Old May 31st, 2013, 08:21 AM   #1
bdavison
Wartown, USA
bdavison's Avatar
Went 150/60/ZR17....
Ok, so I've been wanting to try out a 150 on my ninja 250R just to see what it would be like, and after reading the posts from folks that have done it...went for it.
I chose the Michelin Pilot Road CT2 150/60/ZR17 tire.
First off, I dont know what crack the 150 proponants are smoking, but a 150 most definitely is not a "no clearance issues" tire for the 08 and later 250R.
Yes, you can install it, and yes it will work.
However, you are left with a baseball card thickness worth of clearance between the tire and the chain guard, and more importantly...between the tire and the right side of the swing arm.
Now...
Is that enough clearance to run it. Yes, provided you watch your tire alignment and air pressure religiously. After running this tire on my 250, through a rather hot run in the twisties, where I deliberately tried to get the tire to flex as much as possible, there are absolutely NO signs of any contact at the tight spots. I'm running 40psi in the rear to keep it nice and stiff. If you prefer lower air pressures for stunting, etc., it might be a possibility the tire will flex and make contact in the tight spots. IDK.
Now...as far as how it changes the handling of the bike.
Personally, I love it.
Gone is the "twitchy in the wind" feeling on the interstate. The bike tracks like its on rails, and is much easier to maintain your intended line through the corners. In addition, since its a radial dual compound EXTREMELY sticky rear tire, it hooks into corners like a dream and drives out of the exits with authority. As far as "loss of flickability"...I'm not seeing it. The bike still corners just as well as it did before, what I notice is less of the oversteer/understeer constant line correction that was necessary with the stock 130 rubber band that is normally used, instead I now have a very smooth instinctive "go where I point it" feel in the corners. To be honest....this is what should have been on the bike from the factory in my opinion.
Here is my set up...
Front tire. Michelin Pilot Power 120/70/17 - at 30psi
Rear tire. Michelin Pilot Road CT2 150/60/ZR17 - at 40psi - rear shock on "3"
Old May 31st, 2013, 08:30 AM   #2
Have you tried a 140? Plenty of clearance and delivers a lot of the positives you mention.
Old May 31st, 2013, 08:35 AM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Dude there was like 10mm of clearance to the swingarm with the 17-150/70 Michelin Pilot road 3s I was running. I think you mounted you tire backwards
Old May 31st, 2013, 09:06 AM   #4
bdavison
Wartown, USA
bdavison's Avatar
Um...tire is same width forwards or backwards...but mine is oriented correctly for direction of travel. Also, aligned and installed correctly. Its a big tire....obviously much larger than the 3.
Old May 31st, 2013, 09:10 AM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Sorry I figured the joke was pretty obvious
Maybe you mounted it inside out
Old May 31st, 2013, 09:23 AM   #6
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Old May 31st, 2013, 09:36 AM   #7
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Have you ever tried Rosso 2's? And 40psi? Are you nucking futz?
AFM #676
Supersports are for n00bs
Old May 31st, 2013, 10:47 PM   #8
tubarney
I agree. You cant use 40 p.s.i and say it doesn't flex. If it don't rub or make contact with under 24-26 p.s.i then you have a worthy mod.
Old May 31st, 2013, 11:24 PM   #9
CycleCam303
King Hamfist
CycleCam303's Avatar
Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796
I have a 150 and there is plenty of clearance for a hand or two. The radial tires will all have the positives that you mentioned. Eventually try the Pirelli rosso II's in a 140 width. I was really happy with them. @Jiggles I'm looking up tire pressure stuff now. I'm going to do some investigation. Basically I'm going to do a little street ride and figure out how hot I get the tires and play with setting the cold psi a few ticks below that. Words of wisdom from a crazy European guy I met at Sonoma. "It's just a street bike, who cares." This was said after he rode out to check out practice and his front tire had something like 19 psi in it.
CycleCam303 is offline   Reply With Quote
Old June 1st, 2013, 06:02 AM   #10
DaBlue1
DaBlue1's Avatar
40 PSI is high for the Ninja 250, even riding 2-up. Most of the big heavy cruisers (i.e. Vulcans) run tire pressures in the 40's. You should be good with 32-36 PSI. A good long run on a hot day or sitting out in the sun can raise tire pressure by up to 5 PSI from the cold inflation PSI.
Old June 1st, 2013, 07:46 AM   #11
WOTurtle
WOTurtle's Avatar
Motorcycle(s): 09' 250 ARRRRRR
I just got 150 70 pilot road 3 from revzilla and I CAN NOT GET THE BEAD TO SEAT. Did you have any issues? Even my local kawasaki dealer couldnt get it on.
