Old March 5th, 2016, 04:33 PM   #1
spent_too_much
spent_too_much's Avatar
94 EX250 build - take 2
I started a build thread about a year ago, and after a little over a month, the project stagnated. I have a renewed drive to complete it, but in a different direction than last year.
Link to previous build...
https://www.ninjette.org/forums/showthread.php?t=228089
Where we stand today...
Old March 5th, 2016, 04:37 PM   #2
spent_too_much
This is the direction that I am headed this time around. What is pictured as red will be blue, and what is black will be a dark grey. I just need to find the exact colors in a spray paint. I'm unsure about the color for the wheels - both matching grey? Both matching blue? Or, one of each?
Old March 5th, 2016, 04:53 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Blue wheels!!
Goin' fast on slow bikes!
Old March 5th, 2016, 04:59 PM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Color match the wheels to the front/rear paint scheme.
My Cafe Racer Build
My intro post
Old March 5th, 2016, 05:18 PM   #5
HoneyBadgerRy
HoneyBadgerRy's Avatar
I vote a third color for the wheels, maybe a light gray.
Old March 6th, 2016, 07:03 AM   #6
spent_too_much
So, like me, 2 votes for blue front wheel, and grey rear? Once I get the bike mostly painted, and reassembled, I'll take photos all 3 ways, and then make a final decision. Thanks for the input!
Old March 6th, 2016, 07:07 AM   #7
spent_too_much
Any suggestions on filling in this void? It is where the right hand side turn signal bolts on. The previous owner made a faux carbon fibre plate, bolted over it. Not a bad job, but not my style.
I have another lower engine fairing ( disfigured due to heat? ) to use for bits of plastic. I thought I might try to solder weld bits together, then apply a coat of epoxy, then sand to shape.
This pic is upside down. It is the main upper fairing.
Old March 6th, 2016, 07:13 AM   #8
spent_too_much
I will also need new tires. I did some research on Ninja 250 faq website, and have decided, based on cost, to go with Pirelli Diablo O.E. Scooter Tire - 130/80 16 rear, and 100/80 16 front. The best price that I can find so far is $150 shipped. Is there a better deal to be found?
I already have Pirelli MT75s on my other 250, and the rear 120/80 16 is too narrow looking.
Old March 6th, 2016, 03:19 PM   #9
HoneyBadgerRy
Let me know how you like the Diablo's compared to the MT75's, I love my MT75's but I was considering the Diablos.
Old March 6th, 2016, 05:22 PM   #10
Ghostt
Ghostt's Avatar
Wheels I went naked on mine, took a sandblaster to them. Purple wasn't gonna cut it.
Tires I've used Kenda K671, and Bridgestone BT45. Both excellent choices the Kendas are inexpensive, excellent wet weather performance, and last a lot of miles perfect for commuting.
Good luck on your second attempt, I'm lucky enough to have the free time needed to do mine, so it only took about month to do the bulk of the work. It's maiden long distance voyage was soon after, 700 miles in a single day.
Work performed so far,
Cut and set sag front fork springs(springs from a Ninja 500 1st generation, rate is .85kg/mm )
Replace fork oil 15wt synthetic
Install new fork seals and dust caps
Replace rear shock(zx600c)
Replace shock oil 15wt synthetic
Change gears +1/-2(15/43)
Rebuild/tune carbs, adjust idle mixture
K&N air filter
New brake pads F&R EBC extreme HH
New Wave front rotor
Used OEM rear rotor
Rebuilt calipers
Modified OEM seat(gel/foam insert, Custom Seat Creation cover solo line cf silver/cf metal, heated kit)
Extra heavy bar ends(3"/23oz)
Heated grips w/ foam covers
Touring windscreen / 7 JuRock 18" 73%tint w/ flip
Shorter bar risers(OEM ZX600c, lower bars about 1 1/2")
Removed paint from rims, bare aluminum
Bridgestone BT-45s w/ Dynabeads
Stainless steel allen head fasteners
Stainless steel braided brake lines
Shorty adjustable levers
HD clutch springs
Charge/voltage LED indicator
LED clock
HID headlight(55w 5k)
Replaced all other bulbs with CREE LEDs
DIY integrated tail light kit w/clear lens
DIY rear fender elimination
DIY licence plate mount(LEDs to illuminate the plate/red LEDs tied into brake light)
Brake light modulator
Maintenance free gel battery
Compact air horn
2007 Complete OEM fairing set silver
Genuine imitation carbon fiber wrap misc parts
Reflective custom graphics ZX-2R silver
Reflective custom graphic NINJA red(taillight lens)
Reflective rim tape silver
Electronic turn indicator relay
Replace front side reflectors with flush mount turn indicators LEDs
Installed rearview camera system
Installed oil cooler
Strip paint off grab handle, bare aluminum alloy.*
Custom reflective graphic "SERENITY" for windscreen silver
Aluminum chain guard from Suzuki Bandit 1200
Swing arm plugs from 08 Ninja 250
Mad Hornets Turn Signal Indicators w/duel color Cree LEDs(amber/white)
FH010 R/R modification
Digital gear indicator
Universal Rear View Side Mirror Rain Board Sun Visor Shade Shield
Kawasaki ZRX1200 lowered foot pegs
OEM upgrade shift spring
All this and full maintenance and rebuild everything else except the motor. I'm sure I'm forget some stuff, but you get the idea
SIDENOTE: is that a CBR500 chain guard I see in your parts photo?
