Old January 7th, 2015, 06:08 PM   #1
Ninja Rob
Ninja Rob's Avatar
Motorcycle(s): 2004 Ninja 250
Winterizing for one day
Tonight will be the one night out of the entire year that temperatures will go down to about 20 degrees fahrenheit.
The temperature drop will only be a one night thing but I would still rather take precautions than have that ONE night keep my bike off the road for days.
I do not have a garage or storage but I have a carport. What kind of antifreeze do you recommend and what other winterizing should I do?
I will also take out the battery and bring it inside with me. I also have a battery charger to maintain the battery.
Thanks!
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle.
Last futzed with by Ninja Rob; January 7th, 2015 at 06:10 PM. Reason: .
Ninja Rob is offline   Reply With Quote
Old January 7th, 2015, 06:23 PM   #2
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
You'll be fine for temps that low unless your antifreeze isn't mixed correctly.
The battery will be fine also unless it is a few years old and getting a bit weak.
i rode all last winter with temps that dropped below 0 with no ill effects other than longer to warm up times and partial choke full time.
Old January 7th, 2015, 06:27 PM   #3
high strung much? Relax, you worry too much.
If it's got the regular old green coolant, you're fine.
Besides, 'winterizing' isn't so much prepping your bike for winter, it's prepping the bike for 4 months of storage, aka, winter.
Old January 7th, 2015, 06:29 PM   #4
Ninja Rob
Ninja Rob's Avatar
Ok so what kind of anti freeze is good? Im going to the auto parts store nearby.
Old January 7th, 2015, 06:31 PM   #5
better sacrifice a goat and drape the warm body over the gas tank to keep it warm for the night.
"and i thought they smelled bad.... on the outside!"
Old January 7th, 2015, 06:31 PM   #6
again, chill.
take off your side panel, find the coolant bottle, and look at it. is it green? (it likely is) if so, you're fine.
Old January 7th, 2015, 06:33 PM   #7
there is one kind of antifreeze. it is called glycol. the stuff you buy at the store is called 50/50 because it is 50% glycol, 50% water. you wont find anything else claiming to be antifreeze that isn't this.
one thing you may find that is NOT antifreeze, are things that are only coolants. these typically promise things like increased cooling efficiency. things like engine ice and water wetter. they are essentially soapy water. this makes the water more thermally conductive which makes it better at transfering heat to and from (makes it a better coolant)
Old January 7th, 2015, 06:33 PM   #8
Fwiw, in the last week, I think the temp has made it UP to 20... once. My car sits outside and guess what? it's completely fine. Go figure.
Your motorcycle is intended to endure the same use and conditions as any car. It will be fine. chill.
Old January 7th, 2015, 06:35 PM   #9
actually most car engines are equipped with freeze plugs. something you don't commonly find on moto engines. these allow the engine to freeze up completely without fracturing the block (extra push from ice simply pushes the freeze plugs out instead of cracking)
edit: this is shown to be bs down below
Old January 7th, 2015, 06:37 PM   #10
The point is he's so hyper about this because he's new and he really has no reason to be. There's a 99.999% chance he has the regular old glycol coolant. Whens the last time you saw that freeze at any regular temperature of a location that sees 20 once a year? ...derp.
It's NOT going to freeze at that temp with regular old green glycol coolant.
Old January 7th, 2015, 06:38 PM   #11
Ninja Rob
Ninja Rob's Avatar
again, chill.
There isn't any, thats why I am buying it.
Old January 7th, 2015, 06:40 PM   #12
Have you been riding it like this? is there any coolant in the system? Open the radiator cap and take a peek.
Regular old glycol based green coolant.
Old January 7th, 2015, 06:47 PM   #13
Ninja Rob
Ninja Rob's Avatar
There isnt. When I bought it, it was empty and I just added water in the radiator.
Old January 7th, 2015, 06:49 PM   #14
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Freeze plugs really aren't meant for that, its for part of the casting process.
Just saying.
My Cafe Racer Build
My intro post
Old January 7th, 2015, 06:50 PM   #15
thanks for the good info winston
http://en.wikipedia.org/wiki/Core_plug for more info
from the link:
Freeze plug myth
A true freeze plug would be an expansion plug located in the side of an engine block that is supposed to protect the block against freeze damage. Water expands when it turns to ice, and if the coolant does not have enough antifreeze protection it can freeze and crack the engine block. The freeze plugs (there are usually several) will supposedly pop out under such conditions, to relieve internal pressure on the block.
As far as can be determined[citation needed] this is an "urban legend". No manufacturer has come forward and stated that the holes in the side of any engine block are there for freeze protection. It is possible and even likely, that freezing water will push a core plug out. If the water doesn't freeze solid it is possible that there will be no damage to the block, but in most cases of a "hard freeze", the water jackets in the block will be cracked as well.
Old January 7th, 2015, 06:51 PM   #16
http://faq.ninja250.org/wiki/How_do_...the_coolant.3F
Drain. fill. purge air.
Old January 7th, 2015, 06:51 PM   #17
crazymadbastard
get any old anti freeze. I use walmart or prestone just dont buy that orange(g12 maybe for vw or
special gm crap)- not compatible with normal green stuff.
My Cafe Racer Build
My intro post
Old January 7th, 2015, 09:42 PM   #18
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
you don't need to do anything.
Instagram: @katie.baden
Finesse is offline   Reply With Quote
Old January 8th, 2015, 07:55 AM   #19
Oh...that changes things...
Absolutely do not use water only in the cooling system. As everyone has said - buy pre-diluted antifreeze and fill the system after completely draining it (overflow tank too).
