Old September 26th, 2013, 09:27 AM   #4561
Chris, I think your boat trailer conversion is awesome! My dad and I saw that and thought it was great!
Old September 26th, 2013, 06:16 PM   #4562
cuong-nutz
cuong-nutz's Avatar
Installed the forks and bleed the front brake. found out I'm missing a pinch bolt for the top triple as well as another bolt for the brake master bracket. I just need a rear wheel to get the bike moved out of the patio.
HalfFast Racing Team
Old September 28th, 2013, 12:04 AM   #4563
KrazyWalle
KrazyWalle's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model)
Had the dealer adjust the valves. I changed the oil (Amsoil) and aded some Lucas octane booster! Bikes running amazing!
KrazyWalle is offline   Reply With Quote
Old September 28th, 2013, 11:00 AM   #4564
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Today I installed a 15 tooth front sprocket. Why didn't they do that at the factory? It is better in every way.
I also installed my new bar end mirrors and block off plates. MUCH better. The only problem I ran into was, with the threaded bar tubes, and the stock bar ends, the provided cap screws wee not long enough. I couldn't find a local source for the appropriate screws.
I have a bench lathe, so I turned 15mm off the ends of the stock bar ends. this gave a nice flat surface and allowed the use of the 40mm screws that came with he bar ends. Repainted the stock bar ends after machining, and assembled them with Green Locktite. The mirrors have absolutely no vibration and give a far better field of view.
Tomorrow will be my first major ride since I bought the bike two weeks ago. Plan on maybe 500-550 miles. Gonna go do Ozella Trail and environs around Brooksville.
fast1075 is offline   Reply With Quote
Old September 28th, 2013, 11:02 AM   #4565
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Added a little wire under the seat and now have a portable easy bake oven around me (aka Gerbing's jacket).
<-- Linky
Old September 29th, 2013, 09:26 AM   #4566
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Lubed the chain and threw in some Techron that I had sitting around from a sale.
menikmati is offline   Reply With Quote
Old September 29th, 2013, 10:55 AM   #4567
Løckøut
Løckøut's Avatar
Motorcycle(s): 2007 Ninja 250r
Cleaned out the ar box and foam filter.. probably gonna clean the valves if I can run this tank of gas out today.
Løckøut is offline   Reply With Quote
Old September 29th, 2013, 10:58 AM   #4568
mgentz
Board Member
Putting more holes in the airbox.
Just changed the oil....
Old September 29th, 2013, 12:32 PM   #4569
Løckøut
Løckøut's Avatar
Holes in the air box eh? Pros? Cons? Location and count of holes?
Old September 29th, 2013, 12:41 PM   #4570
mtbang
Motorcycle(s): 2011 Ninja 250R SE, 2011 Triumph Street Triple R, 2013 BMW F800GT, 2005 Honda CRF230F
Installed Galfer SS brake lines front and rear. Huge improvement, especially in the rear. I almost think there might have been some air in the rear line since it was new. New brake fluid as well.. Some CRG brake levers on their way for next weekend.
mtbang is offline   Reply With Quote
Old September 29th, 2013, 03:11 PM   #4571
Search "intake lid modification" and look for a thread started by Timon for more info on how to do that to the pregen. The results are nice.
Old September 29th, 2013, 07:07 PM   #4572
mgentz
Board Member
I have an 09. My box (yep...said it) has (2) 3 inch holes, the snorkel removed and now (3) .75" holes in the sides.
Old September 30th, 2013, 09:20 AM   #4573
IF13
WOT WOT WOT
Motorcycle(s): '12 Ninja 250R
Vinegar bath for a week, neutralized with a mix of water, two boxes of baking soda (two pails of that), and dish soap, then heavily sprayed with wd40, hit with a leaf blower, more wd40, hit it with a leaf blower again, blocked off the petcock/ fuel gauge holes, poured a bottle of 2 stroke oil, shook that around
Neighbors probably thought I was crazy seeing me shaking a gas tank around.
