Old July 7th, 2017, 03:49 PM   #1
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Making a quick turn throttle, DIY w/pics
I wanted a quick turn throttle but didn't have an R6 throttle tube, so I decided to do it myself
First I cut a piece of 1½" sch 40 PVC a little wider than the slot that the cable pulls on the tube fit into
I then ground it to fit juuuuust right, not so wide as to bind and not so narrow as to let the cables fall off and get jammed
I then cut a piece out and heated it with a hair drier to form it to fit on the throttle tube where the cables attach (not glued just a pinch fit)
I had to do some grinding inside the track in the housing and the cable end to make room for the extra circumference of the PVC spacer
before
and after
also had to grind the cable mounting bracket on the carbs to give the cables enough slack to not bind
before
and after
and reattached
this takes the throttle from about 100º stock to around 80º of rotation to get to full throttle. To do this mod you do NOT have to take the throttle tube off, (I took this one off to get better pics) which can be a pain in the donkey, getting the bar end off can be all but impossible, I couldn't get this one off with an impact driver, I had to use heat from a propane torch. 1¼" or even 1" might have worked, but I had 1½" in the shop at the time.
Old July 7th, 2017, 03:56 PM   #2
Very nicely done and well documented, thanks. A friend of mine does something almost exactly the same for the old Kaw triples.
Last futzed with by Triple Jim; July 8th, 2017 at 09:36 AM.
Old July 8th, 2017, 09:18 AM   #3
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Is it difficult to obtain an R6 throttle tube? I'm thinking about doing a quick turn throttle as well, but if R6 throttle tubes are cheap and easy to come by, I may as well just go that route.
Cra1g is offline   Reply With Quote
Old July 8th, 2017, 09:38 AM   #4
Old July 8th, 2017, 11:13 AM   #5
Z1R rider
Z1R rider's Avatar
I think they're easy enough to come by, I just had some time to mess with it and didn't have an R6 tube. Like I said in the write up, with the spacer there is no need to remove the bar end to switch the tubes. With the R6 tube you still have to do something about the cable length and clearance inside the housing. It's also my understanding that there are two R6 tubes, one is bigger (quicker) than the other, but I don't know the years that they changed them.
Old July 8th, 2017, 06:12 PM   #6
Ram Jet
Ram Jet's Avatar
Motion Pro makes some quick turn twist grips. I'm not sure if they make one for the 250.
Bill
Old July 8th, 2017, 07:16 PM   #7
I got a cheapie quick throttle made by Emgo. It's amazingly decent quality, too. It's going on my DT100. They make a couple different ones.
Old July 20th, 2017, 08:29 AM   #8
sparkcycle
sparkcycle's Avatar
Motorcycle(s): Ninja 300 ABS
I installed the quicker version of the R6 tube and had no issues swapping it out on my Ninja 300. I didn't even have to adjust the cable length... it just fit YMMV.
sparkcycle is offline   Reply With Quote
Old July 21st, 2017, 03:45 PM   #9
bruce71198
bruce71198's Avatar
[IMG][/IMG]
I beveled the edges and for clearance.
Old August 24th, 2017, 09:45 AM   #10
cbreater
cbreater's Avatar
Motorcycle(s): 16' S1000RR, 04' CB919, CRF150/230, 07' 250R
Just did this, following 99% of it and it worked great. Wonderful post. Thanks for sharing! \
Confirmed that I did use 1" and expanded with hair dryer. Worked fantastic!
As a point of reference this is now almost exactly the same rotation from full closed to full open as my S1000RR.
cbreater is offline   Reply With Quote
Old August 24th, 2017, 11:23 AM   #11
Ram Jet
Ram Jet's Avatar
I think I'm missing something here. What benefit would a quick turn twist grip be on a motorcycle with a constant velocity carburetor. You can twist yourself silly but the carb slide is only going to open as fast as the engine can ingest the fuel/air mix. That is, you don't control the throttle slide the carburetor does.
"Let's twist again like we did last summer."
Bill
Old August 24th, 2017, 01:44 PM   #12
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Bill
I installed one so I could obtain WOT in one motion and keep my wrist in a comfortable spot. It makes banging gears a lot easier too.
The Bike | The Truck
Old August 24th, 2017, 02:33 PM   #13
Bill
The butterflies comes first though as they determine how much air-volume flows through engine. Then the slides adjusts to that volume to maintain a constant velocity through for the metering circuits. Cause and effect, sure slides open by themselves and they do so based upon volume of air-flow the butterflies dictates. This usually occurs fairly quickly anyway, just a couple of engine-revolutions. At high-RPMs, it's pretty much instant.
So 25.5bhp max-HP requires wide-open 90-degree butterfly position. There's absolutely no way, nada, zip, zilch possibility slides will open all the way at less than that butterfly opening. Trick is how to get there easily for the rider.
What the throttle-mod does is reduces the effort, not necessarily time to get to that max butterfly opening. If you do over 1000 gear-shifts in a single race, that 100-degrees of throttle-twist, requires A LOT of energy and effort. Some people can't even do that with a single-twist and have to walk their hand over grip. Changing that to just 80-degrees makes it easier to do and less fatiguing.
Old August 24th, 2017, 02:51 PM   #14
Ram Jet
Ram Jet's Avatar
Ummm, OK. Thanks.
Bill
Zeta Quick Turn Throttle toEleven 2013 - 2017 Ninja 300 Tech Talk 11 June 9th, 2016 07:49 PM
WTB: Rev2 quick turn throttle ULW Items Wanted 0 March 27th, 2016 02:02 PM
R6 Quick turn throttle tubarney 2008 - 2012 Ninja 250R Tech Talk 59 September 6th, 2014 12:55 PM
Motion Pro quick turn throttle rojoracing53 2008 - 2012 Ninja 250R Tech Talk 43 May 28th, 2013 07:18 AM
Dan Kyle's Quick turn throttle question Gregular 2008 - 2012 Ninja 250R Tech Talk 7 February 28th, 2009 03:14 AM