violente et ignorantia
ZX-2R BLOG
Old March 6th, 2016, 06:21 PM   #11
HoneyBadgerRy
K&N air filter
Used OEM rear rotor
Rebuilt calipers
HD clutch springs
LED clock
Compact air horn
Rearview camera system? What...?
Old March 6th, 2016, 06:28 PM   #12
Ghostt
Ghostt's Avatar
Yup, but it's not working at the moment, cheap LCD screen+H2O=DEATH!!
But it was a handy thing to have, no more blind spot.
ZX-2R BLOG
Old March 6th, 2016, 06:31 PM   #13
HoneyBadgerRy
Couldn't you just... Turn around...? My riding style is way different than yours, but I never really felt like there was a blind spot on a motorcycle.
Old March 6th, 2016, 06:41 PM   #14
Ghostt
Ghostt's Avatar
Yea, I could and do, it was one of things to try out, the kit was cheap enough off eBay. And believe it or not it did come in handy Rearview camera install
It's like the Digital gear indicator I added, not a necessary part, but nice to have kind of thing, true FARKLES
ZX-2R BLOG
Old March 6th, 2016, 06:50 PM   #15
Flying
Motorcycle(s): 2010 Ninja 250
After cleaning up the edges a bit, I would attach a piece of paper flush on one side of the hole with spray adhesive or some other glue, fill in the void with ABS cement, and then sand.
Old March 6th, 2016, 06:54 PM   #16
Ghostt
Ghostt's Avatar
Perhaps these might cover it up, and help the looks too
Mad Hornet's flushmount front turn signals /AsianCycle flush-mounts clones
ZX-2R BLOG
Old March 7th, 2016, 05:31 PM   #17
spent_too_much
I like that idea. Would I try to fill it all at once, or in segments? If all at once, I guess it would set as one piece.
Old March 7th, 2016, 05:42 PM   #18
Ghostt
Ghostt's Avatar
http://faq.ninja250.org/wiki/Body_plastics_repair_guide
ZX-2R BLOG
Old March 8th, 2016, 04:23 AM   #19
Flying
All at once, use a spreader. I'm thinking treat it like you would Bondo. I've never done it before, not quite sure how well the patch will fuse to the original plastic.
Old March 8th, 2016, 11:34 AM   #20
spent_too_much
A great guide . Thank you.
Old March 8th, 2016, 11:36 AM   #21
spent_too_much
I guess I could melt a few paper clips in to the original plastice, to have something for the "new" plastic to bond to? I'll just need to try and see where it goes. I plan to try this weekend.
Old March 8th, 2016, 11:42 AM   #22
spent_too_much
I'll go that route if the patching doesn't work. I wanted these for my other bike, 2 years ago, but the were discontinued. Glad to see them return!
Old March 8th, 2016, 11:47 AM   #23
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
IMO, I would use aluminum foil for the backing. The ABS cement won't stick to it.
Old March 8th, 2016, 01:33 PM   #24
Ghostt
Ghostt's Avatar
Another option is keep checking eBay, I got a complete of plastics from an 07' for $200.00 shipped.
If you keep an eye out you might find an upper for cheap, and save time and aggravation.
ZX-2R BLOG
Old March 9th, 2016, 04:45 PM   #25
spent_too_much
Yeah. I thought of that. No good deals right now - either eBay or Craigslist...
Old March 9th, 2016, 04:51 PM   #26
Ghostt
Ghostt's Avatar
Of your not in a hurry, patience is a virtue. It took me about 3 weeks to score my deal, so keep checking often, and don't hesitate to pull the trigger when you find one.
How much you willing to spend ? If you don't mind me asking.
Also don't forget the check the sale section here.
