Old June 13th, 2014, 03:41 AM   #1
reroka
Biker Noob
reroka's Avatar
Motorcycle(s): 2004 Honda Shadow 750 Aero
1st ride on 15/42 sprockets
I love it, THe speedo says 70, really going 65 at under 8k rpsm. Got the bike up to 90 on the speedo really 85 and I was just a bit under 10k rpms.
It is a whole hell of a lot nicer with this set up. I am sure my gas mileage is going to sufer doing this though. Thoe other thing I found great was, it's not as loud as it was. I seems to be more quite than the other set up I had. It could be the fact I had a lot of wind but it does not seem that way.
Riding as I stole it.
reroka is offline   Reply With Quote
Old June 13th, 2014, 05:51 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I guess I get the sprocket change if you are:
Looking to conserve fuel
For some reason want to run lower revs for said speed (lots of long distance highway)
want to have a higher possible top speed.
race and for particular track want to be in said gear for said turns ect...
I have not tried the sprocket change for a few reasons and probably won't, why? I just don't think it makes sense for the way I ride.
The bike's power and fun range is 9.5k-13k rpms, with that said I will most likely be in those rpms for anything but city riding, so 15t just means I need to go faster to be in that range for a given gear, not necessarily a benefit.
My bike can't pull in 6th up some of the highway hills as is with stock gearing, it would only be worse with 15t.
I don't need the bike to have a higher top speed, would I like it... sure but not necessary on many levels.
I guess in short YMMV, is the 15t 42t setup better than stock... not necessarily depends on what you are doing so take it all into consideration
Old June 13th, 2014, 06:24 AM   #3
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
It depends on what the goal is of the rider.
If you mostly use the bike for commuting and cruising longer gearing might be nice, but if you live somewhere that has 45 mph speed limits shorter gearing might be nice as well.
I know I have a -1/+2 setup on my bike to increase RPMs.
My Old Bike
My New Bike
thisisbenji is offline   Reply With Quote
Old June 13th, 2014, 06:42 AM   #4
reroka
Biker Noob
reroka's Avatar
See a lot of my riding is high way riding with speed limits of 60-70. So going to this makes a whole lot of sense. I live int he country not in the city. So I have to drive 30 miles on the high way just to get to the city. Then I have to go another 30 miles of high way just to get to work.
Old June 13th, 2014, 07:24 AM   #5
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
^^ I will be making a similar change as well for the exact same reasons, 75% of my commute it above 60-65 mph. Why did your speedo change though, its driven off front wheel
Old June 13th, 2014, 07:32 AM   #6
reroka
Biker Noob
reroka's Avatar
Just because my speedometer shows you going 80 does not mean you are.
For example a couple of days ago. I am rinding earrly in the morning, rode to my self. I wanted to see if I could top out the ninja. My speedometer says I was going 100 MPH Cope pulled me over and told me I was going roughly 93 in a 70.
So the speedometer is off, not sure why I just know it is.
Old June 13th, 2014, 07:42 AM   #7
sharky nrk
sharky nrk's Avatar
Understand there is speedo error, it just read like the change came after the sprocket change. Its all good.
Old June 13th, 2014, 08:00 AM   #8
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
...13k rpms...
Do you have a pre-gen, otherwise I would like to ask what that high rpm should be good for?
Please take a look at the dyno from the best and highest tuned 250 Racing-Ninja and you'll see that the highest value producing power of this engine is not above 12500 rpm (12418 rpm to be correct).
Old June 13th, 2014, 08:27 AM   #9
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I don't feel like it should need explained but ok
Sure peak is lets say 12k give or take. I can't run at 12k 24/7 especially when accelerating and running the gears right?
Ok when you shift the rpms drop right? right! So what happens if I shift at 12k? My rpms will drop out of the power band and I will have to build speed to get back into it, me no like.
What happens if I shift at closer to 13k? The rpms drop but they drop me to a rev range that is still in the power band. Even if power drops off at 12k, at 13k I still make more power than I would at say 9.5k give or take where I would end up if I shifted at 12k, does that make sense?
plus no 2 bikes are tuned the same way, you can tune your bike to run better at the higher revs, just because that particular race 250 drops off at 12k doesn't mean all bikes have to.
Old June 13th, 2014, 08:32 AM   #10
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
all of my commute is above 60-65mph if I can help it
Old June 13th, 2014, 08:33 AM   #11
reroka
Biker Noob
reroka's Avatar
I would like to get a digital speedo, not sure if there is one out there.
Old June 13th, 2014, 08:41 AM   #12
sharky nrk
sharky nrk's Avatar
lol, the school zones and stop signs would prob not appreciate me tagging 65 lol.
Old June 13th, 2014, 09:36 AM   #13
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Old June 13th, 2014, 09:56 AM   #14
DaBlue1
DaBlue1's Avatar
KOSO
Translogic
Old June 13th, 2014, 10:43 AM   #15
sharky nrk
sharky nrk's Avatar
LOL
Old June 14th, 2014, 07:48 AM   #16
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
On my 2012 250SE stock sprockets are 14/45. I'm going to install a 41 tooth rear sprocket to drop engine speed by a factor of 41/45 = 0.91.
Currently at 9000 rpm road speed is 60 mph. After I change the rear sprocket, engine speed will be 0.91 x 9000 = 8190 rpm at 60 mph resulting in a cruising speed that puts a little less stress on the engine.
It shouldn't feel overly sluggish as I have a few more ponies to pull the taller gearing with the Yoshimura full system exhaust installed.
C-Bass is offline   Reply With Quote
Old June 14th, 2014, 08:40 AM   #17
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Congratulations! For those Ninjetters who do a lot of freeway riding installing taller gearing is a great mod. It's always a compromise but if it fits your riding pattern it makes for a more enjoyable and efficient ride.
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
1st real ride of the year! LittleRedNinjette Pictures 2 March 9th, 2013 08:55 PM
Sprockets, sprockets, ahhh sprockets?!?! shelei09 General Motorcycling Discussion 10 January 23rd, 2013 09:47 PM
How was your 1st ride to and from Work/School/etc.. MotoED General Motorcycling Discussion 25 August 18th, 2011 09:08 AM
1st EXTENDED ride.. IndyTwoFiddy Ride Reports 5 June 9th, 2011 06:00 PM
MAY 1st - International Female Ride Day azia Ride Reports 3 April 29th, 2009 05:26 PM
