Old July 23rd, 2011, 09:24 AM   #1
venmichaels
Motorcycle(s): 08 ninja 250r
I need help replacing my turn signal on my ninjette!
Can someone please guide me through this??
I need to replace bother front turn signals.. i have no idea where to begin.. i already bought the new pods.. but how do i remove the old ones???
DO i HAVE to remove the side fairings?? is there any easier way to do this??
venmichaels is offline   Reply With Quote
Old July 23rd, 2011, 09:29 AM   #2
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
From the DIY on installing LED front signals:
1. Remove the fairings. Please refer to this thread.
2. Remove the OEM turn signal. It's just one screw. The screw is located on the back side of the blinker inside the blinker well. You might also want to break this screw loose before removing the fairing. I have a JIS #3 driver that I used. You can get away with a phillips #2. Here's a picture to give you an idea where it is: (taken from the DIY flushmounts thread)
Old July 23rd, 2011, 09:46 AM   #3
venmichaels
i was told there is an easier way to do it without removing the fairings.. just the black plastic housing around the headlights.. is this true?
Old July 23rd, 2011, 12:37 PM   #4
wtfh4xx
Opinionated individual :)
wtfh4xx's Avatar
Motorcycle(s): 2010 Ninjette Special Edition (red/black)
Gotta remove side fairings to remove the front housing.
At least without making it very difficult and maybe breaking some tabs.
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete
2010 SE 250R!
Miles in the saddle: 1000
wtfh4xx is offline   Reply With Quote
Old July 24th, 2011, 05:49 AM   #5
neldy
neldy's Avatar
Motorcycle(s): 2011 250 Ninja
I replaced my front left yesterday without removing the fairing.
Tools required:
1 Phillips Head Screwdriver
1 Girly left arm
Didn't find it too difficult to do it all blindly and through the small gaps on the side.
neldy is offline   Reply With Quote
Old August 4th, 2011, 02:19 PM   #6
SweetB
Motorcycle(s): 2009 Blue Ninja 250, 2009 White Vespa S 150
neldy:
Whew! I have to replace one tonight and I'm glad I have girly arms, because I'm really not wanting to take the fairing off.
SweetB is offline   Reply With Quote
Old August 4th, 2011, 02:47 PM   #7
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Be careful on replacing it if you don't remove the fairing. I just installed some LED flushmounts for one of the locals here last saturday on his 2011 and the screw/bolt was stuck. I had to get some pliers and have him hold it while I broke it loose. If yours just turns and turns and doesn't seem like it's loosening, it's likely twisting the rubber grommet, rear plate, and wiring. I don't understand the fear of removing fairings.
Here's a rule of thumb, if you take off all the bolts and clips and you think it's ready to come off, then wiggle it loose. It should come off pretty easily. If for any reason it feels like it's caught on something, you missed a clip or bolt. The fairings won't just drop off the bike once all the bolts are off. They're held in place by slots as well. Take your time and give yourself plenty of time and work space. Don't be scared of working on your bike!
The www.ModMy250.com guy
Old August 12th, 2011, 09:38 PM   #8
I dunno why people act like you can't remove the leads from the bulb socket/reflector/collector.
Assuming that you are replacing it with an identical OEM part, here are the steps:
Unscrew and remove the lens
Lift the collector out of the plastic shroud
Disconnect the blade terminals from the back of the collector/socket
Remove the housing (the collector is what held the housing to the stalk)
Bend the connectors to straighten them (you may not have to do this if you aren't replacing the stalk)
Unscrew the stalk
Thread the wires and straightened terminals through the stalk
Thread them back through the new stalk
Place the new housing on the stalk with the wires threaded through
Bend the connectors to angle them again
Attach blade connectors to the new collector/socket (slightly longer green wire goes to the outer terminal but polarity doesn't really matter)
Transfer the bulb from the old socket*
Align the lens and screw it down
You're done. The only other thing to mind is that the left and right blinker housings are different in that they both have a drainage hole that should face down. It is only the housings, so everything else is interchangable. You can use a right-rear housing on the front-left or a left-rear housing on the front-right and the holes will face down.
*This can be more difficult than it looks. You are supposed to push down and turn counter/anti-clockwise and lift but one of mine could not turn due to excess plastic
I should mention that one of my rear signal stalks would not come out gracefully recently. The plate it threads into would just spin and tear at the sleeve covering the wires behind it. This isn't an issue if you are reusing your stalks.
Old August 12th, 2011, 10:46 PM   #9
/moved to new-gen tech
Replacing Front Turn Signals UCSDavid 2008 - 2012 Ninja 250R Farkles 4 August 21st, 2014 10:37 PM
Turn signal mounting plate replacing...HELP rph12 1986 - 2007 Ninja 250R Tech Talk 5 March 8th, 2012 09:48 PM
Replacing Turn Signal Bulbs zCasanova 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2012 01:06 PM
Replacing turn signals C L 2008 - 2012 Ninja 250R Tech Talk 2 September 12th, 2011 02:19 PM
Help Replacing Front Turn Signals nightshade 2008 - 2012 Ninja 250R Tech Talk 3 June 22nd, 2010 12:37 PM