ZX-2R BLOG
Old March 9th, 2016, 06:11 PM   #27
spent_too_much
After searching many home improvement, department, and auto parts stores, I decided to try these these colors - based upon price, availability, and past experience:
Gloss Deep Blue
249114 - 12 oz. Spray
<img src="http://www.rustoleum.com/~/media/DigitalEncyclopedia/Product/RustoleumUSA/CBG/painters-touch-ultra-cover-2x/gloss/249114_0213_PTO_12oz_2xUltraCover_Gloss_DeepBlue.ashx" alt="Ocean Mist"/>
Gloss Dark Gray
249115 - 12 oz. Spray <img src="http://www.rustoleum.com/~/media/DigitalEncyclopedia/Product/RustoleumUSA/CBG/painters-touch-ultra-cover-2x/gloss/249115_0213_PTO_12oz_2xUltraCover_Gloss_DarkGray.ashx" alt="Ocean Mist"/>
Old March 9th, 2016, 06:16 PM   #28
spent_too_much
The best deal that I can find this week is Jet.com $126.28 shipped, with a first time buyer 15% discount. I have decided to go with Pirelli Diablo O.E. Scooter Tire - 130/80 16 rear, and 100/80 16 front. I don't need these until repair and paint are completed, so I might wait and see where prices go over the next few weeks.
Old March 11th, 2016, 05:33 PM   #29
spent_too_much
I painted a couple of random parts today, to see how the paint would actually look... I don't like it
I might need to go with another color scheme.
Old March 11th, 2016, 05:35 PM   #30
HoneyBadgerRy
I hope I like my paint scheme better. I already ordered all the paint.
Old March 12th, 2016, 05:22 AM   #31
Ghostt
Ghostt's Avatar
For jets try PM @ducatiman
ZX-2R BLOG
Old March 12th, 2016, 06:50 PM   #32
spent_too_much
Ghostt, I don't understand your reply?
Old March 12th, 2016, 07:02 PM   #33
spent_too_much
I have been searching for alternate paint colors, within the $4 to $6 per spray paint can range, and am not finding any dark blue and dark grey combination that I like. I am considering an orange & flat black combo, where the orange would replace the red / blue, and flat black, the black / grey...
Items needing paint:
frame
wheels
all plastics
mufflers
gas tank
swing arm
forks
So, I spent a few hours dismantling my donor bike, and doing inventory. The donor bike will be used for engine, wiring harness, cooling system.
Old March 12th, 2016, 07:07 PM   #34
Ghostt
Ghostt's Avatar
Send @ducatiman a PM he carries carburetor parts, be a lot cheaper.
ZX-2R BLOG
Old March 12th, 2016, 07:08 PM   #35
Ghostt
Ghostt's Avatar
I'm partial to orange myself, and look into satin black instead of flat.
ZX-2R BLOG
Old March 12th, 2016, 07:34 PM   #36
Ghostt
Ghostt's Avatar
On another note, when I use rattle can I use Krylon Fusion
http://www.krylon.com/products/fusion-for-plastic/
ZX-2R BLOG
Old March 14th, 2016, 05:58 AM   #37
spent_too_much
Thanks for the input Ghostt!
I have 2 other ideas for the blue / dark grey combo...
Ultra Cover 2x Gloss Spray - Gloss Navy Blue
Rust-Oleum 248930 Automotive High Performance Wheel Spray Paint, Graphite
If that doesn't work, Plastidip!
Plasti Dip - Flex Blue 11oz
PLASTI DIP GUNMETAL GRAY
Except for the gloss navy blue, I cannot find any of the other colors locally. It's too cold to paint today, anyway. I have so many plastic parts to repair and prep, so that is on tap for today.
Old March 14th, 2016, 06:07 AM   #38
spent_too_much
Tires ordered.
Old tires dismounted this weekend. Now to clean and paint.
Old March 17th, 2016, 07:41 PM   #39
spent_too_much
Parts have been arriving. All Balls steering and wheel bearings, tires, brake pads, and wind deflector. Lots more ordered in the last few days. I want to put the bike back together right.
Old March 17th, 2016, 07:45 PM   #40
spent_too_much
I completely disassembled the front caliper for inspection and cleaning. I have ordered a Galfer SS front brake hose, and need to replace the caliper seals.
Two motorcycles to build one Donovan1 1986 - 2007 Ninja 250R Tech Talk 11 March 7th, 2016 09:01 AM
a.kozak's 06 ex250 build (custom front end) a.kozak 1986 - 2007 Ninja 250R Farkles 16 October 22nd, 2014 07:31 AM
90 build up justin_ninja 1986 - 2007 Ninja 250R Tech Talk 4 January 12th, 2013 03:53 PM
Build Off or Rip Off? eddiekay General Motorcycling Discussion 13 December 9th, 2011 08:08 AM
2009 SE Build Betlog Pictures 8 July 21st, 2010 09:59 PM
