Old May 29th, 2013, 05:43 PM   #3801
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Originally Posted by DemonRider View Post
Damn Manufacturer!!! Finally got this darn thing off!!! I hate it when they put stuff too tight!!
That will teach that effer not to mess w/ you ever again for sure
As for me just gathering knowledge till I get,my course done next week.
I live in a dead end and will be bringing her home early to practice this week.
My Cafe Racer Build
My intro post
Old May 29th, 2013, 05:47 PM   #3802
lgk
Heat, PB, WD, Elec. Impact, Air Impact, Tire On, Tire Off, and as long as 5' Breaker Bar, Specific (tight fitting) 32 MM 27 MM 31 MM sockets, And Nothing. It ended up so bad, GRNMSHN (aka: Whomp Stick) and I just "VERY CAREFULLY" cut the nut off with a Drimel, managed to skate away with ZERO damage to the Transmission Output Shaft"
wow, i didn't have to go through that much trouble...
did you bend the lock washer back?
Old May 31st, 2013, 02:15 PM   #3803
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Cleaner & lubed caliper pistons and replace pads, mounted new go fast rubber in the front, bled brakes.
Old May 31st, 2013, 02:31 PM   #3804
cuong-nutz
cuong-nutz's Avatar
Looks good Jason. How much do you weigh? I'm trying to get a feel for what springs to get. Have you messed with how much oil you used in the forks or are you just picking a spring rate first?
HalfFast Racing Team
Old May 31st, 2013, 02:42 PM   #3805
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Give me till the end of this weekend to get all my testing done. I'm only going to need a dozen or so laps to get up to speed on the track so after the first one or two sessions I plan on spending the remainder of the two days messing with the suspension. In a moment ill be swapping at least one of my .80 springs for a .90 and if it still looks soft ill be swapping the 15wt oil for 20wt. I plan on taking everything with me to the track so if I find it to stiff I can swap back.
Old May 31st, 2013, 09:21 PM   #3806
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Went for a ride through Highland Valley Road (on Monday) both ways to purposely get bad gas mileage, yet I managed 63.9 MPG.
wut.
menikmati is offline   Reply With Quote
Old June 1st, 2013, 04:22 PM   #3807
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
I'm crabby as ****. Started my first oil change since I bought the bike. Drain plug and filter came out no prob. Drained the oil, placed in a new filter no prob. Went to put the drain plug with a new crush washer and... It's not tightening. It's turning in the oil like butter.
One of the two previous dumb as **** owners must've over torqued and ruined the thread inside... ****.
Now what do I do? Meh.
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
iplante is offline   Reply With Quote
Old June 1st, 2013, 04:32 PM   #3808
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Helicoil it is your only viable option. If you don't know how to do then find someone who does. Because you really don't want to **** up the helicoil.
Old June 1st, 2013, 04:39 PM   #3809
I went for a great ride with @nautica down to the Steubenville area for some curvy back roads. We did almost 240 miles in about 6 hours (?) including stops. We made some time considering we didn't really know the roads
Old June 1st, 2013, 05:10 PM   #3810
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Rode it at Laguna Seca all day.
Fastest time was a 1:50 and I could do consistent 1:51's
New front springs and emulators feel amazing, I haven't had a single incident of chatter and I ever got the front to tuck in turn 2 with a smooth sensation. I love finally being able out brake riders without fear of losing the front because its on the bumper.
Although my sag in the rear is good he spring has to much preload to get it and the compression dampening is way to soft so its waging. I feel like Im riding a chopper through the turns. I guess I'm going to have to look into that GSXR shock and make some longer dog bones.
One more day to find that 1:49
Old June 1st, 2013, 06:31 PM   #3811
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Meh, oil change. Trying to get back on schedule since I spaced and missed one of scheduled services.
<-- Linky
Old June 1st, 2013, 08:20 PM   #3812
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Added some more PSI to the tires with my new handy dandy tool, the Craftsman 19.2 volt cordless Inflator. Works like a charm.
antiant is offline   Reply With Quote
Old June 1st, 2013, 08:42 PM   #3813
spc2125
Motorcycle(s): 10 Ninja 250
Removed red flames, then broke out the polisher and detailed the bike. Looks mint. Then did the fender eliminator mod and bought an angled piece of metal at home depot and made holes for licence plate. Looks a lot better! I wish we had bigger tires though
Still trying to figure out what color to paint the bike
And have to order a tinted visor for these damn sunny days! Feel unsafe wearing glasses in my helmet.
spc2125 is offline   Reply With Quote
Old June 1st, 2013, 09:08 PM   #3814
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Put miles on it... Road around home, went to bike night, getin ever closer to 600 miles
Old June 1st, 2013, 09:45 PM   #3815
menikmati
Replaced my rear brake pads, was running the stock ones for basically 24k miles. Got some cuts on my fingers from trying to break the caliper mounting bolts loose, but the whole process only involved 4 bolts and went fairly quickly. Went with Vesrah via kurveygirl.com. Fast shipping, great service, and they provide stickers and a sanding block free of charge with your order to prep the rotor for the new brake pad material. Will definitely place another order with them when my fronts need replacing.
