Old September 7th, 2014, 10:58 AM   #1
Baron
Urban Legend
Baron's Avatar
Motorcycle(s): 09 Ninja 250R SE - Circe
Front brake bleeding problem
Every bloody time I do something that I haven't done before, I screw up somewhere. This time it's with the front brakes. I bled my rear brakes yesterday and they are fine. However the front ones not so much.
So quick summary, I was bleeding my front brakes using the one man bleeding system/more or less just a jar.
I was talking on the phone the same time so I didn't see when the front reservoir emptied itself. Needless to say that WHEN I did notice it I put in more fluid but after that point, it started to go downhill. I got all old fluid out of my system and from the looks of it all the air too however, no matter how much I pump and bleed the brakes, they won't catch at all.
If I continue to bleed the brakes, that's just pumping out clear brake fluid. Pumping the brakes isn't helping at this time because it's being rather stubborn and I could seemingly do it for days without it actually working......
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up."
-Baron
Baron is offline   Reply With Quote
Old September 7th, 2014, 11:13 AM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Tap the lines and caliper, you still might have air in the system. Also check the caliper to make sure it is functioning correctly as well as the cable.
Old September 7th, 2014, 11:18 AM   #3
Put the clear tube into a 20oz pop bottle (lower than the caliper), pump until the fluid is above the line in the bottle, then you can start bleeding. Fill the res and keep pumping while keeping the res full until there is no air bubbles. If needed, zip tie the lever overnight and repeat in the AM. Your brakes will be SOLID!
Old September 7th, 2014, 11:40 AM   #4
Baron
Urban Legend
Baron's Avatar
Thanks . I'll try that in a bit.
I am a bit unclear on the procedure,
1. I get a soda bottle
2. Place it on the ground[lower than the caliper]
Here's where I am unclear. Do I keep the nut open and then pump the fluid in it???
-Baron
Old September 7th, 2014, 11:44 AM   #5
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Here's where I am unclear. Do I keep the screw around the nut open and then pump the fluid in it???
place the bottle lower that the caliper, open nut, pump...
Old September 7th, 2014, 11:48 AM   #6
Baron
Urban Legend
Baron's Avatar
cool. I update it in a bit.
-Baron
Old September 7th, 2014, 11:51 AM   #7
Brother Michigan
Motorcycle(s): 2013 Ninja 300
The zip-tie trick is a winner. There's likely just some air stuck up near the master cylinder (or something) somewhere that's being stubborn; leaving the brake lever pulled at least overnight should give it time to migrate up into the reservoir.
Old September 7th, 2014, 11:54 AM   #8
Spot on! Pump until fluid looks clear and no bubbles. I had a tough one once, took me a whole bottle of new fluid to get it sorted.
Old September 7th, 2014, 12:00 PM   #9
snot
sammich maker
snot's Avatar
MOTM - Apr '15
This happened to me on the rear. I used my shoe lace (was still on my shoe) to hold the tube into the little Tupperware container (no bottle). I used 1/2 bottle to get all the bubbles out.
Old September 7th, 2014, 12:01 PM   #10
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
https://www.ninjette.org/forums/showthread.php?t=147436
see bottom of post on bleeding, bikes are easy to bleed. just do it step by step, if you still have problems let me know
Old September 7th, 2014, 12:03 PM   #11
Old September 7th, 2014, 12:54 PM   #12
Baron
Urban Legend
Baron's Avatar
Thank you everyone for helping out.
I just finished zip tying the bastard. I'll check in a bit. Also can anyone tell me which screws are used in the front brake reservoir? I swear these things are made of wax.
-Baron
Old September 7th, 2014, 01:16 PM   #13
Brother Michigan
Just curious, are you using the screwdriver included in the bike toolkit?
Old September 7th, 2014, 01:21 PM   #14
Baron
Urban Legend
Baron's Avatar
Unfortunately it didn't come with a tool kit so I got myself a 200pc toolkit some time ago, found the correct screwdriver and was using that one.
-Baron
Old September 7th, 2014, 01:23 PM   #15
Soujyu
From my recollection of doing this a couple of years ago, it took myself and a friend about 20-30 minutes of handbleeding the front brake before it finally would work.
The rear brake is easy to do and takes no time because the line is mostly horizontal and bubbles are easily bled out.
Old September 7th, 2014, 08:09 PM   #16
Brother Michigan
This post finally motivated me to get out and put on my Apex lines I got over a year ago. I've run half a 12 Oz. bottle of fluid through the rear and I'm STILL getting some small bubbles. Hopefully the front isn't that much worse.
Old September 7th, 2014, 08:12 PM   #17
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Get some speed bleeders, never struggle again.
