September 11th, 2013, 07:33 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
Rear brake is hard to push back
Hi! Im changing my Rear brake pads now, but i cant push the 2 rear cylinders 100% back, they stick like 1,5mm out and that is enough to block the rear disc after i insert my new brake pads, any tips?
September 11th, 2013, 07:55 AM | #2 |
The pistons may be dirty and need to be cleaned; otherwise you are pushing grime in and through the seals.
How to clean those: http://faq.ninja250.org/wiki/How_do_..._brake_pads%3F
September 11th, 2013, 08:04 AM | #3 |
The Luck Dragon
Join Date: Apr 2012 Motorcycle(s): 2013 Ninja ZX-6R B/W Posts: 738
Yep, just give them a good cleaning and lube job like Motofool mentioned and they should operate a lot better as well as be easier to move! I find that using the flat tool with the rounded end is helpful when pushing them in since it's better to push them in simultaneously since one will push out a bit when you push the other in.
September 11th, 2013, 08:22 AM | #4 |
Also - some folks have reported that off-brand pads on eBay can be too thick to fit between the pistons and the disc when new. Which type did you go with?
September 11th, 2013, 08:23 AM | #5 |
I'm crazy,your excuse is?
I usually crack the bleeder first before compressing, keeps you from pushing back nasty old fluid throught the system. Pumpbrake and fillup on fluid before moving bik. Flush/Bleed system while at it ftw.
[roadracingworld.com] - Marquez Says He Will Push Hard At Motegi To Recover What He L | Ninjette Newsbot | Motorcycling News | 0 | October 22nd, 2013 07:40 AM |
[crash.net - MotoGP] - Dovi 'able to push hard' despite Aragon rain | Ninjette Newsbot | Motorcycling News | 0 | September 28th, 2012 08:10 AM |
[crash.net - WSBK] - Melandri: Feeling comfortable, didn't push very hard | Ninjette Newsbot | Motorcycling News | 0 | January 31st, 2011 03:50 AM |
[crash.net - WSBK] - Toseland forced to ‘push too hard on front' | Ninjette Newsbot | Motorcycling News | 0 | June 28th, 2010 07:40 AM |
[crash.net - WSBK] - Toseland forced to ‘push too hard on brakes' | Ninjette Newsbot | Motorcycling News | 0 | June 28th, 2010 06:50 AM |
