Old January 14th, 2014, 04:11 PM   #1
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
Finally did a fender eliminator!
And must say that I am more then happy of the out come. I wasn't sure if I was going to like it but I did!
Josh_kcco is offline   Reply With Quote
Old January 15th, 2014, 03:39 AM   #2
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
looks good! now on to the next mod..
The Bike | The Truck
Old January 15th, 2014, 05:25 AM   #3
Nice!
Old January 15th, 2014, 10:14 AM   #4
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old January 19th, 2014, 04:36 AM   #5
burnrich
burnrich's Avatar
Motorcycle(s): gpx 250
Do you make that or buy it?
I'm looking at: http://www.aliexpress.com/item/For-K...479187837.html
"Revenge is so very, very sweet"
burnrich is offline   Reply With Quote
Old January 19th, 2014, 10:09 AM   #6
Snake
Snake's Avatar
Great job! Looks very good.
Old January 20th, 2014, 12:41 PM   #7
Josh_kcco
Josh_kcco's Avatar
well im cheap. lol so I made it. its still in progress. as far as figuring out what to use to cover the bottom. but, I just bought 3 L brackets and used those to mound the lights and used the original plate bracket and mounded that to a L bracket. ill post pics later tonight.
Old January 20th, 2014, 12:48 PM   #8
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Keep Calm and Fender Eliminator On
Old January 20th, 2014, 06:53 PM   #9
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Great!!! I don't like rear fenders at all.
Old January 20th, 2014, 06:53 PM   #10
Ish
Ish's Avatar
Motorcycle(s): Ninja 250 2001 KX125 2001
Attachment 27943
more pictures please!!
I need to do mine
Ish is offline   Reply With Quote
Old January 24th, 2014, 10:30 AM   #11
Josh_kcco
Josh_kcco's Avatar
I used this L bracket. i thinks its a 1/4. i just brought a screw from the under side of the seat to match it up.
i punched out the red plastic piece under the tail light.
then used this thin plastic sleeve that came with my vest manual.
I attached it with scotch tape in side the tail light pod. The tape nor plastic has not melted to my surprise. still holding up strong. i just wanted something to keep the dirt out. been about 2 weeks or so. Im not to worried. lol
this is how i put on the L brackets. i kinda bent the bracket in a little to give to tail lights a tilt look.
i used the original plate bracket to attach the plate with the L bracket.
This is how it turned out!
im still going to fill in under the seat. and more then likely move the lights to the pods.
Old January 24th, 2014, 10:30 AM   #12
Josh_kcco
Josh_kcco's Avatar
@Ish
Old January 24th, 2014, 10:47 AM   #13
Josh_kcco
Josh_kcco's Avatar
Old January 24th, 2014, 04:21 PM   #14
Ish
Ish's Avatar
@Josh_kcco
Looks badass.
Do you have a dedicated white light for the license plate?
Because per California Law 24601VC:
License Plate Lamp
24601. Either the taillamp or a separate lamp shall be so constructed and placed as to illuminate with a white light the rear license plate during darkness and render it clearly legible from a distance of 50 feet to the rear. When the rear license plate is illuminated by a lamp other than a required taillamp, the two lamps shall be turned on or off only by the same control switch at all times.
I got a ticket for it a few months ago and thought i should give you a heads up.
Old January 24th, 2014, 09:11 PM   #15
Josh_kcco
Josh_kcco's Avatar
Originally Posted by Ish View Post
@Josh_kcco
Looks badass.
License Plate Lamp
i didnt think about that lol. the light from the tail lamp does a good job keeping it lit.
Old January 24th, 2014, 09:43 PM   #16
TnNinjaGirl
Ms. Personality
Simple, clean, effective.
Old January 25th, 2014, 09:43 AM   #17
Josh_kcco
Josh_kcco's Avatar
thank you!!
@Ish
http://www.amazon.com/White-Super-Br...se+plate+light
i got these and im going to throw the blinkers in pods and put the by the tail light.
Old January 25th, 2014, 12:37 PM   #18
Ish
Ish's Avatar
thank you!!
@Ish
Nice man
My fix it ticket was a pain in the ass. $58 bucks and two court trips
Old January 25th, 2014, 12:40 PM   #19
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
These bikes look good with no rear fender, but how is it in the rain?
Do you get crap all over your back?
Old January 25th, 2014, 12:50 PM   #20
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
have you considered installing your turn signals to the left and right tail lights to make it look a little cleaner? I wanted to do that to mine before the engine blew and never got to.
Old January 25th, 2014, 01:16 PM   #21
Josh_kcco
Josh_kcco's Avatar
I haven't ridden in the rain. I try not to. Even if I think it's going to rain I don't ride. So I wouldn't know.
Old January 25th, 2014, 01:18 PM   #22
Josh_kcco
Josh_kcco's Avatar
Yea I have plans on the future to do so. I liked the smoked ones. I just don't want to risk fixit tickets.
Old January 25th, 2014, 02:06 PM   #23
You can pop out part of that red plastic in the bottom of the taillight, and it functions quite well as a license plate light.
Old January 25th, 2014, 02:20 PM   #24
Roca
Motorcycle(s): 2005 ex250f
I want a fender eliminator but oklahoma laws require fenders to be stock.
Roca is offline   Reply With Quote
Old January 25th, 2014, 09:56 PM   #25
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
ah, I wasn't really worried about that since in MD you aren't required to have turn signals.
what you could always do is show the cop that it works and he won't give you a fixit ticket, lots of people have integrated rear turn signals these days.
I'm also with alex on the easy license plate light. You get to break stuff to become legal (except not really)
Old January 26th, 2014, 11:28 AM   #26
JohnnyBravo
That's a crappy law
Old January 26th, 2014, 11:40 AM   #27
dcj13
Participant
dcj13's Avatar
You can't even add fender extenders? In the BMW world, it's not uncommon to add to the length of the fronts and/or rears (depending on the model) to keep the bike and rider cleaner in the rain.
Old January 27th, 2014, 01:39 PM   #28
Josh_kcco
Josh_kcco's Avatar
I did this. I showed how in the pic I posted.
fender eliminator 102dalz Items Wanted 4 March 11th, 2014 04:18 PM
fender eliminator.... dark_beaverezt 2008 - 2012 Ninja 250R Farkles 9 December 8th, 2013 05:49 PM
The best fender eliminator!! SSANGHA 2008 - 2012 Ninja 250R Farkles 11 October 19th, 2012 07:09 PM
Which Fender Eliminator should I get? tinng321 2008 - 2012 Ninja 250R Farkles 191 August 28th, 2012 10:45 AM
Help! Rear fender replacement (not fender eliminator) mcnuggett General Motorcycling Discussion 7 April 30th, 2012 08:24 PM
