Old March 24th, 2016, 03:33 AM   #1
mr2peak
Motorcycle(s): Hyper 821
The Re-Rebuild...
Ok guys.
Bought this bike back in '14, rode the piss out of it as a naked bike after reviving it from a blown engine from the PO.
Got clip-ons, 70kg spring, '08 rear sets set up for GP shift, quick throttle mod, and lowered the front significantly; and I have a GSXR shock that I'm fitting to a bare frame right now. Got a full jet kit too, K&N filter, and no room for the airbox but I'm hoping to add that back in and hide it behind the (new/fun) fairings. No airbox felt like a handicap. Also got a nice dual-light headlight, but I'm hoping to ditch that for a small LED headlight that I can blend into the bodywork for the "racer" no-headlight look.
Got a new fiberglass tail, and planning on a nice 1970's-80's look fairing. Something bulbous and classic that I can tuck behind, but also small enough for the 250. Maybe A1R250 or TA125... along those lines from Airtech-streamlining. Open to suggestions. Ran naked for a while, need something else. The frame is definitely getting chopped up to make it a nice single-seater. Probably run a different fuel tank as well, something more rounded.
What other mods should I look at? Need new tires, so the newer 250/300 swing arm and tire is looking good, 17" gives decent compounds and those parts are getting pretty cheap. Emulators are in play, but I always felt like the stock forks were flexing badly, so maybe some GSXR forks? Such nice adjustable stock suspension on those bikes, but more power than I'd use responsibly..
Replacing this bike will be ~$1500, so my budget is around 1/2 that. Let's hear some suggestions!
mr2peak is offline   Reply With Quote
Old March 24th, 2016, 03:51 AM   #2
mr2peak
I'll also be reinforcing the frame with some plate in a few places... gusset the arch in the middle for sure. Standing a towering 5'7, the size of this bike makes more sense than stepping up to something larger. Plus, the roads I usually ride make more power meaningless, lean angle is more useful and more fun.
Old March 24th, 2016, 04:19 AM   #3
HoneyBadgerRy
HoneyBadgerRy's Avatar
If you could get your hands on a yoshimura 2:1 exhaust it would help you out. It mounts on the rearset instead of the passenger footpeg mount, and it gives you more lean angle.
Old March 24th, 2016, 06:50 AM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I would add stainless brake and radial master cylinder. I like your plans lets see it done.
My Cafe Racer Build
My intro post
Old March 24th, 2016, 12:59 PM   #5
mr2peak
Forgot to mention, already have that!
Already have a front stainless steel line. Stock brakes apart from that though.
Old April 8th, 2016, 12:45 PM   #6
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
What about the fairing just for shipping?
Old April 8th, 2016, 06:33 PM   #7
mr2peak
What is it off of?
Old April 11th, 2016, 07:11 PM   #8
spooph
spooph's Avatar
MOTM - Oct '15
It's a custom made piece by @RacerX, I'm not sure what it's modeled after. I think e was going for 70's cafe-ish.
Engine Rebuild FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 210 November 2nd, 2013 07:16 PM
Full Rebuild Sirref 1986 - 2007 Ninja 250R Tech Talk 4 August 14th, 2013 12:39 PM
We can rebuild it. Alex Off-Topic 29 April 2nd, 2013 07:21 PM
carb rebuild help deanomyte 1986 - 2007 Ninja 250R Tech Talk 12 November 18th, 2012 07:29 PM
Rebuild after crash Cuongism !%@*#$%!)@#&!%@ I crashed! 16 March 26th, 2011 10:38 PM
