Old November 21st, 2014, 11:07 PM   #1
zenmike
zenmike's Avatar
Motorcycle(s): 2012 Triumph Street Triple R, 2008 Kawasaki Ninja 250R
First time long time!
What up ya'll.
Been reading and following this forum for a while, this is my first post.
Just came home today with an 08 ninja 250. I bought it from the original owner, came with oem tool kit, cover, battery tender(its also wired for one), two keys and an owners manual.
I feel it was a nice find, owned by a nice young lady, although she admitted she wasnt mechanically inclined. It has 518 miles on the odo. My first question was regarding its storage. She said her and her fiance would fire it up and let it run every so often, applying slow throttle turns(this concerns me most since that fuel tank was probably so old. It split time between being garaged and outside under a cover, which cant be good considering humidity building up under there over time(years) right?
Bike fires up fine(with full choke), and after warmed up idles at ~1k with choke off. Any normal twist of the throttle will immediately shut her off. Take offs requires working the clutch lever slow with about 4-5000 revs. From a roll in 1st, letting the rpms drop to idle, wot boggs and stutters up until 5k, then the bike pushes me back into my seat with a crazy (not that fun) power surge.
I immediately put some seafoam in the tank, about 1.5 oz. Nothing has changed yet (after riding 20 miles)
So it seems typical carb cleanup/shimming?
Tomorrow I will be doing an oil change, chain clean and lube, etc... but I feel a carb cleanup is needed
Anyway here are some pics
www.djmikesage.com
zenmike is offline   Reply With Quote
Old November 21st, 2014, 11:20 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Hello Michael and
Hopefully someone soon will pop in with some help. The magic box scares me so I can't offer up any advice.
<-- Linky
Old November 21st, 2014, 11:23 PM   #3
zenmike
zenmike's Avatar
Hey Wolf. Thanks, glad to be here brotha!
www.djmikesage.com
Old November 21st, 2014, 11:28 PM   #4
NevadaWolf
NevadaWolf's Avatar
518 mils on an '08 is pretty sweet, not even broken in yet (right, 1000 mile break in?)
Looks really clean on the outside. If its been sitting that long going through So Cal summers, I'd take a close look at the tires and see if they've started cracking or whatnot. Can't recall if the first newgens had the IRC or Dunlop (?) as the stock rubber.
<-- Linky
Old November 21st, 2014, 11:35 PM   #5
The '08s had either Dunlop GT-501's or the Bridgestone BT-45's. Looking at the tread on the front tire, I'm pretty sure those are the Dunlops. Wolf is right, those tires are now 6 or 7 years old, and performing at a somewhat lower level than they would when they were new.
Old November 21st, 2014, 11:37 PM   #6
zenmike
zenmike's Avatar
I've used motoman method for break in in the past which takes about 20 miles or so. But with 518 she's practically brand new. That's about two tanks in 6 years though
It has some Dunlop arrowmax's gt501 I believe
I checked them over and they look good as far as I can tell, you guys suggest replacement?
www.djmikesage.com
Old November 22nd, 2014, 01:08 AM   #7
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
#filter
"That's what" -she
Roark is offline   Reply With Quote
Old November 22nd, 2014, 01:16 AM   #8
zenmike
zenmike's Avatar
Originally Posted by Roark View Post
#filter
What do you mean?
www.djmikesage.com
Old November 22nd, 2014, 01:37 AM   #9
Roark
Roark's Avatar
Originally Posted by zenmike View Post
What do you mean?
Your pics! Looks like a filter on them! No big deal.. I use that one myself
"That's what" -she
Old November 22nd, 2014, 08:45 AM   #10
Welcome Michael!
Great find!
Old November 22nd, 2014, 10:08 AM   #11
zenmike
zenmike's Avatar
Thanks Chris...I hope to one day obtain that cornering position you have going there!
www.djmikesage.com
Old November 24th, 2014, 07:02 AM   #12
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
How is the clean up process going on the bike? Sounds like you need new fuel in the bike and a carb cleaning. I would drain what is left in the tank and fill it with brand new premium and some fuel system treatment run that tank and then see how things go there. If that doesn't work pull the air box and clean the carbs that route. Also adjust the idle screw and have it set at about 1500-2000 rpm.
