May 1st, 2016, 06:32 AM | #1 |
Join Date: Jan 2016 Motorcycle(s): 2007 Ninja 250 Posts: 96
Just did valve adjustment. Can we flush the engine somehow?
Me and my buddy just did a valve adjustment. Unfortunately we dropped a socket once and then a bolt. We had to fish those out at two different times using a string and magnet and a long piece of wood to push it down. We got it out but I'm worried the magnet and wood shed some debris into the engine.
Beside draining the oil is there anything else we can do to try and flush the engine clean? |
May 1st, 2016, 07:56 AM | #2 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Highly doubt the magnet left anything in the engine, while the wood might have, though i would venture to guess the amount is negligible and do little damage as it can easily break down compared to something metallic.
Just flush the oil and you should be good to go, unless your chunk of wood was missing chunks from it. |
May 1st, 2016, 08:32 AM | #3 |
Great. Thanks. Well flush the oil today and put it back together. Hopefully the valve adjustment was good to go.
May 1st, 2016, 08:41 AM | #4 |
I'm crazy,your excuse is?
Next oil change also clean the screen.
May 1st, 2016, 10:53 AM | #5 |
A very old school trick was to add a little bit of kerosene to the oil, idle for about 5 minutes, then drain the immediately.
Since synthetic oils have excellent qualities over old school conventional oils this practice is no longer needed in most cases, but it's an excellent way to get rid of sludge and gummed up deposits. Or you could use this method, although I would highly recommend not doing this. How to clean the crankcase, and airbox without disassembling
valve adjustment | mauiwowie | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 17th, 2015 08:15 PM |
Engine noise and delayed throttle response after valve adjustment and carb clean | gdvd | 2008 - 2012 Ninja 250R Tech Talk | 27 | January 6th, 2013 04:54 PM |
Valve Adjustment Engine Won't Turn Over. | ukie | 1986 - 2007 Ninja 250R Tech Talk | 86 | February 15th, 2012 05:23 AM |
Valve Adjustment-Really Tight adjustment screw? | mikesova | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 2nd, 2010 04:57 AM |
anyone want to help with a valve adjustment? | diablo250 | Group Rides and Local Events | 2 | March 28th, 2010 02:00 AM |
