Old March 12th, 2016, 05:11 PM   #1
Jdero_620
Motorcycle(s): None anymore/yet
Clutch replacement
How hard is clutch replacement? Full kit. Can it be done by a typical driveway mechanic?
Jdero_620 is offline   Reply With Quote
Old March 12th, 2016, 05:48 PM   #2
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
If you are referring to replacing just the disks, it is not that difficult. Utilize the service manual for reference. I think there is a link of it floating around here or just google for it to download.
chugs is offline   Reply With Quote
Old March 12th, 2016, 07:42 PM   #3
Ghostt
Ghostt's Avatar
Can I ask why your asking, the clutch is pretty much bulletproof, with the exception of the clutch springs themselves, those are the weak links.
violente et ignorantia
ZX-2R BLOG
Old March 12th, 2016, 09:12 PM   #4
Jdero_620
Because even after I adjusted it ( it was all the way in and rattled like crazy) it only grabs at the last 20% of the release.
Old March 12th, 2016, 09:45 PM   #5
Is this a ninjette? Which year?
Old March 13th, 2016, 07:30 AM   #6
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Ninjettes tend to grab at the very end of the release, as long as it's not slipping you should be OK.
My Cafe Racer Build
My intro post
Old March 13th, 2016, 07:44 AM   #7
Jdero_620
11 Cbr 250
Old March 14th, 2016, 05:29 AM   #8
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Like someone else said, clutch work is pretty easy not much to get wrong there. The only thing that can be a pain is getting the basket nut off if you even need to go that far in. That is basically the last part before you get to the clutch gears and bearings.
The nut comes off pretty easy with a clutch tool and can be done without one but there is always a risk of damaging something when using whatever "custom" method you use to lock things up with.
Tear it apart, have a look, fix whatever is messed up or just throw it back together, should be a quick job.
Old March 31st, 2016, 03:43 PM   #9
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
It's been about 2 years since I changed mine, but I was able to do it and I'm a noob who really doesn't know what he's doing when it comes to mechanics.
walty87 is offline   Reply With Quote
Old March 31st, 2016, 04:52 PM   #10
APEmike
Motorcycle(s): 2014 Ninja 300
If you are just changing frictions and steels its super easy.
Get a bag and soak new plates in oil for at LEAST 10 minutes, but longer than an hour is pointless.
Remove clutch cover (you did get a new gasket, RIGHT?)
Remove old plates. Take special note if there are any rings, unique plates, or wave washers.
Take new steel plates and put them in a stack. See how they look? They are stamped steel, and you can tell which direction they were cut in by looking at the edges. MAKE SURE THEY FACE THE SAME WAY. Its easy once you take a look at them, but critical as they all have a little curve to them and if they arent facing the right way the pack may end up too thick.
Put the new plates in. Use your notes that you made of weird parts when you took it apart to put it back in the same way.
It sounds harder than it is. Any one of us who have done it before could probably do it again in under 30 minutes.
I ride because therapy is too expensive, and less fun.
Old April 1st, 2016, 10:32 AM   #11
Originally Posted by Jdero_620 View Post
11 Cbr 250
The range of friction zone has noting to do with the condition of the clutch.
Play with the levers instead.
Just in case you disregard my advice:
Old April 1st, 2016, 11:12 AM   #12
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
be sure to soak the friction pads the night before, you will burn them up on the first clutch release if they are dry...
the 11 CBR 250 is a wet clutch right?
if it is, just add a little clean oil to the package and let them sit over night.
if you don't do it in the package they never get fully oiled all the way around sitting in the bike.
I actually get to see my clutch plate, my TLR has a window
http://img.photobucket.com/albums/v620/Ricejocky/achievement.easy.bake.Rifleman_zpscllv4ryl.png
Rifleman is offline   Reply With Quote
clutch cable replacement james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 20th, 2015 11:54 AM
Please help!! Clutch cable replacement complication Dustinfools 2008 - 2012 Ninja 250R Tech Talk 31 November 29th, 2012 01:34 PM
2003 Ninja 250 Clutch Basket Replacement!! RobJB 1986 - 2007 Ninja 250R Tech Talk 3 March 2nd, 2012 07:16 AM
Clutch Replacement talisman.26 1986 - 2007 Ninja 250R Tech Talk 11 February 26th, 2012 01:35 PM
2008 model clutch cable snapped @ 17,800 miles. Replacement? CZroe 2008 - 2012 Ninja 250R Tech Talk 9 December 14th, 2010 05:40 PM
