Old April 1st, 2011, 10:29 AM   #1
ferret09
Motorcycle(s): None yet
Stock mixture screw settings
I need to double check if the stock settings for the idle mixture screws is really 2.5 turns out for the left and 1.75 turns for the right carburetor. Just so no one is confused to which screws I'm talk about it's these...
ferret09 is offline   Reply With Quote
Old April 1st, 2011, 11:43 AM   #2
http://www.ninjette.org/forums/showthread.php?t=9467
Old September 12th, 2023, 03:46 PM   #3
truetaylorking93
Motorcycle(s): 08 ninja 250r
Which one is air. Which one is fuel
truetaylorking93 is offline   Reply With Quote
Old September 12th, 2023, 03:51 PM   #4
Each carburetor has one idle mixture screw. They are fuel adjustments, so screwing one in will make that cylinder leaner.
Exactly where you initially set them isn't critical, since it's important to do the final adjustment by warming up the engine fully and adjusting each screw for the highest idle speed. It's usually best to err on the side of a little rich.
Here's some more informaiton:
https://faq.ninja250.org/wiki/How_do...dle_mixture%3F
Old September 12th, 2023, 04:30 PM   #5
truetaylorking93
I have found that they only can be adjusted for up to 5,000 rpms. What do you adjust for problems higher then that. I'm having big issues at 8500 rpms and everyone said adjusting those screws wouldn't do anything. The bike factory specs are set 2.5 left and 1.75 right. If they are both fuel why are they set different???
Old September 12th, 2023, 04:42 PM   #6
ducatiman
ducatiman's Avatar
the factory idle screw settings are (primarily) based on meeting EPA specs. Higher RPM tuning involves needle height settings and main jets....depending on your specific running needs.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old September 12th, 2023, 11:00 PM   #7
Uneven pilot-screw settings because bike doesn't have perfectly even firing order. Exhaust scavenging effects for each is different. Also left & right needles are different. If you've taken them out, make sure they go back in correct side. Make sure your float-levels are set correctly with final external wet-test as confirmation.
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
Mixture screw turns. simook 2008 - 2012 Ninja 250R Tech Talk 7 October 13th, 2013 07:26 PM
Idle Mixture Screw Problem gogoKawi 2008 - 2012 Ninja 250R Tech Talk 6 April 23rd, 2013 07:07 PM
Adjusting the Idle Mixture Screw conrya5 2008 - 2012 Ninja 250R Tech Talk 22 March 18th, 2013 05:03 AM
Idle Mixture adjustment screw Q indr 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2010 09:36 PM