Antifreeze/coolant does more than just keep the water from freezing. It has corrosion inhibitors, lubricants, and also increase the boiling point - an engine needs it.
Anytime you add water to the cooling system it should not be regular tap water. Tap water contains minerals that will build-up inside the system. Distilled, Deionized, over even filtered drinking water are better choices.
It would take more than 32F to freeze the water solid, but get it out of there ASAP just to be safe.
The battery isn't a problem unless it's weak to start with.
Keep the tank almost full. Use ethanol-free 87 or the lowest octane you can get without ethanol.
Old January 8th, 2015, 06:24 PM   #20
crazymadbastard
Thanks!
omg! what DID you do??
My Cafe Racer Build
My intro post
Old January 8th, 2015, 07:26 PM   #21
Ninja Rob
Ninja Rob's Avatar
Thank you for those tips. It didnt freeze last night or hit anywhere near 20 degrees. I havnt done anything yet because it was dark and cold outside so it will have to wait for my day off. I also bought the wrong anti freeze and have been sleep deprived lately so I dont wanna work on it until I have a fresh, well rested mind. Should be in the 40`s tomorrow, if Im not on call for work, Im gonna get it fixed.
Old January 8th, 2015, 07:35 PM   #22
Ghostt
Ghostt's Avatar
All else fails, park it in the living room
violente et ignorantia
ZX-2R BLOG
Old January 8th, 2015, 07:55 PM   #23
Ninja Rob
Ninja Rob's Avatar
I live on the second floor.
Old January 8th, 2015, 07:58 PM   #24
Ghostt
Ghostt's Avatar
Well make friend on the first floor, hope that she's cute
File Type: jpg 10689632_10205428948706069_5627002859154355908_n.jpg (47.8 KB, 7 views)
ZX-2R BLOG
Old January 8th, 2015, 11:50 PM   #25
what do you mean the wrong antifreeze?
Old January 9th, 2015, 08:14 AM   #26
crazymadbastard
i bet he got rv antifreeze- cheap and its for the toilets
My Cafe Racer Build
My intro post
Old January 9th, 2015, 08:42 AM   #27
Ninja Rob
Ninja Rob's Avatar
Please excuse my newbieness,
This is what I got
http://www.peakauto.com/products/ant...g-life-50-50-/
http://www.oreillyauto.com/site/c/de...ord=antifreeze
The guy at the store didn't know which one I needed so he called his friend who works at a motorcycle shop and they said they use Peak. I recall somewhere in this thread someone said that its green and this one is yellow. I still have the receipt and have not opened the bottle yet so I can exchange it if I need to. Motorcycles are not a big thing where I live so motorcycle knowledge is scarce and usually not very reliable. The few mechanics that we have are "quick fix mechanics".
Once again,
Old January 9th, 2015, 09:17 AM   #28
allanoue
allanoue's Avatar
MOTM - Sep '14
that is fine.
you are good go
get that water out ASAP
Old January 9th, 2015, 09:28 AM   #29
Ninja Rob
Ninja Rob's Avatar
Originally Posted by allanoue View Post
that is fine.
you are good go
Do I got to flush it out with distilled water or should I be fine just by draining it out?
Old January 9th, 2015, 09:31 AM   #30
Ninja Rob
Ninja Rob's Avatar
Look what I found.
https://www.youtube.com/watch?v=j4i9ajWOk14
Old January 9th, 2015, 10:28 AM   #31
so not to back up a few steps but i dont believe he ever said he drained the radiator... he said the overflow was empty...
was the radiator empty? or just the overflow tank? theres a big difference
Old January 9th, 2015, 11:33 AM   #32
Ninja Rob
Ninja Rob's Avatar
Both were empty. Both radiator and coolent reservoir. I only added water to the radiator.
Old January 9th, 2015, 11:39 AM   #33
don't do that
Old January 9th, 2015, 12:03 PM   #34
Ninja Rob
Ninja Rob's Avatar
don't do that
I did that a few weeks ago, Im gonna drain all the water out and then add that anti freeze that I bought.
Old January 9th, 2015, 12:06 PM   #35
remember to bleed the air out
Old January 9th, 2015, 12:32 PM   #36
I would follow these instructions if you are not familiar with draining, filling, and bleeding the cooling system - http://faq.ninja250.org/wiki/How_do_...ling_system%3F
Old January 9th, 2015, 12:37 PM   #37
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Lol, OP is worrying about 20 degrees... hahahahaha....
Be careful. Remember you are
invisible
Old January 9th, 2015, 12:54 PM   #38
20 degrees is under freezing.
with no antifreeze, this is potentially damaging.
so in response to your haha; no. you're simply wrong in your jaded sense of what is cold enough to cause damage.
Old January 9th, 2015, 01:27 PM   #39
allanoue
allanoue's Avatar
MOTM - Sep '14
don't do that
you reminded me of Ned the Head in Groundhog Day
"Watch out for that first step, Is's a doozy"
Old January 9th, 2015, 01:56 PM   #40
dang. now i want to watch groundhog day.
Winterizing for 5 weeks? mrudich General Motorcycling Discussion 4 June 13th, 2014 05:13 AM
winterizing 250's scorch General Motorcycling Discussion 10 May 13th, 2014 11:34 AM
Winterizing your 250R? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 206 April 27th, 2014 06:55 PM
Winterizing... emilyLOVESlime 1986 - 2007 Ninja 250R Tech Talk 18 November 2nd, 2009 10:57 PM
Winterizing your Ninjette Sailariel 2008 - 2012 Ninja 250R Tech Talk 37 December 20th, 2008 08:05 PM