Also cleaned and lubed the chain. I rarely clean my chain so I figured I should make it a habit of cleaning every oil change.
Old June 2nd, 2013, 04:25 AM   #3816
Kokosun
Are you sure about that?
Name: That's "Sir" to you!
Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF
The English Lake District
Took her to the English Lake District. Visited a friend there (overnight). 300 miles there, and 300 miles back. But, it was worth it.
I did discover that 100 miles is about the maximum that I can do on the highway before I need a 5-10 minute break to stretch.
Kokosun is offline   Reply With Quote
Old June 2nd, 2013, 06:07 AM   #3817
iplante
iplante's Avatar
Thanks. I'll try that.
Old June 2nd, 2013, 07:03 AM   #3818
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
In the mean time you can wrap the threads with teflon tape snd re-insert....It would be a good idea to safety wire the bolt though.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old June 2nd, 2013, 11:31 AM   #3819
iplante
iplante's Avatar
Yep. My bike guy put some plumber's tape on it and then some black goop.. not sure what it was. I put it back so it would be snug, and then let it sit overnight.
This morning I put a quart of oil in, let it sit for an hour.. no leak. So I filled it, then went for a 10miles ride. So far so good, I'm letting it sit with a paper bag underneath to see if it'll leak. It's of course a temporary fix until I can figure out the Helicoil.
The ride was nice. I was trying out my WC lowered risers for the first time, felt really nice. My new jacket also felt great. The only thing that was kind of uncomfortable were the new A* Stella SP-2 gauntlets. It's probably gonna need some getting used to... Not used to the wrist movement restriction.
Old June 2nd, 2013, 04:12 PM   #3820
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
I went on my first "real" ride (ie: not riding around the neighborhood) on the freeway and I had sooooo much fun! I stalled once, but handled it pretty well. The wind factor was interesting, definitely didn't expect that (need to work on that a little as it knocked me around), so I went into a race tuck, which was way better. There was nothing, but a smile on my face the whole time and I got my first little wave along the way.
Old June 2nd, 2013, 04:15 PM   #3821
DemonRider
Motorcycle(s): Ninja 650R
Yup, sure did :-)
DemonRider is offline   Reply With Quote
Old June 2nd, 2013, 05:02 PM   #3822
Geologic
Motorcycle(s): 1995 Ninja EX250-F
I changed the coolant and oil/oil filter this weekend. Then I ran some seafoam through the vacuum lines.
Geologic is offline   Reply With Quote
Old June 2nd, 2013, 05:54 PM   #3823
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
switched out stock needles for factory pro needles. Will ride it to work tomorrow and see how close my clip height guess was to being correct.
Old June 2nd, 2013, 07:18 PM   #3824
cuong-nutz
cuong-nutz's Avatar
@iplante; time-serts is an alternative.
Lubed the chain, found out that my master link is going bad...
Old June 2nd, 2013, 07:30 PM   #3825
iplante
iplante's Avatar
Thanks, it's good to know I have options
Old June 3rd, 2013, 08:43 AM   #3826
TBC
TBC's Avatar
Motorcycle(s): 2004 Ninja 250F
The bike has been down for the last 3 weeks, so I'm still working on getting it back up. This weekend:
-Fixed the front turn signal wiring
-Shimmed the cush drive
...and bent one of the rear adjuster bolts and the chain adjuster mount when trying to align the rear wheel. Well, she's out of commission for a little while longer. FML. Off to order some new parts.
TBC is offline   Reply With Quote
Old June 3rd, 2013, 08:56 AM   #3827
menikmati
Adjusted and aligned the chain.
One of the oil seals on my forks is leaking, so I used that as a lame excuse to get Race Tech springs and new fork oil to go along with it. Hope to install it in the next couple of weeks.
