Old August 22nd, 2014, 04:12 PM   #1
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
To those with a 250 and a 600/1000, hows the front braking power?
I feel that the front braking power of the 250 is not in a 70/30 90/10 etc ratio that we are lead to believe. I feel like I always need to add rear brake. Does anyone else feel this way on their 250 that has ridden other bikes? I don't think my front brakes are bad they aren't spongy or anything new fluid less than 6 months ago.
Runeknight95 is offline   Reply With Quote
Old August 22nd, 2014, 04:17 PM   #2
For regular street riding, I only use the front brake of my 2007 Ninja 250.
I practice emergency braking regularly, again, only using the front brake.
Old August 22nd, 2014, 04:28 PM   #3
Something may be not right, my braking feel on a 250 is damn near that on a my r6. Both crazy late and hard, enough to raise the rear. Rotor glazed? How is your brake line? Still stock? And no, I aint talkin' bout endos and stunts, this is straight up corner entry braking.
Old August 22nd, 2014, 04:40 PM   #4
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Pre-gen Ninjette brakes are adequate.
My BMW K75 std (750cc old man bike with stock Brembo calipers) has much more responsive, better feeling, better stopping brakes.
KLR250 brakes are not as good as Ninjette brakes.
Old August 22nd, 2014, 05:25 PM   #5
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
my front brake on the street bike if AWFUL!!!!! Stainless lines and Galfer pads on the track bike are better but still not great. At the end of a session there is a decent bit of wasted movement at the lever. Its been bled 900 times, rotor cleaned, pads bedded. There is just a bit of slot between the master and caliper flex. I feels NOTHING like my 6R setup in terms of precision. Maybe you got a Wednesday master and I got a Friday master Chris, or the R6 bits are not as good as the 6Rs (could be cause they are VERY good). Outright stopping power is decent though, as is bite once upgraded.
Old August 22nd, 2014, 05:29 PM   #6
Neil, I am a freak about break feel. You almost have to be in order to have "real" confidence in your stopping power. Let's face it, deep down... your not gunna feel all that good about ridin' beyond your ability to stop.
My pregen brakes really sucked when I first got it, I kept at it until I liked what I felt. I recommend everyone else do the same. Even if you have to replace the whole lot.
My brakes are Friday!
Old August 22nd, 2014, 05:34 PM   #7
sharky nrk
sharky nrk's Avatar
Yeah but its within limits too. I mean the rule book limits you to some degree on what you can do. Stock master and stock caliper, if required, have their limits. I would agree to keep working through rotors and pads as necessary and to stay on top of what you have (clean slide pins, seals, etc.) to make it the best you can.
Its not necessarily applicable to this thread (if they are that bad then there is likely an issue), but if you have a stock master/caliper and it feels as good as a modern 600 setup ...... I wanna know your secret lol
Old August 22nd, 2014, 05:35 PM   #8
I am running stock stuff aside of lines and pads, I feel ya about da rulez.
A rubber hose and a 20oz mt dew bottle.
Old August 22nd, 2014, 05:36 PM   #9
sharky nrk
sharky nrk's Avatar
I had 7UP
Old August 22nd, 2014, 07:12 PM   #10
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
My 99 250 had front Galfer rotor and Galfer semi metallic brake pads.... braked like a champ, no issues. It's not the sharpest, smoothest, most stunningly effective brake but it WILL stop the bike quick. my 03 SV650 brakes even better up front with dual rotors and fresh fluid and stainless steel lines.. almost too much brake! very even, smooth, and effective...
But when I got my SV the brake sucked. It took a lot of pull to get the brake to bite, and when it did, it was in stages. I flushed and replaced the fluid which helped but then a couple weeks later it started feeling crappy again, so I worried there was an air leak in the lines.. but then I put some lube in the brake lever pivot and it made a HUGE difference. Since then I've had awesome brakes, sometimes I brake hard coming up to a stoplight just cause it feels so good to stop so effectively lolol
Try lubing that brake lever... I do use my rear brake just out of habit and mostly lightly when coming to a stop at lights or whatever. definitely use it a lot while turning slowly in parking lots too. It aint there for no reason!
Finesse is offline   Reply With Quote
Old August 22nd, 2014, 07:38 PM   #11
Soujyu
When I had my 250, I put in stainless steel lines both in the front and in the rear at about 5000 miles or so when I was replacing the brake pads. Now going to my liter bike, I feel that the rear brake has about the same amount of stopping power as my 250 with the stainless steel lines. The only big difference is since my literbike is at least 150lbs heavier in wet weight, it's not as effective.
