportbike I've ever owned, and never ran into any clearance issues. I'm very surprised Kawi would design it such that there would be interference, even at full suspension compression. I also wonder how hitting the exhaust could provide enough force to rip a chunk of metal out of the swingarm. In the cases where spools have hit exhausts that I have seen, it puts a ding in the exhaust, which bends easily. To cause the damage you're showing, it seems like it would take a very large amount of force. It looks more likely that the spool hit something stationary itself rather than just contacting the exhaust.
How large is the outside diameter of the spools that you had mounted to the bke?
Alex is offline
Old August 8th, 2013, 01:25 PM   #15
c-dog
c-dog's Avatar
Motorcycle(s): -
Yikes! I have to check my 2011 ZX6R out. I have spools on it, and I haven't changed out the stock exhaust.
I bet that swing arm is one expensive part! Probably like $1000?
c-dog is offline
Old August 9th, 2013, 05:34 AM   #16
Redgeneral
Redgeneral's Avatar
They can actually be found for ~$150 on ebay.
Old August 9th, 2013, 05:40 AM   #17
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
Pics of the spool you used?
Live2ride is offline
Old August 9th, 2013, 06:54 AM   #18
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
I'd be pissed. If it was my bike I would try to get a hold of Kawasaki and see what they say. It doesn't seem like something that should have happened.
My Old Bike
My New Bike
thisisbenji is offline
Old August 9th, 2013, 07:20 AM   #19
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
The weld was crap if you look it has no penetration in to the base material if I was you id take it to a dealer.
fishdip is offline
Old August 9th, 2013, 07:37 AM   #20
Bentley813
Bentley813's Avatar
Motorcycle(s): 2013 White 300
Wait, your muffler caused the reinforced spool bracket to break off? Seems like it would have went through your exhaust before something like that happened.
Bentley813 is offline
Old August 9th, 2013, 07:46 AM   #21
lgk
I agree with everyone...
It must have hit something else,
because if it couldn't withstand a love tap with a muffler, it probably isnt strong enough to hold the bike safely...
lgk is offline
Old August 9th, 2013, 08:18 AM   #22
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
i bought some sexy red swingarm spools to match everything else and attached them with some noice blue lock tight guess i dun goofed D:
Aggrotech is offline
Old August 9th, 2013, 10:29 AM   #23
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
I hope mine wont ever hit my exhaust...
tehehehe
massacremasses is offline
Old August 9th, 2013, 10:40 AM   #24
MR2Aaron
Motorcycle(s): 2003 Kawasaki Ninja 250
Something I haven't seen mentioned, but could be a factor, is damage to the exhaust.
I have a ninja 250 and 500 that have both been knocked over. When this happens, it seems to have a tendency to Ben the mufflers inward, fairly significantly in the case of the 500. On the 250, it actually brought the muffler into contact with the swingarm. Could this be the case here, where the OP's exhaust was bent inward enough to cause interference?
MR2Aaron is offline
Old August 9th, 2013, 11:38 AM   #25
Redgeneral
Redgeneral's Avatar
Haha, you think the brackets are reinforced? Take a good look at yours. They are simply tack welded onto the swingarm. It's enough to hold the weight of the bike on spools, but any impact can and will shear them off. The more I researched my issue, the more I found that losing those spool brackets is pretty common. Mostly in crashes or high speed slides.
The bike has ~3500km on it. I'm the only owner (bought it with 2kms on the clock) and it has never been down.
Old August 9th, 2013, 11:40 AM   #26
Redgeneral
Redgeneral's Avatar
Would you rather lose a spool mount? Or have it rip your swingarm apart?
I'd rather lose the mount than have to replace my swingarm.
There's no guarantee anything bad will happen. I had spools on my 2009 250 and nothing bad ever happened to it.
Definitely was not a 'love tap' as there is a decent sized dent in the bottom of the muffler
Trust me, I'm not a happy camper...but this was caused by something I did. The damage was cause by an aftermarket part.
I already know the cause of the damage, no one needs to speculate how it happened. I only made this thread hoping to make people aware that this is a possibility as I had never considered something like this could happen.
Last futzed with by Redgeneral; August 9th, 2013 at 11:49 AM. Reason: Multi post
Old August 9th, 2013, 11:43 AM   #27
fishdip
fishdip's Avatar
Id rather have welds done right.
fishdip is offline
Old August 9th, 2013, 11:50 AM   #28
lgk
When i crashed my 250 it bent the bolt but the swing arm mount suffered no damage.
Maybe this happens more with aluminum swingarms.
lgk is offline
Old August 9th, 2013, 11:59 AM   #29
/thread closed at OP's request
Alex is offline
Closed Thread
[superbikeplanet.com] - Now Is The Time When We Wash The Swingarms At Austin (Photos) Ninjette Newsbot Motorcycling News 0 April 11th, 2015 08:30 AM
I shouldn't like this. But, do. 250rr General Motorcycling Discussion 8 April 28th, 2012 05:29 PM
Why you shouldn't look away GreenNinja Videos 14 December 11th, 2011 01:38 PM
[motorcyclistonline] - Dangerous Helmets, Swingarms, and Valve Stem Cap Questions | A Ninjette Newsbot Motorcycling News 0 June 8th, 2011 12:10 AM
[crash.net - MotoGP] - Pramac get carbon fibre swingarms for Catalunya. Ninjette Newsbot Motorcycling News 0 June 10th, 2009 06:40 AM