Old June 4th, 2013, 08:34 PM   #3828
hillbilly86
Motorcycle(s): 1990 Kawasaki Ninja 250R
Laid my bike down in my driveway acting like a retard. Reminder, slick tires, grass, and popping the clutch don't mix too well. Now I have a reason to finish up the little bit of bondo work I need to do and paint my bike correctly
hillbilly86 is offline   Reply With Quote
Old June 4th, 2013, 09:20 PM   #3829
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Maybe you just have a little dirt stuff in them. You may want to give the motion pro seal mate a shot first. http://www.rockymountainatvmc.com/p/...ork+seal+saver
most leaky seals on dirt bikes aren't bad most the time and just need a cleaning to get them to seal again. I'm not sure if the same applies to street bikes but for $5 it worth a shot. You can also cut your own of of a plastic milk carton if your really cheap
Old June 4th, 2013, 09:42 PM   #3830
menikmati
Thanks for the suggestion.
Unfortunately, (woot) I've already bought and received new springs, fork oil, and oil/dust seals from Race Tech today and plan to make it a project for the weekend. I've also ordered that Seal Mate tool based off of your recommendation for the future.
Old June 4th, 2013, 09:53 PM   #3831
NevadaWolf
NevadaWolf's Avatar
Installed Sylvania SilverStar Ultras in my headlight. Got a few long distance rides coming up and need something to ward off the cows and aliens on remote highways at night.
<-- Linky
Old June 5th, 2013, 04:17 AM   #3832
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Pulled the engine out yesterday and split the cases to replace the cam chain, have replaced the trans. bearings while at it. Don't want to replace the pistons and rings until I can get the bores honed. Am now at a point where I can reassemble the engine, or wait and order new big end and main bearing shells. I now know that there are no markings on the crankshaft, conrods and cases, so bearing selection should be easy.
Does anyone know where an oil seal with a 25mm (1 inch) O.D. would go on this engine 1992 Ninja. Seems there has been one hiding inside, found it when I removed the transmission shafts. It is not from the gear selector shaft, that is 22mm. ????
baxtc1 is offline   Reply With Quote
Old June 5th, 2013, 01:22 PM   #3833
kirk595x
kirk595x's Avatar
What I've done the last two days... Went out for a four hour ride to try out my new Diablo Scooter tires. I just replaced my stock Dunlop death tires. I have not been able to really go on a spirited ride cause of this..I've been relegated to just commuting. I went out to Scott Rd. Outside of Folsom. Last time I rode it was on a friends Gixxer 1k a few years ago. It has many hair pin turns and some high speed rollers..pretty much a sport riders roller coaster ride. After a few minutes of feeling out the tires I was able to push it far beyond what I thought I was capable of. I used all but a 1/4 inch of the chicken strips and Scrapped both pegs including my boots. I actually got the front end off the ground on a few of the rollers to my surprise. I am so amazed as to how well this bike turns and how much the Pirellis stick.
I decided to do the zip tie mod, installed a carbon wrap on the triple tree and mounted a clock/temp sensor and a cool Nofear radiator cap sticker I had been saving from my sponsored days. Been an awesome two days!!
Old June 5th, 2013, 01:33 PM   #3834
Pic links are a little strange - they should end with a .jpg, .gif, or similar. Yours look like login links instead.
Old June 5th, 2013, 01:42 PM   #3835
kirk595x
kirk595x's Avatar
Fixed. I'm having issues with photobucket on my phone. I have to copy to clipboard to get it to work right.
Old June 5th, 2013, 02:15 PM   #3836
Hey, I'm digging the gauges. Looks like mine, but with green needles instead of orange!!
Old June 5th, 2013, 03:03 PM   #3837
kirk595x
kirk595x's Avatar
Thanks...I sneaked my daughters nail polish for the needles..lol. I want to change the dash lights to Led..where did you get yours and what part numbers if you don't mind me asking??
Old June 5th, 2013, 04:31 PM   #3838
No problem, they're from superbrightleds.com.
The ones behind the gauges are 194 bulbs, you'll need 4 of them I believe.
The ones behind the dummy lights are 74 bulbs.
info here:
http://faq.ninja250.org/wiki/Replaci..._cluster_bulbs
I believe these are the 194 replacements that I'm using.
I believe these are the 74 replacements that I'm using. The only one I wish I had done differently was the turn signal idiot light, which I should have gotten this one instead as it blinks a little dim in the daylight. The other 3 are bright enough that they wash out the wording on the lens, so remember what the colors mean . For the idiot lights, remember to get the same color LED as the lens it's behind, or the color won't show through as true as it could.
Old June 5th, 2013, 04:43 PM   #3839
kirk595x
kirk595x's Avatar
Thanks man!
Old June 5th, 2013, 07:24 PM   #3840
TBC
TBC's Avatar
Very nice!!! If I could ask, where did you get that 12V socket? I've been looking for something like that.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
