Old January 14th, 2014, 08:40 AM   #41
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
My ears just perked up... I knew I heard 636 somewhere
Old January 15th, 2014, 03:48 AM   #42
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
how long has that ladder trick been in the book? because that is legit, probably not that reliable but good enough for the 250, no?
The Bike | The Truck
Old January 15th, 2014, 04:22 AM   #43
This isn't the first pic of a bike hanging from a ladder that has been posted on this site. Been at least a year now. Reliable? Sure, well... maybe a bit unstable at times, just be mindful of the weight limit of the ladder and your strait.
Old January 15th, 2014, 06:42 AM   #44
It's always worked for me.
And yes, I learned it from CB also.
Old January 15th, 2014, 06:58 AM   #45
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I think this was the first time I tried it. That was several years ago. It seems to work well for 250's and 600's so far. I don't see why it wouldn't work for 1000's but I don't think i'd try it on any sport touring or touring bikes.
Old January 15th, 2014, 09:05 AM   #46
Typical weight limits for ladders are like 250-300 lbs right?
Old January 15th, 2014, 09:40 AM   #47
Yea, 375lbs is the heaviest duty ladder I have seen. 200-225lbs is light/medium duty and what most homeowners have.
Old January 15th, 2014, 09:49 AM   #48
Gurk
Done here.
Motorcycle(s): -
I change fork oil 3-4 times a year. Granted I track only but still. Think about changing it more often..
Also a +1 on ECU flash. I've changed sprockets, got a full exhaust, race airfilter, delete smog system and bunch of other stuff. ECU throttle mapping + fuel mapping + engine brake adjustment + few others were by far the most effective in comparison to all other performance mods I've done.
Gurk is offline   Reply With Quote
Old January 15th, 2014, 09:52 AM   #49
Geeezzzz... chopping that hulking cat off the midpipe must have felt good. I still need to do mine.
Old January 15th, 2014, 09:52 AM   #50
does your fork oil really degrade that quickly or are you just changing for weight?
Old January 15th, 2014, 09:57 AM   #51
Gurk
Done here.
Motorcycle(s): -
It's to protect forks more than anything. When I pour the old oil out it's watery and dark grey. So yes, it does degrade that quickly.
Old January 15th, 2014, 10:00 AM   #52
Gurk
Done here.
Motorcycle(s): -
The difference in weight is so ridiculous... And I never thought it would make that much of a difference therefore I resisted for a long time. Boy was I wrong.
Old January 19th, 2014, 04:19 PM   #53
TnNinjaGirl
Ms. Personality
Bike is back together enough to run. Still not rideable but it will be soon.
He sent the ECU to Bauce Racing and had Anthony do it. Working on zeroing out his Power Commander as I type this.
The bike comes apart and goes back together pretty quickly.
This video is with a 2 brothers slip on, gutted the cats, aftermarket mid pipe and the ECU tune.
Old January 20th, 2014, 07:28 AM   #54
TnNinjaGirl
Ms. Personality
Yay! she's on her own 3 (?) feet again!
My paint job on the exhaust was nice but not so much on the rearsets. I'm going to have those painted by the same person doing the plastics.
Apparently in VA you can get away with plates like this....
Old January 20th, 2014, 07:50 AM   #55
Old January 23rd, 2014, 09:21 AM   #56
willi777
Motorcycle(s): Ninja 500, VFR750
They would write you in one second flat for that plate here in NY
willi777 is offline   Reply With Quote
Old January 23rd, 2014, 09:00 PM   #57
beninja
beninja's Avatar
It sounds so good!
beninja is offline   Reply With Quote
Old January 23rd, 2014, 09:21 PM   #58
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
get one of those retractable plates where you pull a lever and they come up completely out of sight. A great investment on any street supersport or superbike.
on a separate note, that exhaust sounds amazing, very nice work that you've done to it so far.
Old January 23rd, 2014, 09:28 PM   #59
TnNinjaGirl
Ms. Personality
Current round of parts ordering:
Driven sprockets. Black. -1 in the front stock back.
Gold chain
Stomp Grips
Vortex adjustable rearsets
And the side panel thingies have been reworked to this...
Thanks for the feedback guys!
Old January 23rd, 2014, 09:30 PM   #60
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
ooh stomp grips and adjustable rearsets at the same time. That should make a huge difference to your cornering confidence on the bike while hanging off.
Old January 24th, 2014, 11:33 AM   #61
TnNinjaGirl
Ms. Personality
And a Pilot Power (3) on a pear tree!!
Old January 27th, 2014, 06:56 AM   #62
TnNinjaGirl
Ms. Personality
636 guy is out in Colorado skiing this week so I haven't done the valves on it yet. Did get some stuff done on the r6 though. Besides the new front tire we did some fairing prep for paint.
Old January 27th, 2014, 07:01 AM   #63
Come tidy up mine when your done please.
Old January 27th, 2014, 08:46 AM   #64
Mmmmm carbon fiber
Old January 27th, 2014, 10:45 AM   #65
TnNinjaGirl
Ms. Personality
Okie dokie. I have very few requirements but if you meet them I'm generally happy to work on anyone's stuff. Or you could ship it down here for the winter. Gives me something to do and therefore keeps the general public safe.
The bike is staying the same color. It's a sparkle laced black much like the 09 black 250. Acura calls it flamingo or something.