The front brakes, on the other hand, are a monster. Having adjustable levers for feel is a must with bigger bikes.
Old August 22nd, 2014, 08:06 PM   #12
Runeknight95
That may be part of the problem, both my 636 and 1k have aftermarket lines as well lol.
Old August 22nd, 2014, 08:28 PM   #13
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I'm about to attempt this method
let's hope it works out
new pads and finally switching to my SS brake lines on my 300 with new fluid
Old August 22nd, 2014, 08:30 PM   #14
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
will confirm, those front brakes are sick on that lil' 2-fiddy
I have been surprised multiple times on track how well that thing brakes, the r6 felt similar except with more outright stopping power
Old August 22nd, 2014, 08:31 PM   #15
Finesse
ran when parked
Finesse's Avatar
I don't 'feel' the SS brake lines. Supposedly they only matter under very hard braking where rubber would expand or flex a little and absorb some of the braking power. But I don't know too much about it but I don't think it's true that SS brake lines increase braking power under all levels of braking more than rubber lines do, only hard braking.
Old August 22nd, 2014, 08:33 PM   #16
Finesse
ran when parked
Finesse's Avatar
I rode a 2004 ninja 250 recently and the customer was complaining that after he had installed SS brake lines, his bike didn't brake like he expected it to. I think he expected a much more sensitive and sharp feel from the brakes, but they felt fine to me. My 250 felt a little better (as far as I can remember) but that may be because I had put in fresh new brake pads and rotor... I don't know that Galfer is any better than stock, but that rotor sure looks sexy dont it!
Old August 22nd, 2014, 08:37 PM   #17
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
afaik SS brake lines are more about a consistent feel than a sharper one, a sharper feel is all in your setup. To get a proper sharp feel you need good pads/rotors/consistent brake fluid/and a nice tight lever pull (which you achieved by lubing your brake line)
I'd say it's better than stock
Old August 23rd, 2014, 02:15 AM   #18
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
After putting SS lines on the 300 I think they feel much better.
I still have the stock pads and rotor.
My braking confidence has improved with the stopping power. I think SS lines will be on of the first mods I do on any future bikes.
Raven's Rejuvenation
Old August 23rd, 2014, 05:10 AM   #19
I think I need to go wrap some threading in teflon tape, because my brake lever isn't as firm as Chris's. I've got lever envy! The feel is good. The response is good. But it's just not... firm. It also got worse with heavy use. Screams to me water in the fluid or a system that isn't tight.
hmmmmmm.
Old August 23rd, 2014, 05:44 AM   #20
Katie,
The spring effect of the rubber hose does not absorb braking power.
Braking power depends only on the hand force that is applied to the lever and the actual coefficient of friction between the pads and the disc.
Old braking mechanisms were a direct connection, via a steel rod or Bowden cable and secondary levers, to the braking pads.
http://en.wikipedia.org/wiki/Bowden_cable
http://en.wikipedia.org/wiki/Pascal_law
All the modern hydraulic systems do is replacing that steel rod or cable and cumbersome levers, so a straight run between lever/pedal and pads' pivot is not longer needed.
The spring effect of rubber hoses is equivalent to inserting a strong spring in that old steel rod: the initial muscular effort will be used to expand the spring/rubber hose, introducing some spongy or non-linear feedback, but at the end, all the force of your hand/foot is reaching those pads.
Old August 23rd, 2014, 06:43 AM   #21
LittleRedNinjette
hmmmmmm.
We had a hell of a time bleeding the front brake, went through almost two things a fluid and had to use a vacuum bleeder kit when we put the SS lines on.
Old August 23rd, 2014, 07:17 AM   #22
hmmmmmm.
Keep at it man! It's a simple system, so there has to be a simple answer.
Now you know one of the little secrets to how I brake the way I do. I simply have 100% faith and confidence in my braking system. If you liked how it felt in the paddock, you should feel it while out there riding. And don't forget... that is even with those 99.9% spent pads on there.
Old August 23rd, 2014, 08:21 AM   #23
Dude.... Those pads. Hahahaha
Old August 23rd, 2014, 09:15 AM   #24
pic coming....
Old August 23rd, 2014, 09:16 AM   #25
@Runeknight95 - sorry to kinda jack your thread. So how you doin' with yours?
Old August 23rd, 2014, 10:47 AM   #26
MirinNinja
Motorcycle(s): Ninja 300
I jump on my 300 about once a month for track days. I panic every time at the start because it feels like the front brake isn't working at all
You just have to squeeze a shitload harder on the 300 compared to my 600. That said, braking power is still adequate. Only "mods" are brake lines and EBC HH pads. About the same braking power as stock but waaay less brake fade.