WOTurtle is offline   Reply With Quote
Old June 1st, 2013, 08:40 AM   #12
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I leave my track pressures in my street tires, xept the bmw
AFM #676
Old June 1st, 2013, 02:49 PM   #13
cornering =/= flicking. A larger, heavier tire will not want to change speed/direction as easily as a lighter/smaller tire. This is equally true for accelerating, braking, and roll rate. Know why road cyclists are obsessed with super light tires/wheels? They make accelerating easier. An once of weight lost from the wheels feels like a pound of weight lost from the whole bicycle.
Personally, I noticed it minimally when going back-to-back between two sets of tires on my ninjette, but only when tossing it quickly from one direction hard to the other. Not that I'm saying that one type of tire was ever a 'bad' tire or that the bike felt slow to transition, but when going back-to-back, I noticed a small difference. Same idea as adjusting gearing; you only notice it right away. Once you get used to it, it's a non-issue. Is 'flickability' worth choosing one set of tires over another? likely not. The bike will still be light and nimble and a load of fun on curvy roads.
Again, this is all a theoretical point for discussion. In reality, YMMV. You might notice a difference if you ride with very quick, sharp directional changes; you might not if you like to be smooth and even in your carving.
As long as you like your tires and like the feedback you get while turning, that's the important part.
Old June 3rd, 2013, 08:28 AM   #14
chris21er
626ER
chris21er's Avatar
Motorcycle(s): 08 Ninja 250
I have the same exact sent up as you and im loving it!!!!!! Also looks a lot better
chris21er is offline   Reply With Quote
Old June 3rd, 2013, 08:36 AM   #15
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Sorry I just saw this.
I don't think I had any funny issues but I do use a good tire lube. If you ever have trouble beading a tire try wrapping a ratcheting tie down around the circumference of the tire and cranking it down to spread the bead and keep moving the tire around till you get lucky. I've had some crazy hard to head tires in the past but my PR3's weren't ago them.
Old June 3rd, 2013, 12:53 PM   #16
bdavison
Wartown, USA
bdavison's Avatar
I gave the tire to a local shop, and let them put it on. They had it on in minutes, didn't seem to give them any issues. At least they didn't say anything to me. However, mine is a Pilot Road 2CT, not the 3...so perhaps that makes a difference. IDK.
Old June 3rd, 2013, 12:56 PM   #17
bdavison
Wartown, USA
bdavison's Avatar
I'm not going to run it that low to find out. You can if it's that important to you.
Normally I run rears in the 38-42psi range, and I'd feel comfortable running this setup in that range. 24-26psi is in the "overstress the sidewalls, and prepare for blowout on hot day" range..even for a bicycle tire, so no.
Old June 3rd, 2013, 12:57 PM   #18
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Every style of tire is different but they will all bead eventually. I find Bridgestone street tires to be a total bitch to bead because of the stiff carcass.
Old June 3rd, 2013, 02:01 PM   #19
Panda
not an actual panda
So on a hot day and a spirited ride your pushing what.... 47psi in the rear if your 42 cold? Also I am running 150 shinko podium and I have no clearance issues.
Old June 3rd, 2013, 02:04 PM   #20
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
Pics ?!
Aggrotech is offline   Reply With Quote
Old June 3rd, 2013, 02:11 PM   #21
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Nah because he's probably running helium to keep the pressures from rising with heat.
Old June 3rd, 2013, 04:09 PM   #22
Panda
not an actual panda
Helium in tires + backwards = 15rwhp at least
Old June 5th, 2013, 11:20 AM   #23
bdavison
Wartown, USA
bdavison's Avatar
It usually tops out around 41.6psi on a spirited 20 min ride.
Normally, for every 10 degrees F outside temperature, the psi goes up 1.
I check pressures EVERY morning before riding.
Also, the cold temps on a tire are the max inflation at COLD....not the max pressure. So if the max cold pressure is listed on the tire as 40psi, it is designed to handle 40+ hot, also....underinflated tires generate more heat, and also increase pressures more rapidly. Properly inflating one, will make both the tire temps and the pressures more stable.
Old June 5th, 2013, 11:55 AM   #24
Jiggles
Jiggles's Avatar
MOTM - Apr '13
That's some high ass pressures! I run the lowest I can in my beamer without it yelling at me that the tires pressure is low which is about 36 psi in both
AFM #676
Old June 7th, 2013, 05:56 PM   #25
WOTurtle
WOTurtle's Avatar
Took it to tire kingdom, firestone, columbia power sports, and my friends tire shop. In the end carb cleaner and a bic did the trick. It's rained the past few days here, and wet grip/drive out of corners is AMAZING
Old July 12th, 2013, 06:59 AM   #26
mheitman
Motorcycle(s): '04 919 / '08 250r / '95 xr100
All this and not one pic of a 150 installed?
mheitman is offline   Reply With Quote
Old July 12th, 2013, 07:12 AM   #27
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Here
Old July 12th, 2013, 07:35 AM   #28
mheitman
Here
looks a little small for a 150.. how many miles are on it
Old July 12th, 2013, 07:49 AM   #29
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
About 100 to many
Here's another 150
Old July 12th, 2013, 05:00 PM   #30
mheitman
About 100 to many
Here's another 150
that's more like it - looks good.