M42 is offline   Reply With Quote
Old September 7th, 2014, 08:51 PM   #18
Brother Michigan
I'm not having any trouble with backflow or anything, so I'm not sure speed bleeders would change much. I do wish I had the $40 to spend on a mityvac, though.
Old September 7th, 2014, 09:36 PM   #19
M42
Wrench wench
M42's Avatar
Backflow's not the only thing bleeders help with, they make the whole job so much faster. Literally like 10 minutes for a full flush. I HAVE a mityvac and I stopped using it the moment I installed the speedbleeders, because the former is much more finnicky than the latter. Also more expensive. ($40 vs $20)
Old September 7th, 2014, 11:29 PM   #20
corksil
Motorcycle(s): A lot.
Once you get this sorted, please post back with your procedure.
Seems I've done this a million times, but someone always comes out of left field with some little tiny tidbit of thought that makes me think "Why didn't I come up with that?"
Hopefully you've figured it out by now.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old September 8th, 2014, 09:01 AM   #21
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
We had a hell of a time on the front lines when putting the steel lines on the 300.
We used a vacuum bleeder kit on the bike and that seemed to helped alot.
Raven's Rejuvenation
Old September 8th, 2014, 07:07 PM   #22
Baron
Urban Legend
Baron's Avatar
The rear was so simple to do for me too. The front however.........
I was wondering about those, however I didn't which ones to go for.
Okay, update update update. Sorry for going MIA for some time.
So I did what was posted above, I did go through nearly half a bottle of brake fluid but I was able to get it to an okay state. However I had some chores to handle and work in the morning so I wasn't able to leave it overnight.
I did a quick bleed when I got back from work today before heading out to Motorcycle Monday and it's more or less satisfactory now. It still feels a wee bit soft at times and pumping the brake a few times does make it firm so I'm guessing there is still some air in it somewhere. I'll probably try it next weekend.
However the zip tie procedure works.
I went the miser's way. Wish I hadn't.
-Baron
Old September 8th, 2014, 07:11 PM   #23
M42
Wrench wench
M42's Avatar
The speed bleeder website has a sizing chart. I think newgens use a SB8125L, but check yourself to make sure.
Old September 8th, 2014, 07:46 PM   #24
Baron
Urban Legend
Baron's Avatar
Thanks. It's out of stock on amazon.ca and amazon.com doesn't ship it to where I live. FML
Also does anyone know which screws does the reservoir take. I nearly stripped one of them. I found out it's 8-32 1/2 inch but one of the person told me that it was a metric screw since the ones I looked at in Canadian tire didn't have the same number of threads.
-Baron
Old September 8th, 2014, 07:48 PM   #25
M42
Wrench wench
M42's Avatar
Try ebay, too.
Old September 8th, 2014, 07:58 PM   #26
Brother Michigan
You might also look at auto parts stores. One just up the street from me evidently carries them.
As for the screws, take one to a hardware store. They should have something there you can try the screw in until you find the right size/thread pitch.
Old September 8th, 2014, 07:58 PM   #27
Asspire
Asspire's Avatar
brafasco, or fastenal, some times home depot
Old September 8th, 2014, 08:11 PM   #28
Baron
Urban Legend
Baron's Avatar
I'll give it a shot. I'll keep everyone posted on how things progress.
Thanks I'll be checking out both tomorrow, with any luck I should be able to find a match.
-Baron
Old September 8th, 2014, 08:41 PM   #29
Brother Michigan
One more thing I thought about while out riding just now: exactly how are you bleeding the front? Are you squeezing the lever and building up pressure before opening the bleeder or are you opening the bleeder and then squeezing? Both will technically work, but the former is theoretically better. By squeezing the lever and building pressure in the line before opening the bleeder, you are compressing any air trapped in the line, reducing its buoyancy. This should mean less regression of air back up the line between pulls.
Probably not enough to make a huge difference, but it's something.
Brake bleeding bliss Gurk General Motorcycling Discussion 6 July 2nd, 2014 08:35 PM
Brake Bleeding Question kennetht 2008 - 2012 Ninja 250R Tech Talk 16 March 4th, 2014 10:55 AM
Bleeding brake ? caineroad 2008 - 2012 Ninja 250R Tech Talk 3 September 24th, 2013 02:53 PM
Rear Brake Bleeding Problem (2011 Ninja 250) - Caliper Valve Sucks Back Fluid/Air MovingUp7 2008 - 2012 Ninja 250R Tech Talk 3 January 28th, 2013 08:46 AM
front brake pad problem killerbuddy 2008 - 2012 Ninja 250R Tech Talk 8 April 30th, 2012 07:30 AM