MirinNinja is offline   Reply With Quote
Old August 23rd, 2014, 06:15 PM   #27
pic coming....
Old August 23rd, 2014, 08:53 PM   #28
Flying
Those pads.
Old August 23rd, 2014, 09:39 PM   #29
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
those look almost as bad as the first set of pads from my N300
...if only I had taken a picture :/ due to lack of photographic evidence I defer to your efficient use of brake pads
Old August 25th, 2014, 06:06 AM   #30
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
Got all 3.
Understand that the 250 is a single side duel pot.
the CBR600F3 are dual side dual pot.
and the TLR is a dual side 310mm rotor, 6 pot calipers. The 600 and the 1000 will lift the rear with two fingers on the lever.
here is a little trick that may help.
the night before you are going to bleed/replace your brakes...
Tie a bandanna or zip tie around your lever, or put something heavy on the peddle.
the idea here is to place the system under pressure for an extended period of time (over night)
what this does is force any moisture, or small air pockets into the brake fluid...
the next day, when you do the bleed/change... all the "badness" goes out with the used fluid and the system is as clean and moisture free as it can be.
this also works on "soft" brakes even with out a replacement, tie it up, should be good and grabby in the morning.
Prepping the bike for a rear brake change
Rifleman is offline   Reply With Quote
Old August 25th, 2014, 06:41 AM   #31
sharky nrk
sharky nrk's Avatar
Originally Posted by Rifleman View Post
Got all 3.
I do the zip tie wrap periodically on my bikes as well. Sometimes it helps, sometimes not so much. But its easy enough to do and well worth the effort.
Old August 25th, 2014, 06:47 AM   #32
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
I've rode quite a few bikes. In comparison, the stock brakes of the newer 250 are okay; not too weak, not too strong. The bike is fairly small and light, so that helps.
If I have any complaint, it's that the brakes don't have great 'feel', even with fresh fluid and pads. They grab okay, but you just don't get the same feedback as on other brakes. Things feel a bit 'dull'.
Old August 25th, 2014, 07:33 AM   #33
sharky nrk
sharky nrk's Avatar
agreed
Old August 25th, 2014, 08:25 AM   #34
Road Dawg1
Motorcycle(s): 04 Ninja 250
Educate me - why would you skip using the rear brake?
Road Dawg1 is offline   Reply With Quote
Old August 25th, 2014, 09:05 AM   #35
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Because the rear brake doesn't do all that much when you're braking really hard. Even under optimal (i.e. non-emergency) conditions. something like 70% of your braking force comes from the front.
In an emergency braking situation, there is very little (or even no) weight on the rear wheel. A small misjudgment could cause the wheel to lock, which could then lead to a highside once it regains traction.
Careful modulation of the rear brake can avoid a lock and also avoid a highside, but remember this is an emergency scenario. Few riders have the presence of mind to carefully control rear brake pressure in such a situation.
Old August 25th, 2014, 09:27 AM   #36
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Are the 250R brakes Radial or non Radial? I know my ZX6R and S1000RR both have radial brakes. but for some reason i am thinking the 250R does not.
TEAM ALFALFA
www.apexassassins.com
Old August 25th, 2014, 09:39 AM   #37
sharky nrk
sharky nrk's Avatar
not radial mounted calipers on the ninjette
Old August 25th, 2014, 09:40 AM   #38
sharky nrk
sharky nrk's Avatar
also
not radial master either
Old August 25th, 2014, 09:55 AM   #39
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
Katie,
Didn't know this. Makes perfect sense. Thanks!
250rr is offline   Reply With Quote
Old August 25th, 2014, 09:55 AM   #40
250rr
250rr's Avatar
also
Always wondered what 'radial master' meant. Thank you.
Braking power at different speeds? Miles_Prower Riding Skills 3 July 5th, 2012 02:47 PM
Losing braking power randomwalk101 2008 - 2012 Ninja 250R Tech Talk 21 December 25th, 2011 10:11 AM
1000 vs 600 CC Cowboy General Motorcycling Discussion 29 December 31st, 2010 01:16 PM
600 vs 1000 Apex General Motorcycling Discussion 79 June 5th, 2010 06:10 PM
[sportrider - latest stories] - Late Braking: Michelin Power Pure Ninjette Newsbot Motorcycling News 0 May 20th, 2010 06:40 PM
