Go Back   ninjette.org > Marketplace > Motorcycle-related
Old June 30th, 2014, 02:09 PM   #1
abhijitz
Motorcycle(s): Many Two Wheels ..
FS : 08+ Ninja 250 GSXR shock setup
FS : 08+ Ninja 250 GSXR shock setup ... 2 sets.
Spring was not changed. I started racing on this shock and then moved to the RPM. Would really work great with some shortened links ...
Price : 60$ + shipping for the complete set
Please Note :
I have not taken off material of the stock GSXR collar (like others did). I purchased a 250 OEM shock bushing and pressed out the OEM collar. As you see in the left pic the GSXR collar is missing and hence i am including a brand new OEM 250 complete bushing [press out the inner collar and use some silicone to fit in the GSXR hole)
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
Last futzed with by abhijitz; August 4th, 2014 at 07:13 PM. Reason: only 1 set left ...
abhijitz is offline   Reply With Quote
Old June 30th, 2014, 02:25 PM   #2
Nice price for everything!
Old June 30th, 2014, 02:32 PM   #3
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
That is a very nice price, but aint got that dough, though.
The Bike | The Truck
Old June 30th, 2014, 02:59 PM   #4
abhijitz
Huh ... its 50 bucks not 500 ... lol. and you are local to me. But, dunno if its going to fit your bike with 16" rims.
Old June 30th, 2014, 03:09 PM   #5
Singh2jz
Singh2jz's Avatar
i swapped the whole rear for the new-gen. The main problem is need vs. want lol.
Old June 30th, 2014, 09:32 PM   #6
KrazyWalle
KrazyWalle's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model)
Do you have to cut the undertail to make it fit? Also would this shock be to stiff for normal street riding? And from what I've read the front end would have to be addressed as well..
I would be rich by now if I had a dollar for every person that has told me "You need to upgrade, You need a bigger bike, You need more power..."
KrazyWalle is offline   Reply With Quote
Old July 1st, 2014, 07:59 AM   #7
abhijitz
No modifications required. Depends on weight .... If you are under 180 it will be slightly stiffer. Folks have shifted to 03-04 gsxr 1000 spring.
Old July 1st, 2014, 08:05 AM   #8
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
If you don't mind meeting me a bit late I wouldn't mind swinging by after I get done MTBing over at skeggs point(near Alice's Restaurant). We normally get done riding about 8 so I would be in your area till about 9ish.
I'm only 160lbs but I figure with a 20lb Mtb hanging 5' off the rear the shock probably feels like I weigh 200+.
Old July 1st, 2014, 08:07 AM   #9
abhijitz
Ok - but i am at work ... i can only meet after 4 PM today.
Old July 1st, 2014, 08:18 AM   #10
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Sorry, those are 8pm and 9pm. The ride is after work.
Old July 1st, 2014, 02:33 PM   #11
Oxide
Motorcycle(s): ex500 ex250
very interested pm me with shipping quote to 33617
Oxide is offline   Reply With Quote
Old July 1st, 2014, 03:10 PM   #12
abhijitz
I am going to post some pictures later today ... I think i have 2 setups [made 1 for another friend].
Rojo - i will not be available after 9 PM today. Tomorrow is fine.
Old July 1st, 2014, 03:40 PM   #13
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
not entirely true. If it is the same GSXR shock that i am thinking of that everyone else uses you will need to trim just a little bit off the bottom of the stockunder tail to make it fit where the air reservoir meets up with the actual shock part.
Other than that it is GTG
Old July 1st, 2014, 03:56 PM   #14
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
that is a great deal for that set up, switching front springs is not a must, but it does help. the GSXR shock made the bike feel much more stable compared to stock.
TEAM ALFALFA
www.apexassassins.com
Old July 1st, 2014, 04:20 PM   #15
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Yes Wednesday. I'll PM you tomorrow if I'm going to make it out to my ride and then I'll be able to swing by you on my way home.
Old July 1st, 2014, 11:26 PM   #16
abhijitz
Picture uploaded and some notes .. feel free to ask if any questions. Thanks @subxero for correcting the trimming part .
Old July 2nd, 2014, 04:53 PM   #17
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
PM sent
Old July 2nd, 2014, 10:48 PM   #18
abhijitz
Right side shock sold to Rojo .. Left side still available with the Ninja 250 OEM shock collar.
Old July 5th, 2014, 03:26 PM   #19
Oxide
op did u miss this? lmk please
Old July 7th, 2014, 09:00 AM   #20
abhijitz
Sorry .. i was away this long weekend on a hike.
Well - Rojo took the complete setup. I still have the setup on the right.
The setup on the right will need some add-ons
1. The brass bushings/spacers as it came with the setup on the left. [I thought i had those but i cannot find]
2. For this shock the collar from Ninja 250 need to be pressed out and used. Rojo elected to use the GSXR shock collar and hence he took the right shock.
I will take a picture as to which one is left.
Old July 18th, 2014, 07:16 AM   #21
abhijitz
Update : I got the brass washers from ACE. 1 washer is on backorder so i will get it next week. Will take an updated picture. I didnt realise these washers were these expensive
Old August 4th, 2014, 07:14 PM   #22
abhijitz
I took a new job and was slammed at work ... Did not get any spare time at all. Updated the pic in the first thread. Setup is available for sale!
Old August 5th, 2014, 10:35 AM   #23
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
PM sent
Old August 5th, 2014, 02:11 PM   #24
Braden07
Wannabe racer
Motorcycle(s): 2010 ninja 250 race prepped, 2009 Zx6R
PM sent as well.. last night..
Braden07 is offline   Reply With Quote
Old August 12th, 2014, 04:37 PM   #25
abhijitz
bump ... still available.
Old August 13th, 2014, 05:49 AM   #26
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
Is this a bolt in piece?
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old August 13th, 2014, 06:01 PM   #27
abhijitz
Except you would have to press out the OEM Ninja 250 shock collar inner spacer out and press into the GSXR eyelet. (That's why the Ninja 250 shock collar assembly is included).
Even the lower clevis mount needed slight griding on the inside lips to fit the mount.
Old November 4th, 2015, 05:13 PM   #28
abhijitz
bump ..
Old November 20th, 2015, 01:50 PM   #29
daverdfw
Motorcycle(s): 2009 Ninja 250
Curious where you got the copper spacers?
daverdfw is offline   Reply With Quote
Old November 20th, 2015, 01:56 PM   #30
abhijitz
ACE Hardware/Dale. You will not get them at Lowes or HD. maybe Grainger.
btw - I still have 1 complete setup left ... bump ! Use with the 17$ dogbones/links and a different spring, under 100$ a good raised setup.
Old December 18th, 2015, 08:45 PM   #31
Oxide
still have this set up??
Race-prepped 250 GSXR shock swap question Braden07 2008 - 2012 Ninja 250R Tech Talk 7 November 15th, 2014 07:03 AM
I'm new, already installed gsxr shock. Zombarian 1986 - 2007 Ninja 250R Tech Talk 14 June 17th, 2014 01:06 PM
2006 gsxr shock sidekick10121 1986 - 2007 Ninja 250R Tech Talk 2 March 26th, 2014 04:13 PM
gsxr shock alex.s Ninjettes At Speed 1 October 17th, 2013 12:03 PM
FS : GSXR shock mod -- Complete abhijitz Motorcycle-related 7 June 25th, 2013 09:01 PM