Fixing the bracket was the most annoying thing ever. Bracket was bent downward at a sharp angle. I was able to bang it back to shape with a combination of a rubber mallet, a screw driver, and pliers. Paint on the bracket was obviously ****ed up but I hit it with wd40, will spray it later with black and clear.
Before:
After:
Down the line, I'll probably replace the petcock filter just in case there were more rust lodged loose by the gasoline.
May your roads stay clear....
IF13 is offline   Reply With Quote
Old September 30th, 2013, 01:35 PM   #4574
BRad704
Big Dreams, Small Wallet
BRad704's Avatar
Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces)
Listed mine in the for sale section... :|
~BRad
BRad704 is offline   Reply With Quote
Old September 30th, 2013, 06:02 PM   #4575
cuong-nutz
cuong-nutz's Avatar
Dumped the vinegar out of the tank, went ahead and got a another petcock off ebay along with other misc parts to get the motor turned over. sprayed the gas tank with wd40, and capped it off. Got most of the rust out but there's still a bunch up under the topside of the tank. Looks like I'm going to to have to turn the tank upside down and do the treatment again. I hope the gas lock holds up.
@mgentz how's the motor running?
Old September 30th, 2013, 06:22 PM   #4576
mgentz
Board Member
Running better now. Switched to synthetic oil. Now the pressure light goes off immediately. Before it would take a few secs. Shifts better too.
Old September 30th, 2013, 06:23 PM   #4577
mgentz
Board Member
Is all this wotk you are doing for an extra motor? I thought you had yours running?
Old September 30th, 2013, 09:01 PM   #4578
menikmati
Lost the pivot bolt on my shifter during a downshift. Unfortunately I was going about 50MPH and there were no lights so I gave up trying to find the damn thing.
Rode home the last 3 miles in 1st gear.
Looks like I'll have to make a trip to Home Depot to find a suitable replacement.
Old September 30th, 2013, 09:07 PM   #4579
IF13
WOT WOT WOT
Nice, guess I wasn't the only one doing the vinegar bath. From what I saw, it looked pretty clean at the top but that was definitely my concern because I had the tank upright the whole time albeit the thing was filled to the tip of the fill ring.
Took me forever to clean it out after I dumped the vinegar but the bike works. Lined the tank with some 2 stroke oil to prevent flash rust.
Old October 1st, 2013, 03:07 AM   #4580
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Brought it home!
Raven's Rejuvenation
Old October 1st, 2013, 03:10 AM   #4581
anacron
anacron's Avatar
Motorcycle(s): Triumph Street Triple R
Originally Posted by LittleRedNinjette View Post
Brought it home!
Congrats!! Hope you heal up soon so you can break it in!
Looks all new and shiny. Mine looks better though
anacron is offline   Reply With Quote
Old October 1st, 2013, 03:32 AM   #4582
LittleRedNinjette
Hehe, thanks. Its already got 1300 on it but i cant wait to put my own miles one it.
Going to be a long couple months..
Old October 1st, 2013, 06:38 AM   #4583
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Replaced the spark plugs with NGK Iridium. Bike seemed to start a bit easier. Only rode it around the block though so I'll see if overall performance is better later.
Old October 1st, 2013, 07:14 AM   #4584
allanoue
allanoue's Avatar
MOTM - Sep '14
Update your profile!
Old October 1st, 2013, 07:21 AM   #4585
LittleRedNinjette
Working on it!!
Old October 1st, 2013, 08:57 AM   #4586
cuong-nutz
cuong-nutz's Avatar
@mgentz
I'm working on a track bike using the 265cc motor. Piecing a bike together is adding up real fast and I don't have any aftermarket parts yet!
@IF13
The concentrated vinegar is some good stuff! I filled the tank up to the rim of gas fill hole but there's still a good amount of tank untouched. I have large flakes of rust just chilling up there.
Old October 1st, 2013, 12:15 PM   #4587
anacron
anacron's Avatar
What are your opinions on plasti dip?
I was thinking about using it for the windshield and heat shield and end cap on the exhaust.