TEAM ALFALFA
www.apexassassins.com
Old November 24th, 2014, 08:23 AM   #13
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
3 things
1. Make sure the tires aren't stock, if they are replace them immediately. They most likely are. Safety first! Tires aren't really meant to last 5+ years.
-I recommend the pirelli diablo rosso II, michelin street radial, or bridgestone bt-45 tires. The pirelli's will give the best dry grip, michelins the best life and wet grip and the bridgestones are a great all around value as well with a very long tire life.
2. Change the oil, it hasn't reached it's "break in service" yet and after 5 years it desperately needs new oil and a new filter.
3. Drain and replace the fuel and clean the carbs.
and then you're good to go!
Old November 24th, 2014, 08:26 AM   #14
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I've ridden with him at the track multiple times, he's a great coach. I want his mentality towards riding just as much as his ability to ride
Stick with the 250, get some pirelli DRII tires on there and head to the track to learn how to ride faster safer and you'll be able to do it within a few seasons. Especially in cali, you have the best area to learn how to ride fast in the US with tons of good tracks and fast riders around.
Old November 24th, 2014, 11:58 AM   #15
zenmike
zenmike's Avatar
Yesterday I pulled the fairings off, I left town and won't be back until Friday so I plan on pulling the tank and flushing the fuel on Friday, that'll be my first step, the goal there is to see if the new fuel and fuel treatment would clear the carbs for me right?
I'd really like to pull the carbs and clean the float bowls and jets and what not, I'd like that peace of mind and the bike would like it too.
Just to recap:
1. Remove gas tank/replace fuel
2. Remove air box to remove carbs/clean carbs
3. Remove snorkel
4. Fire her up/adjust idle
What about all relevant hoses, should I lightly run some compressed air through them once everything is pulled apart?
www.djmikesage.com
Old November 24th, 2014, 01:40 PM   #16
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
hello
250rr is offline   Reply With Quote
Old November 24th, 2014, 04:16 PM   #17
Snake
Snake's Avatar
Hello and welcome.
Old November 25th, 2014, 10:49 PM   #18
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old November 26th, 2014, 01:24 PM   #19
zenmike
zenmike's Avatar
Thanks guys glad to be here!
www.djmikesage.com
Old November 27th, 2014, 06:53 PM   #20
catseye
catseye's Avatar
Motorcycle(s): '76 KZ900, '99 Ninja 250,
welcome. I sure wish I could come across a specimen with 500 miles on it. I'd love to have something for once that hadn't been ****ed with...
All I remember is dirt, sky, dirt....ambulance.
catseye is offline   Reply With Quote
Old November 28th, 2014, 09:44 AM   #21
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Welcome Michael!
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old November 28th, 2014, 09:20 PM   #22
zenmike
zenmike's Avatar
I took off some things today, she does look like a bike with 500 miles
Tomorrow I'll be pulling the tank and starting step 1 in fixing the under 5k lag problem. I almost know for sure that the problem is because of old oxidized fuel, so I hope a fuel flush and some seafoam Will solve the issue.
The rubber holding down the emissions canister has also rotted, thinking that is a sign of possible humidity gatherage under the bike cover when parked outside for so many years. Lastly, check the picture of the exhaust mount, some brown/orange residue coming out of there, is that normal?
www.djmikesage.com
Old November 30th, 2014, 06:05 AM   #23
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Long time no see! CThunder-blue Off-Topic 16 September 24th, 2014 07:18 PM
[RoadRUNNER] - Time to Ride: How Long is Long Enough? Ninjette Newsbot Motorcycling News 0 March 18th, 2014 01:50 PM
Long time and lots of changes dougherty 2008 - 2012 Ninja 250R Farkles 4 May 28th, 2012 09:22 PM
Hello from a long time lurker seis gunnar New Members 12 January 12th, 2011 10:15 PM
Long time lurker first time poster k1prototype New Members 10 October 2nd, 2009 11:18 AM
