Old April 17th, 2013, 08:18 AM   #1
Silly
Silly's Avatar
Motorcycle(s): 2021 Ninja 400 Passion Red; 2019 Yamaha R3; 2017 Indian Scout; 2016 HD Freewheeler
I need a Power Commander MAP, R-77 full system
Hi, I just installed a Yoshi CF full system exhaust on my 2013 Ninja 300. I could only get a two brothers CF full system map. I'm using it now, but the bike's exhaust backfire/pops every now and then on decel. It seems to pop more at above 3500 rpm with the throttle closed and then slightly opened. That is when I can hear it pop. It's not bad, but I think it's because I'm not running the MAP.
Let me know if anyone has that MAP or has one that will work.
Silly is offline   Reply With Quote
Old April 17th, 2013, 08:22 AM   #2
Did you remove the Kleen-air system when you installed a full exhaust? If not, that's the source of your popping.
Old April 17th, 2013, 10:18 AM   #3
Silly
Silly's Avatar
Oh, no I did not. The instructions made no mention about that. I didn't even know the bike had one. I will look into it.
Thank you
Old April 17th, 2013, 10:25 AM   #4
Good catch chone!
Old April 17th, 2013, 01:03 PM   #5
Not sure how similar it is to the Kleen system on the 250R, but this should give you some idea of what to look for when taking everything off:
http://www.ninjette.org/forums/showthread.php?t=9948
Old April 17th, 2013, 01:41 PM   #6
Silly
Silly's Avatar
Thank you, I will look at this today. I guess the fuel tank has to come off again.
Power commander 5 joecool 2013 - 2017 Ninja 300 Tech Talk 27 October 17th, 2014 05:03 AM
power commander? bandit_fosky 2008 - 2012 Ninja 250R Tech Talk 14 January 16th, 2013 02:05 PM
Dynojet Power commander 5 FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 3 September 23rd, 2012 03:23 PM
Power Commander - Full Yoshimura - Dyno results Gregular 2008 - 2012 Ninja 250R Tech Talk 15 July 12th, 2011 08:32 AM
Power Commander Map Needed tuktukracer 2008 - 2012 Ninja 250R Tech Talk 8 April 28th, 2011 01:20 PM
