May 2nd, 2016, 10:33 AM | #1 |
MOTM - Jan '18, Sep '13
Ninja 300 Engine in a Pre-gen
http://www.bayarearidersforum.com/fo...d.php?t=494205
Someone did it, if anyone here was interested.
My Ninja 300 |
May 2nd, 2016, 10:44 AM | #2 |
Vintage Screwball
MOTM - Mar '16
SOunds like he needs to undercut the gears in the tranny.....having shifting issues.
32 MM carbs and a bolt in 300 engine, eh? Interestingly enough, it's only a 4 HP bump over a new-gen 250 though....his dyno'd out at 35 HP, my 250 is 31 HP. Should have gone with larger carbs. They are not the same as throttle bodies.....carbs have a venturi that slims down the air stream and a slide too. I'd go at least 34MM carbs on that one. Maybe 36. I'd also look at the advance curves between the 300 ECU and the pre-gen CDI. I'll bet they're different.........but a cheap ignition box for a pre-gen would fix that.
Goin' fast on slow bikes! |
May 2nd, 2016, 10:53 AM | #3 |
I'm crazy,your excuse is?
sweet!
May 2nd, 2016, 11:53 AM | #4 | |
His dyno numbers are right on with most of the runs I've seen - which is to say not overwhelming. Even though your 250 engine is pretty close, I would expect the 300 to make its power lower and have a bit more torque. Judging from the port differences I agree that it could most likely use more than 32mm carbs. That may be holding it back at this point. I'd like to see what kind of numbers a fully-built 300 would produce. |
May 2nd, 2016, 12:30 PM | #5 | |
Vintage Screwball
MOTM - Mar '16
It is good to note, however, that his dyno numbers at the rear fit perfectly with the FI model. Dood did a good job on this swap for sure! It's just that, while I was in there, I'd be doing a bit more hop up for all the work. Then again, I don't know the class he's running in and the rules for it either.
May 2nd, 2016, 01:05 PM | #6 |
EX500 full of EX250 parts
FYI, the EX500 uses CVK34 carbs. I assume it would be plenty for the 300 too.
The Gen1 and Gen2 500s use different ignition pickups as well. The Gen1 flywheel has exploding magnets, but you can swap in the Gen2 flywheel if you just modify the triggers a bit. You might be able to do something similar with the 300 flywheel to make it work with the PreGen ignition. Personally, a lot of the reason I'd want the 300 engine is for the EFI. Pairing the engine with mostly PreGen parts seems less than ideal to me, though obviously much cheaper and simpler.
May 2nd, 2016, 02:25 PM | #7 |
May 2nd, 2016, 02:31 PM | #8 | |
Vintage Screwball
MOTM - Mar '16
You can pick up a 300 motor for 5-600 bucks off FleaBay and re-use a lot of things you have on hand. Bore, pistons, cam, etc would cost you well north of that to mod a 250.
May 2nd, 2016, 02:58 PM | #9 |
Something to keep in mind when the 250 engine wears out.
May 2nd, 2016, 05:04 PM | #10 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
About the cvk34, you would likely need different carb boots.
Because Unregistered sucks at riding. |
May 3rd, 2016, 07:25 AM | #11 |
Fighting Texas Aggie '05
So the curious thought then is - are the pregen and newgen ignition, flywheel, and covers also exchangeable? Would the same process work as is with the new gen? I do think the 300 swap if it can be done for a reasonably cheap sum would allow the 250s to continue as a competitive option vs the newer 300+ class bikes. To me is seems like it would cost less to swap the 300 mill than to do a 250 sbk build to 300cc range.
May 3rd, 2016, 07:39 AM | #12 | ||
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
The 250 flywheel bolts to the 300 crank. I'm pretty sure the side covers are interchangeable. Quote:
Last futzed with by bruce71198; May 3rd, 2016 at 07:41 AM. Reason: screwed up on multi quote |
May 3rd, 2016, 09:09 AM | #13 | ||
The 500 switched from a single trigger and multiple pickups to multiple triggers and a single pickup, so the side covers and harnesses are different. What should be a fairly simple swap turns into a bunch of parts needing to be changed for everything to match up. Chopping down the trigger ends up being the simplest way to make everything work together. Just thought I'd point out another option, but it doesn't really seem like this would be all that useful on the 250/300 stuff. I wasn't sure how much your stuff cost, but I knew I had seen numbers higher than his. His method seems sort of like a drop-in big bore upgrade. Quote:
If I was going to the trouble of swapping in an engine from a different bike, but still keeping the carbs, I'd be tempted to go this route. If you're racing, there are classes and such to consider. But if you're not limited like that, this should give you even more power, and you don't need to figure out the proper fueling/ignition stuff to go along with the swapped engine.
May 3rd, 2016, 09:10 AM | #14 |
Vintage Screwball
MOTM - Mar '16
Converting a 250 to EFI though would require the 300 gas tank.....unless the fuel pump and all the other goodies bolt in to the 250 tank.
May 3rd, 2016, 09:45 AM | #15 |
They make a kit to convert the ninja 250 to efi with the stock gastank.
May 3rd, 2016, 11:21 AM | #16 |
May 3rd, 2016, 11:23 AM | #17 | |
Vintage Screwball
MOTM - Mar '16
I was just curious what other ideas were since people seemed to want to keep the EFI for the 300 in a 250 frame but hadn't mentioned the fuel side of things. Personally, I think the pre-gen chassis is a terrible idea for the 300 conversion but that's me. I'd have popped into a 2008+. I like the idea of re-using the pre-ignition and carbs though. Keeps things a bit more simple with no apparent decrease in performance.
May 3rd, 2016, 11:26 AM | #18 | |
May 3rd, 2016, 11:27 AM | #19 |
Vintage Screwball
MOTM - Mar '16
I'd slap a set of Mikuni VM34's on there and see what happens.
May 3rd, 2016, 01:46 PM | #20 |
Schönen Tag noch
Join Date: Sep 2013 Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica Posts: 184
I've been following on grease_monkey on barf, I might do an FI application into my pregen this summer.
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. | AFazakerley | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 5th, 2016 02:03 PM |
Needed: pre-gen engine! | thuggiehuggies | Items Wanted | 4 | March 30th, 2014 04:42 PM |
Pre gen-new gen engine differences | baxtc1 | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 3rd, 2013 04:43 PM |
pre-gen engine | bhalv | Motorcycle-related | 1 | September 30th, 2011 08:20 PM |
anyone have some engine parts (pre-gen) in phoenix az | dirtyrottenninja | Items Wanted | 1 | August 5th, 2011 03:36 PM |