The CF wrap is awesome 10x5ft was $60. I wrapped my cell phone in it. Near stuff.
The rest of the parts should be here this week. I haven't told the owner that im going to be the first one to ride it.
Old February 5th, 2014, 09:36 PM   #66
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Originally Posted by TnNinjaGirl View Post
Okie dokie. I have very few requirements but if you meet them I'm generally happy to work on anyone's stuff. I haven't told the owner that im going to be the first one to ride it.
So this project is for a customer?
you are going all the way through this bike . looks great!
nice shop
Old February 5th, 2014, 10:04 PM   #67
TnNinjaGirl
Ms. Personality
@Klondike1020 this is for a friend and thanks for the compliment.
I've had the flu the last week or so and haven't updated. The chain should be fitted and the bike should be ready by Saturday. The fairing bolt kit just came in. All of the fairings painted and finished. All aftermarket parts installed except for the StompGrips.
Old February 5th, 2014, 10:07 PM   #68
TnNinjaGirl
Ms. Personality
Oh and I didn't do the painting on the fairings. I can't do stuff like that. I did help with the prep work but I definitely won't take credit for the paint.
Old February 11th, 2014, 08:51 AM   #69
TnNinjaGirl
Ms. Personality
So we got the bike back together and it looks amazing!
Old February 11th, 2014, 08:57 AM   #70
TnNinjaGirl
Ms. Personality
A couple of hours after that last photo was taken we started making adjustments. David, myself and 2 other friends went to grab some food and David had an accident.
We rounded a corner we've been around literally a few thousand times. He went wide on the corner, down into a ditch and into a tree. He and rag-dolled for about 50' and the bike landed back on top of him. He's relatively alright with a crushed tailbone and a broken L1. The orthopedic surgeons say he doesn't need surgery and fitted him for a back brace. He's been recovering at my house for the last few days and has been in great spirits. He can't wait to ride again, though probably on a 250 to start back off on.
Old February 11th, 2014, 09:07 AM   #71
Sorry to hear about the accident. His injuries sound serious enough, but glad it wasn't worse.
Sad to see all your hard work in a wad like that...
Old February 11th, 2014, 09:29 AM   #72
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Oh man..that's terrible news! Prayers go out to him for speedy recovery, and tell him to keep up the good spirits!!
My replies are intended for street riding only, plz do not provide track only replies.
Visit my new MotoVlog Channel !!
Old February 11th, 2014, 10:28 AM   #73
KawiKid860
KawiKid860's Avatar
Glad he's okay... That's the most important thing. But that suckssssss what happened to the R6, that bike is done.
Old February 11th, 2014, 11:46 AM   #74
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
That is definitely one mangled mess of a bike. keep us posted on recovery.
Oh yeah, tell him he is doing it wrong, you wreck a 250 then get an R6.... not the other way around
Old February 11th, 2014, 12:25 PM   #75
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
OOPS
Xtina is offline   Reply With Quote
Old February 11th, 2014, 02:00 PM   #76
TnNinjaGirl
Ms. Personality
@subxero I told him you thought he was crazy for going to a 250 instead of a 1000 or something like that. He got a kick out of it.
I'm sure it'll be a long recovery process but he's a trooper. I'm more worried about his family driving him nuts at this point.
It is a shame that beautiful bike went down and it was a lot of hard work but obviously we are more concerned about his health at this point.
There wasn't a single salvageable part we could find on the bike. Both of the rims were creased in from hitting the tree and then the edge of the road surface. The forks were both broken in half. The engine was cracked in half and the headers were flattened against the engine block. The swingarm was cracked, the triple tree was broken in half. Both sets of rearsets were gouged out and one side was broken in half. The frame had cracks in it. Actually come to think of it I think the chain ended up being ok. Go figure. There are some parts we still haven't found.
I'm pretty impressed he only came away with a broken back and a couple of very small scratches.
Old February 11th, 2014, 02:12 PM   #77
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
damn, that's a cruel reminder of how fragile bikes can be in a crash.
Luckily he wasn't injured more severely, I send my regards for a full recovery with track days on that 250 when he gets it.
Old February 11th, 2014, 05:42 PM   #78
Best wishes
Old February 11th, 2014, 06:54 PM   #79
Klondike1020
Intrepid Adventurer
Such a bummer. Glad he made it out with non life threatening injuries!
I will pray for a solid recovery. Patience and persistence.
its so sad all that work all blasted away in a fraction of a second.
may the Yamaha rest in peace. ..
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old February 11th, 2014, 07:05 PM   #80
Klondike1020
Intrepid Adventurer
Please tell us he insured it !!!!
lest not the bike died in vain!
winter project almost complete justopelt 1986 - 2007 Ninja 250R Farkles 10 May 5th, 2014 02:00 AM
2012 Ninja 250r SE - Winter Project...Streetfighter Version. SuperAmp13 2008 - 2012 Ninja 250R Farkles 6 April 3rd, 2014 04:34 PM
Winter project; 250 engine enko11 2008 - 2012 Ninja 250R Tech Talk 8 March 29th, 2013 01:43 PM
iPhone/iPod Dashboard - Winter project binlagin 2008 - 2012 Ninja 250R Farkles 47 September 13th, 2010 05:55 AM
My Winter Project maxedpenny 2008 - 2012 Ninja 250R Farkles 51 March 11th, 2009 05:09 PM