PR3s ?
how are they holding up?
Old July 13th, 2013, 04:54 AM   #31
Rojo kinda kills tires. Effortlessly.
He might not be the best one to ask about how rear's are holding up, seeing as he likes to run a sweet tire in front, and a crummy IRC roadwinner in rear. He might just be the first person to get even wear on an IRC roadweener.
Old July 13th, 2013, 05:25 AM   #32
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Dude that front Michelin race tire I have on the bike right now has been on its last leg for a couple weeks. I swear the cords should have come through several hundred miles ago but I can still just bearly make out the center tread was and that tire is past 7000 miles
The 140 road winner on the back is doing great, still gripping the asphalt like a mofo and showing very little wear over 4000 miles into its life. I have a good feeling about this one, it may be my first rear tire I can get to go to cords on both sides and center. When I change the front tire here soon ill flip the rear tire again to keep the wear even
As for the PR3's they made it like 6000miles before they got to the cords so they are my longest wearing tire besides OEM. When I first mounted them up I loved them but during the last couple rides I started to lose faith in the front a bit for my more spirited(not your normal level of spirited) rides and when I finally went back to a full race tire I fell in love all over again.
Sure the race front wears fast then the road fronts but I can run them several thousand miles farther then a road front simply because even with the tire bald it still grips and feels great. But ill still mount a PR3 front for our short winter since I ride in the rain when it finds me.
Old July 13th, 2013, 08:42 AM   #33
*slowclap*
We finally found a rear that might get as much mileage as a front for Jason. Who'da thunk it'd be an IRC???
Old July 13th, 2013, 12:22 PM   #34
mheitman
thinking just the opposite. He looks like EXACTLY the person to ask about tire life.
Thanks, that's good to know.. I have them on my 919 and so far so good, but it will take me a few seasons to wear them out.
Old March 16th, 2015, 11:28 AM   #35
Ducatidave
Motorcycle(s): Ducati 998s, Aprilia RSV 1000r, Aprilia RS250 , 2012 Kawasaki Ninja 250
worn out safety hazzard
Wow, unbelievable!! I can't believe anyone would even run a sportbike tire with any cords showing. The way I ride, its definitely not worth the consequences. hopefully my friend you are not on the road with this....it only takes one time for that thing to go at the wrong time and your done.....not cool! Cords do not heat up and stick....the rubber does!
Ducatidave is offline   Reply With Quote
Old March 16th, 2015, 11:32 AM   #36
Welcome David!
There are few riders here who are above the normal curve, Rojo is one of them. If he feels he can rock that tire, then just take it at face value as one might have a different risk vs. reward curve than he does.
Old March 16th, 2015, 12:10 PM   #37
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Thanks for the input
I've been toying with the idea of putting a 150 on my 300, but since I plan on doing some track time with the ol' 300 I don't think I want to attempt anything that could compromise the handling.
....Either way, I want one just not sure if I'll pull the trigger.
Be careful. Remember you are
invisible
Old March 16th, 2015, 12:15 PM   #38
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
I got a 160 for my 300. Yes, i'm nuts. I fully admit it. No track plans at the moment and if i do i'll get track tires anyway. I should have them mounted this weekend.
Raven's Rejuvenation
Old March 24th, 2015, 01:30 AM   #39
Ducatidave
More like below the curve I think if I'm understanding you right. I have a stock pile of race tires and road tires that will fit his bike that have less then 500 miles on them that I am willing to pay shipping on and give him for free if its a money issue just so as these type tires are not put on the road for his safety and those who will be at the receiving end. I really can't imagine anyone enjoying riding on cords on edge. I would just hate to run him over not if but when the tire lets go in a turn. Just saying......
Bridgestone Battlax BT-016 Rear Tire 150/60 ZR17 100$ krolinked Motorcycle-related 0 January 7th, 2013 06:39 PM
FS: Michelin pilot powers 110/70/zr17 150/60/zr17 Havok Motorcycle-related 14 June 19th, 2012 05:20 PM
[topix.net] - 2010 Ford F-150 Harley-Davidson, an AW...2010 Ford F-150 Harley-Davidso Ninjette Newsbot Motorcycling News 0 March 24th, 2010 02:00 PM
Ninjtiny anyone 150 RR ztrack157 General Motorcycling Discussion 31 October 7th, 2009 06:17 AM
