Old April 13th, 2015, 08:31 AM   #1
ieathonda
ieathonda's Avatar
Motorcycle(s): Ninja EX250F
Clip ons and suspension geometry
I have some clip ons coming in this week sometime. I plan to move the forks up the clamps a bit and install the clip ons on the upper fork body similar to Rebeln9tn11's setup:
https://www.ninjette.org/forums/showthread.php?t=74050
My question about this setup is: I know it will lower the front a bit and I dont want to lower the rear at all, Will the bike's handling change considerably? I know turn ins and the front end will be a little more twitchy to inputs and dont want to compromise the lean angle of the bike as a whole by "evening" out the bike by lowering the rear as well. Any input would be great!
ieathonda is offline   Reply With Quote
Old April 13th, 2015, 08:44 AM   #2
agentbad
agentbad's Avatar
[IMG]had tor esize, will update in a bit[/IMG]
If you use imgur to host your pics you can do an instant resize by just adding an s, m, or l to the end of the filename in the link. Examples:
Old April 13th, 2015, 09:03 AM   #3
ieathonda
ieathonda's Avatar
Yeah I figured it out. Nice scooby in the background btw
Old April 13th, 2015, 09:54 AM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
If you dont like it you could try ex500 tubes. I think they arw longer and would swap over. You could try mounting the clip ons under the top tripple clamp. Since looks like you are going naked.
My Cafe Racer Build
My intro post
Old April 13th, 2015, 10:24 AM   #5
bruce71198
bruce71198's Avatar
Slide the tubes up just enough to make the clip on's fit, I think you will like the way it handles.
Old April 13th, 2015, 04:04 PM   #6
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
You need to make sure your forks don't bottom out on the lower triple tree. Put a zip tie on the fork tube and bottom the forks out to make sure you have room between the lower fork tube and the triple tree.
accumack is offline   Reply With Quote
Old May 28th, 2015, 07:15 PM   #7
Mike K
Mike K's Avatar
Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike
So what did you end up doing? I just got a set of used Woodcraft clip-ons for my '02 and now I'm scratching my head wondering if I should use them or not. I'm tracking the bike.
Track, track, track
Mike K is offline   Reply With Quote
Old May 28th, 2015, 07:38 PM   #8
ieathonda
ieathonda's Avatar
I ended up installing them above the upper triple tree. It lowered the bike maybe 1/2"-3/4". Love how it turns in after the clip ons. I also upgraded to new gen fork springs, new maxima 10wt fork oil and new fork seals which dramatically improved front end handling
Btw, the forks never bottom out. Plenty of travel left. I am 145lbs if that helps
Woodcraft clip-ons V.S. Kitaco clip-ons tjb0012 2008 - 2012 Ninja 250R Tech Talk 41 June 20th, 2011 05:35 PM
