June 22nd, 2015, 05:38 PM | #1 |
Join Date: Apr 2015 Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke" Posts: 129
Is my clevis shot?
I was just now on my way home from work when my clutch cable snapped. I pulled over to find this:
It comes completely out. Is my clutch screwed? What am I seeing here? |
June 22nd, 2015, 05:48 PM | #2 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Ah yes, that...
CVMA #531 |
June 22nd, 2015, 05:58 PM | #3 |
June 22nd, 2015, 06:01 PM | #4 |
Oh hey your picture works now!
Is it broken or did the cable just pop out? Looks like you just rotate it around and put the cable back in.... undo it from the clutch lever to get some more slack. if it broke... replacing those things can be a bitch!
CVMA #531 |
June 22nd, 2015, 06:20 PM | #5 |
Practically anyone would know better than I would. |
June 22nd, 2015, 06:51 PM | #6 |
Oh THAT comes completely out! ****! You're boned bro!
Also you're about to become a mechanic! You will need a new gasket for the clutch cover. Before you remove that cover remember to dump all of your oil. As far as exactly how to replace that - I have no idea! But I remember it being somewhat self explanatory?
CVMA #531 |
June 22nd, 2015, 07:10 PM | #7 | |
June 22nd, 2015, 07:24 PM | #8 |
Nope. All serious. The gaskets are one use gaskets. It would help to have some gasket sealant too.
See how your oil sight glass is part of that clutch cover? There's a lot of oil behind that cover, so you'll need to dump it before you go for it. Why are you doing this instead of taking it to a mechanic? This is at least 1-2 hours of mechanics labor. So figure $200+ to fix. Fix it yourself!
CVMA #531 |
June 22nd, 2015, 07:37 PM | #9 | |
June 22nd, 2015, 10:04 PM | #10 | |
Replace the cable and re-insert the lever into the cavity all the way and then rotate it clockwise. That little notch at the lower end grabs the plunge that pulls the clutch assembly out when you press the hand lever.
June 22nd, 2015, 10:06 PM | #11 |
Now that i've read motofool's comment and looked at the first picture of the part again it doesn't look sheared (broken). The lines are too clean.
He's almost always right and very knowledgeable. Listen to him!
CVMA #531 |
June 23rd, 2015, 06:51 AM | #12 | |
June 23rd, 2015, 08:08 AM | #13 |
dirty boy
MOTM - Apr '14
It is not to common for clutch cables to just snap with out some underlying cause. Make sure when you install your new cable that you check and make sure everything is set correctly. Make sure you have slight play/slack in the lever it should not be completely tight.
How many miles on the bike? ever down?
June 23rd, 2015, 08:48 AM | #14 | |
June 23rd, 2015, 10:21 PM | #15 | |
Read this, please: https://www.ninjette.org/forums/showthread.php?t=201063 Clutch cables can last forever. The problem starts when there is no proper lubrication at the heads of the cable (the little cylinder that connects to the upper lever) and the normal movement introduces bending of the cable due to friction. Cables cannot stand cyclic bending and soon snap.
June 24th, 2015, 08:09 AM | #16 |
I'm crazy,your excuse is?
talk to the shop you JUST bought it from. They will make it right.
June 24th, 2015, 10:11 AM | #17 |
@Trailerboy531 ... what the hell are you talking about bro?
June 24th, 2015, 10:20 AM | #18 |
I have They asked me to bring the bike in and I let them know that my insurance won't cover a tow that far (they're a good 40 miles away), but that I'm competent enough to lube and install the cable myself if they'd be willing to give me a new one, which they were okay with. They let me know that once it's installed they'd like me to bring it in when it's convenient just to give it a look over and make sure nothing else is going on (which I doubt there is)
Awesome shot!! | Apex | Off-Topic | 11 | May 4th, 2014 07:09 AM |
[RoadRUNNER] - Hot Shot | Ninjette Newsbot | Motorcycling News | 0 | May 14th, 2013 06:20 AM |
Rolling shot. | aloh | Pictures | 21 | May 29th, 2011 03:19 PM |
Is my chain shot? | bob706 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 5th, 2011 04:12 AM |
One in a million shot..... | Flashmonkey | General Motorcycling Discussion | 19 | September 26th, 2010 10:57 AM |
