Old December 28th, 2013, 05:51 PM   #1
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Mounting New tires
How do you guys mount new tires on the rims?
I tried blasting compressed air in through the valve stem after I had put the tires on and it didn't work. Do I have to remove the valve core to set the bead on the rim when doing this? I also tried spraying starter fluid all around the rim but it only set my tire on fire..... The bike shops nearby are all closed for the holidays I'd really like to ride again asap!
Mods: Offset clutch pressure plate
Old December 28th, 2013, 05:53 PM   #2
Talk to @rasta (link to recent thread)
Old December 28th, 2013, 06:33 PM   #3
rasta
Your face
rasta's Avatar
lol I'm quite an expert after my ordeal last week.
The valve stem should be removed, it will allow you to blast more air into the tire.
Old December 28th, 2013, 06:40 PM   #4
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
Take the core out and shove an air hose on the stem. If that fails you can always spray something fun in there and touch it off. Or get a bigger air tank that flows more
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old December 28th, 2013, 06:46 PM   #5
Originally Posted by FvnnyL3tt3r1ng View Post
............I tried blasting compressed air in through the valve stem after I had put the tires on and it didn't work. Do I have to remove the valve core to set the bead on the rim when doing this? I also tried spraying starter fluid all around the rim but it only set my tire on fire.....
The tire and wheel should be properly lubricated, both beads should be contacting the wheel all around and the valve core may be removed from the valve stem to allow more air flow into the tire.
If the beads don't seal all around, you can tie a rope or belt around the perimeter of the tire, like in the pic, in order to spread the beads.
You should keep hands, arms, and entire body away from the tire during the bead seat and inflation.
Do not stand over the tire.
Do not leave tools on the tire sidewall when inflating tire. NEVER increase air pressure to exceed 40 psi when attempting bead seating.
Old December 29th, 2013, 06:03 AM   #6
FvnnyL3tt3r1ng
Ok, will try! Have to go to my storage unit to pick up the core removal tool anyways.
Old December 29th, 2013, 12:16 PM   #7
FvnnyL3tt3r1ng
Ok, strap around the tire worked great for the back tire but now the front won't seal up even with 2 straps on it. I don't know what to do I tried starter fluid and pry bars to seat the tire but nothing is working....
Old December 29th, 2013, 12:47 PM   #8
.........I don't know what to do I tried starter fluid and pry bars to seat the tire but nothing is working....
You could use a bicycle inner tube (maybe a 20") as a donut to restrain the air from escaping too fast until you build up some pressure.
Old December 29th, 2013, 12:56 PM   #9
FvnnyL3tt3r1ng
That's not a bad idea.... To give up or push on???
Old December 29th, 2013, 01:57 PM   #10
http://www.gtsparkplugs.com/Bead_Seat.html
Old December 29th, 2013, 02:31 PM   #11
FvnnyL3tt3r1ng
Crazy thing is there is this random rubber o-ring laying in the garage.... Must try!
Old December 29th, 2013, 03:20 PM   #12
Felipe the Ant
Also see if there's any way you can get more air flow
Old December 29th, 2013, 03:33 PM   #13
FvnnyL3tt3r1ng
O ring was too small. I think it was from a vacuum cleaner. Will buy a bike tube tomorrow and give it a try. I am using an 11gal portable tank with a short rubber hose with 300 psi rating connected to a trigger you squeeze to let air out..... a 16" tube will work for our bikes I would imagine??
I wonder if there are any around the house products I could use in place of the inner tube so I don't have to wait til tomorrow....
Old December 29th, 2013, 05:10 PM   #14
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded)
After reading some articles and the thread rasta had, I feel like I might just pay more $$$ and have a dealership swap tires for me lol.
Sykes92 is offline   Reply With Quote
Old December 29th, 2013, 05:46 PM   #15
FvnnyL3tt3r1ng
I don't blame you but I will say it gets easier every time. By the time you get the process down it will be a piece of cake. I think next tire change will be very easy. From what I've learned I do think tires with higher aspect ratios seat easier.....
Old December 29th, 2013, 06:18 PM   #16
..........I wonder if there are any around the house products I could use in place of the inner tube so I don't have to wait til tomorrow....
Do you have a rubber hose or foam tube (floater or pipe insulation) to make a donut with?
Old December 30th, 2013, 12:16 AM   #17
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
I had a flat on the highway once and broke the bead. We connected two belts around the center and cinched while my compressor was on and it worked.
Best way I've found is to get a ratcheting tie down, lube up the bead with soapy water or WD-40 and ratchet away while the compressor is on. I've done this with bike, Atv and car tires with great success.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old December 30th, 2013, 06:59 AM   #18
Old December 30th, 2013, 12:14 PM   #19
FvnnyL3tt3r1ng
The ratcheting tie down didn't work. I think the compressor hose itself might work (an extra) but I'm gonna buy a tire tube today.
Old December 31st, 2013, 05:38 PM   #20
FvnnyL3tt3r1ng
put a 16" inner tube on one side of rim but it didn't help. Air still leaks out.... I would've bought two but they only had one left at the store...... I'll try again tomorrow when there is actually light out.
Old December 31st, 2013, 06:09 PM   #21
kirk595x
kirk595x's Avatar
Have you tried warming the tire up before trying to seat the bead? Either leave it out in the sun if it's warm or a space heater then try the strap method?
Old December 31st, 2013, 08:26 PM   #22
FvnnyL3tt3r1ng
I mean I'm sure it wouldn't hurt but the temp has been around 77+ here so I wouldn't say they are frozen or anything. Hopefully walmart is open tomorrow so I can get another inner tube.... Seems like such a small thing to be stuck on but what can you do....
Old January 1st, 2014, 08:35 AM   #23
FvnnyL3tt3r1ng
With 2 tubes it starts to seat then the tubes pop out and air leaks out. Grrr
Old January 1st, 2014, 10:40 AM   #24
More lube, more patience and then, even more lube !!!
Keep that brake disc protected from any forces.
Old January 1st, 2014, 11:01 AM   #25
FvnnyL3tt3r1ng
I went to a tire kingdom and they shot it with a ton of air and seated it. They said it was free so I gave the worker $20. I'm not sure it was gonna work ever my way because I think I would need a whole lot more air pressure/volume to seat the bead as quickly as possible. Never buying that size tire for the front again! The bigger the better imo....
Old January 1st, 2014, 11:05 AM   #26
What tire is it?
Sometimes, the tires are flattened sideways due to long storage at the bottom of a pile of tires.
Old January 1st, 2014, 11:28 AM   #27
FvnnyL3tt3r1ng
What tire is it?
Pirelli diablo scooter? 100/?? -16......
Started Mounting and balancing my own tires Runeknight95 General Motorcycling Discussion 27 August 9th, 2013 04:49 AM
Mounting tires in Seattle kevinlo423 General Motorcycling Discussion 2 July 24th, 2011 07:45 PM
Tip - Mounting Dunlop Tires g21-30 2008 - 2012 Ninja 250R Tech Talk 7 March 24th, 2010 08:07 PM
[webbikeworld.com] - Mounting Avon Storm ST Tires Ninjette Newsbot Motorcycling News 0 June 12th, 2008 01:10 PM
