Old October 6th, 2013, 06:49 PM   #1
peterpayne
peterpayne's Avatar
Motorcycle(s): Pregen body with a newgen engine.
how screwed up is this?
Long story short I broke this screw that holds the header pipes...
Fixable?
Posted via Mobile Device
peterpayne is offline   Reply With Quote
Old October 6th, 2013, 07:18 PM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I think it's threaded on both sides. Take some vice grips and see if you can unscrew the whole thing.
Do you go riding through mud a lot or something?
Worst case scenario you'll just need a screw extractor, drill bit and a punch. Possibly a tap to rethread it.....
Mods: Offset clutch pressure plate
Old October 6th, 2013, 07:47 PM   #3
Originally Posted by peterpayne View Post
.....Fixable?
Yes; as explained above.
I would use some heat on the bolt because that should be very tight after 6 years in there.
Before you give up, weld some cross bar on the stud (previously disconnecting the battery).
Old October 7th, 2013, 08:21 PM   #4
peterpayne
peterpayne's Avatar
Yeah, last time I went out I rode in the mud for a bit, and did not wash it..
Thanks, I think you're right about it being threaded on both ends.
Old October 7th, 2013, 08:23 PM   #5
peterpayne
peterpayne's Avatar
Thanks!, I'll start by using some penetrating oil such as WD-40 probably for a couple of days.... I don't want to risk breaking the stud where it goes into the engine, I really don't...
Old October 8th, 2013, 03:21 AM   #6
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Exclamation WD-40
WD-40 is not a good penetrant, it is designed to displace water (WD = Water Displacing). Go to the auto parts store and get a can of Seafoam "Deep Creep". Use a propane torch to heat up the stud boss (the cylindrical aluminum projection the stud screws into) a little, then spray on the deep creep. Repeat a few times. Give it a few days.
Then warm it up and unscrew the stud. You only want to warm it up a little, so the aluminum expands. If you get it too hot, the stud will also expand.
The proper tool to use is called a stud puller. You may be able to rent one at Autozone. ****CAUTION**** Do not apply any side load to the old stud while breaking it loose. If it does not want to unscrew without much force, repeat the heat soak/deep creep applications. If you break the stud off, you are in a world of poo.
fast1075 is offline   Reply With Quote
Old October 8th, 2013, 06:45 AM   #7
^ That's what I'd do with it as well. The right amount of heat will help a lot in that situation.
When you feel it start to move, go forward, then back, as you turn it out - moving slowly only about 1/8 turn out or less each time. It should get easier as you go, but backing-up occasionally is a good idea and usually helps keep it from snapping.
The same type of back-and-forth movement works well if you have spark plugs that are really snug and difficult to remove.
Old October 8th, 2013, 07:29 AM   #8
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
anyone use the "CRC Freeze Off" penetrant?
Supposedly supercools the the bolt to make it shrink and allow penetrant to soak in better.
My Cafe Racer Build
My intro post
am i screwed or what? 7oxSin 1986 - 2007 Ninja 250R Tech Talk 40 November 2nd, 2014 01:53 AM
Have you ever been screwed over? subxero Off-Topic 11 August 17th, 2014 09:59 PM
I screwed up Driddle !%@*#$%!)@#&!%@ I crashed! 21 August 7th, 2013 01:37 PM
So I think I'm getting screwed.... THE BIG SITT 2008 - 2012 Ninja 250R Tech Talk 37 May 4th, 2012 04:16 PM
I think I screwed something up ARF07 2008 - 2012 Ninja 250R Tech Talk 21 July 29th, 2009 06:53 PM
