Old October 31st, 2021, 01:03 PM   #161
Hmm, make sure it's 100% acetone and not that nail-polish stuff. Also ALL paint must be removed from ABS, sand, scrape, chop off all paint from surface. Try dropping a fragment of actual paint-free fairing material in there and see if it'll dissolve.
https://www.wikihow.com/Identify-Abs-Plastic
Old October 31st, 2021, 04:58 PM   #162
BonelessSugar
Motorcycle(s): EX250-F x 3, TW200, NPS50
oooohhhh yeah the ABS im trying to melt is all coloured. I tried fairing material before and it mostly dissolved, but still not like it was supposed to. I'll post ABS and acetone and container that it's in in ~5hrs.
BonelessSugar is offline   Reply With Quote
Old November 1st, 2021, 12:58 AM   #163
BonelessSugar
Pics
Old November 1st, 2021, 05:31 AM   #164
Have you done much stirring?
Old November 1st, 2021, 07:03 AM   #165
BonelessSugar
i shake it up twice a day
Old November 7th, 2021, 02:32 PM   #166
BonelessSugar
I'm guessing the acetone I have isn't doing what it's supposed to be doing correctly, because the video danno linked has it melting way faster than my acetone does for either plastic. Went and picked up some 100% nail polish remover because it actually says 100% acetone on the bottle, where my metal container doesn't say 100% anywhere on it, just acetone. Otherwise I'm kind of at a loss. Update tomorrow with results. Working a lot. Forgot to get glycerol/glycerin to firmly check abs.
Edit: not melting. Stripped the colour real well, though. Next is to check if it's actually abs.
Last futzed with by BonelessSugar; November 8th, 2021 at 05:26 PM.
Old February 8th, 2022, 09:29 PM   #167
BonelessSugar
Bought a different ABS. This one dissolves.
Old July 13th, 2022, 01:27 PM   #168
BonelessSugar
Mounted tire on wheel today. I have some white ceramic beads I put in the valve stem. https://www.kawasa***************/th...g-beads.36721/ (ninja300 forum) says 1oz in front and 2oz in rear. I used this video and used this link. Video was helpful, link was not.
Propped wheel up on 2x3's and used a lever to break the bead as much as possible, then started making my way around the wheel.
Bead is broken
Using three levers to try to work the tire off the rim. Pull down on the middle, push in the right, move over the middle, repeat.
Rim is free. Light spot on tire was marked with a pink circle, heavy spot on the wheel was 90 degrees CCW from stem with rotor facing up.
Time for lube. First side was a little difficult, second one was way harder. Accomplished it from here by stepping on two levers as far into the lip that I can, and then going under the tire and slipping a third lever into the rim and pulling it over (not very far from one of the two levers, or else it doesn't work).
Finished result. Pumped to 60psi to hear both pops, then dropped to 30.
Old July 15th, 2022, 11:21 AM   #169
BonelessSugar
reassembled front caliper. trying to bleed the rear one but the bleeder screw is entirely rusted through. ordering a new one, looks to me m7x1, 26mm length.
also picking up allen bolts for the front brake resevoir, looks like 1x4-28 1in.
Old August 11th, 2022, 11:07 PM   #170
@BonelessSugar how's this project coming along?
Old August 12th, 2022, 02:03 PM   #171
BonelessSugar
@DannoXYZ
All the plastics have been repaired, but not painted. Had to add some raw plastic strips in for support on the middle of the lower cowl, it was cracked in half at the bushing spot.
Rear brake is cleaned and bled, leaving wheel off to make it easier to put carbs and airbox in and out.
Got the carb on but couldnt get the airbox on the carb and broke my aluminum fix on the carb, nbd. Last time i removed the metal springs on the airbox and did some finagling to get it on, very annoying to get the springs back on the airbox when its attached to the carb in the bike. Airbox is missing the rubber band on the top to hold it down, 92072-1196 ($30 on ebay, shesh). Did a 4hr trail ride on my other bike today. Going to get the carb and airbox on then start asking for help with starting the bike. Dumping out the old fuel in the tank and replacing it with fresh fuel to try to start the bike (tomorrow morning). I cut the carb fuel line and put an inline filter in it to try to help with the rust in the tank.
I also replaced the footpeg, then drilled and tapped the handlebar, and got new bolts for the front brake reservoir.
I need to still put all the handlebar controls back on, need to either find a video of someone doing it or try to figure it out without help. Also need to add in the coolant reservoir tank you sent me.
I have a camping trip next week so I'll be MIA after tomorrow.
I found out after mounting the tire that apparently you're supposed to replace the valve stems while you're replacing the tire... oops. Ordered new ones and new tires for my other ninjas that I haven't started working on yet.
Old August 12th, 2022, 03:46 PM   #172
hey, coming along, good job!
I never replace valve-stems if they're in good shape. You can wiggle them to see they're cracked where they go through rim. I'll replace if needed with metal ones so i'll have to do it just once.
Old August 22nd, 2022, 02:04 PM   #173
BonelessSugar
I forgot the tank had rust in it so I couldn't use it to try to start the bike. I'm going to go this route again and just do multiple passes of it and completely fill the tank afterwards so I dont get rust. There was quite a lot in there when I looked. If there's any other suggestions lmk, I went through this thread for info again, and everything seemed to be contradictory with experience with people except for that method. Kreem, caswell, etc. Radiator shop is 300mi away. I do see some advocacy for POR here.
Old August 22nd, 2022, 03:04 PM   #174
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
I use a spare coolant reservoir as an auxiliary fuel tank for testing engines and such. The vacuum line connects to the vent port. Chime in if it’s not a good way to do it lol but it’s worked so far. Get something one there to run the engine while you figure out the gas tank situation.
The Bike | The Truck
Old August 30th, 2022, 05:14 AM   #175
BonelessSugar
How should I go about trying to start my bike? Choke? Throttle? Starting fluid?
Old August 30th, 2022, 08:30 AM   #176
thedrewski86
thedrewski86's Avatar
Ideally, you would just do full choke and start, no throttle, then ease off the choke as you can. I aim for about 3,000 rpms as it's warming up for the first minute or two.
Folks here don't like to recommend starting fluid. If I mess with my throttle as the bike is warming up it gets temperamental.
Don't think, look!
Old August 31st, 2022, 06:45 PM   #177
ducatiman
ducatiman's Avatar
Originally Posted by Singh2jz View Post
I use a spare coolant reservoir as an auxiliary fuel tank for testing engines and such. Get something one there to run the engine while you figure out the gas tank situation.
suggest an old, plastic lawn mower tank, el-cheapo, readily available.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
rebuild help! tap_rack_bacon 2008 - 2012 Ninja 250R Tech Talk 1 May 31st, 2017 07:51 PM
Flying's Rebuild Flying 2008 - 2012 Ninja 250R Tech Talk 31 February 1st, 2017 03:57 PM
The Re-Rebuild... mr2peak 1986 - 2007 Ninja 250R Tech Talk 7 April 11th, 2016 07:11 PM
We can rebuild it. Alex Off-Topic 29 April 2nd, 2013 07:21 PM
So I think I am going to rebuild my bike... SpyderGirl 2008 - 2012 Ninja 250R Tech Talk 10 August 27th, 2009 08:49 PM
