Old May 19th, 2013, 05:16 PM   #1
lowandslowcabby
Motorcycle(s): 2001 EX250
Aftermarket speedo
Hey everyone,
I recently took the gauge cluster off of my 250 and installed an aftermarket one. Found here:
http://www.dimecitycycles.com/vintag...er-490291.html
They also have it in black.
[IMG][/IMG]
I wanted to be able to just plug it in to the oem plugs so I followed a combination of this thread
http://www.ninjette.org/forums/showthread.php?t=116546
(about half way down the page the guy posted a picture of his wiring job so i tried to see what wires he connected)
and these directions
http://www.jpcycles.com/instructions/pdf/5600262.pdf
It took a little time and some testing but I eventually got all of the lights to work as they should, including the blinkers. Since the blinker indicator is an led you have to add resisters to the two blinker wires. If not, all four blinkers will blink when activated. I just went to radio shack and bought 2, 10 ohm- 1 watt resistors and put them in between the two blinker wires and one blinker wire from the speedo, as shown. They cost about $2 and work great. I have had everything hooked up for about 2 weeks and havent had a problem yet.
[IMG][/IMG]
[IMG][/IMG]
Like all threads I do not assume any responsibility, hopefully just a a helpful thread for someone. If you have any questions just pm me and i will try to help.
[IMG][/IMG]
[IMG][/IMG]
Also, my speedo is a 2:1 ratio and it is pretty close to actual speed. Reads a little high. I also soldered all of the wires and heat shrunk them then wrapped everything in electrical tape for a cleaner look.
Oliver
lowandslowcabby is offline   Reply With Quote
Old May 19th, 2013, 05:19 PM   #2
lowandslowcabby
I bought my solder gun, solder, and shrink wrap from harbor freight for probably around $10. Everything worked great. Also, when I was testing, if one of the indicator lights didnt work when i plugged everything in I just switched the 2 wires ("power" and "ground") and then it would work.
Old May 19th, 2013, 05:32 PM   #3
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Good job an thank you for sharing. I too was looking at the same gauge, and this answered some. Questions. What about the rest if your bike, what else is going on? More pics?
My Cafe Racer Build
My intro post
Old May 23rd, 2013, 06:47 PM   #4
lowandslowcabby
Awesome, if you have any questions just shoot me a pm. And nothing else too crazy. I put some dirtbike bars on and some front blinkers from dime city cycle and just a custom rear license plate holder.
Old May 23rd, 2013, 06:53 PM   #5
lowdown112
lowdown112's Avatar
Motorcycle(s): 01 Ninja 250, 98 Honda CR80, 79 Harley Sportster
Nice writeup but Im intrested in your handlebar setup..can i see more pics?
lowdown112 is offline   Reply With Quote
Old May 25th, 2013, 08:03 AM   #6
lowandslowcabby
ya ill post up a picture or two. I just used pro taper universal mounts and pro taper cr mid 1" 1/8 bars.
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd Klondike1020 General Motorcycling Discussion 8 August 17th, 2014 12:23 AM
My speedo is way out! Damo990 2013 - 2017 Ninja 300 Tech Talk 14 March 5th, 2014 06:54 AM
Speedo Removal Knolly Ninjettes At Speed 4 September 26th, 2013 01:30 PM
Speedo Came Off! komohana 1986 - 2007 Ninja 250R Tech Talk 8 May 29th, 2011 01:55 PM
My speedo is off??? Kitdog 2008 - 2012 Ninja 250R Tech Talk 3 June 28th, 2010 03:24 PM