Old October 1st, 2013, 12:24 PM   #4588
tfkrocks
tfkrocks's Avatar
It looked ok on the windshield but I wasn't a fan of it being opaque and removed it. The little bits of spray that got on the edges and to the other side bothered me too.
Should be alright on the heat shield and end cap if you like the look. I forgot if it was holding up for other people on the end cap, but it holds up on the heat shield.
Old October 1st, 2013, 12:33 PM   #4589
anacron
anacron's Avatar
I'm hoping there's an aspect of functionality as well as looks. My end cap started rusting because of the high humidity, so hopefully a plastic coating would help prevent the rusting.
I really like the way my (black) rear sets clean up the bike so I may do the same with the passenger pegs and use one of those plasti dip gloss coat.
Old October 1st, 2013, 12:35 PM   #4590
tfkrocks
tfkrocks's Avatar
Might help, although it's not supposed to do that. I think there was an issue with some bikes having defective parts causing quick rusting on the exhaust.
I think some people on this forum have mentioned that the plastidip gloss is useless.
Old October 1st, 2013, 01:58 PM   #4591
dooby
Motorcycle(s): '11 250R SE (FI), '14 Daytona 675, '14 Sprint 1050 GT SE
Today I completed the 7,500 mile valve check and adjustment - exhaust valves on cylinder 1 were both too tight, adjusted to 0.05mm thinner HotCams shims to bring them back in the middle of the range which is where the others are.
First time inside a motorbike engine - a little scary but the engine still starts and no nasty noises so I think I got away with it...
FI light has come on though so I may need to retrace my steps and see if I forgot to reconnect a connector. Any of you (mostly carb I guess) folks have any hunches on that? I'm wondering if it's just my battery was off its charger for a couple of days and the low voltage triggered the FI. It was showing up low when I reconnected the charger tonight.
Otherwise I assume there's a way to read some sort of code to give me a clue so I'll have a search...
Cheers, Pete
dooby is offline   Reply With Quote
Old October 1st, 2013, 02:19 PM   #4592
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Put miles on my bike and smiles on myself
Old October 1st, 2013, 03:07 PM   #4593
tfkrocks
tfkrocks's Avatar
So after replacing the spark plugs, the bike seems to run much smoother and the idle is now stable and consistent.
Old October 1st, 2013, 04:48 PM   #4594
mgentz
Board Member
@mgentz
@IF13
I'm sure it seems expensive. Just wait till you get aftermarket stuff.
I checked it over today.
Old October 1st, 2013, 09:07 PM   #4595
IF13
WOT WOT WOT
I have a 15T sitting around. I'm just concerned that I won't be able to launch as fast as when I'm w/ the 14T front.
Regardless, I really want to get some functionality out of first gear. It's such a pain making a left turn while at a red.
Old October 1st, 2013, 09:16 PM   #4596
tfkrocks
tfkrocks's Avatar
It's not that bad. You'll still easily outgun vehicles unless they're trying really hard to beat you lol.
Old October 2nd, 2013, 09:52 PM   #4597
chef
Motorcycle(s): 1965 Honda S90 , 2010 Ninja 250,2012 Vespa LX 150(Yes,a vespa!)
Just picked up the bike from 10 days in the shop.....valve adjust,polished ports,new plugs,shell synthetic oil change,filter,jets (100) new clutch & throttle cables & running sweet although idle is a little high.
Spare parts including labor $260
Next project will be install the TRON wheel lights.
chef is offline   Reply With Quote
Old October 2nd, 2013, 09:59 PM   #4598
chef
Oh yea...& a big arse new Hella horn....almost made me soil myself
Old October 4th, 2013, 05:12 AM   #4599
DCMoney
DCMoney's Avatar
GSXR Shock! With all the other upgrades I'm super excited for this weekends trackday and races!
MCRA.com
Old October 4th, 2013, 05:34 AM   #4600
Not a big deal unless your racing and even then... just rev higher and more clutch fines. IMHO it should be the stock gearing.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
