Old August 2nd, 2017, 10:05 AM   #1
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
***project fender begone***
Got a 4 day weekend starting Friday and Lucy is gonna get some love. First on the agenda, fender elimination. Anyone who's done it themselves on the cheap please post here give links to videos and write ups. I'll listen to everyone's method. I'm not paying $100 for a kit. I've become a great DYI kind of lady. Thanks!
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old August 2nd, 2017, 10:23 AM   #2
Ralgha
Ralgha's Avatar
Here are a few threads, they're on newgens, but it should give you some ideas:
https://www.ninjette.org/forums/showthread.php?t=21044
https://www.ninjette.org/forums/showthread.php?t=21090
http://www.kawiforums.com/ninja-250r...tra-parts.html
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old August 2nd, 2017, 10:25 AM   #3
It can be done for free!!! This guide shows you how: https://www.ninjette.org/forums/showthread.php?t=21090
Don't remove fender all way up to tail-light. Leave about 5-6cm to bolt plate-bracket to it.
I want to use use tail-light bulb to light up licence-plate too. Looking for way to cover up bottom of tail-light with clear plastic if I cut an opening. Might just get some small LED lights.
Old August 2nd, 2017, 02:08 PM   #4
taz
taz's Avatar
MOTM - May '17
Hey guys he has a pre gen
Old August 2nd, 2017, 04:09 PM   #5
A.J.
A.J.'s Avatar
Originally Posted by taz View Post
Hey guys she has a pre gen
Yes yes, thank you. 2006 to be exact.
Old August 2nd, 2017, 04:58 PM   #6
Whoops, sorry. Here's one that'll work: https://faq.ninja250.org/wiki/I_want..._rear_fender_1
CD case is good idea. I'm going to try that on my bike!
Old August 3rd, 2017, 04:01 AM   #7
A.J.
A.J.'s Avatar
That's the one I was looking for thank you. Now to dig up some CD's lol. Any time there's cutting involved I get a little nervous. I tend to be a perfectionist when it comes to my baby.
Old August 6th, 2017, 09:31 AM   #8
A.J.
A.J.'s Avatar
Dragging my feet on this job. Have a friend with an '07 just one year newer than mine. He just innocently said his fender simply "unscrewed" from the tail. Anyone confirm this? His did in fact just unscrew. He was able to keep his turn signals as well.
Old August 6th, 2017, 12:43 PM   #9
Here's another guide https://faq.ninja250.org/wiki/I_want..._rear_fender_2
The fender does unbolt. But you have to mount turn-signals and licence plate somewhere.
Old August 7th, 2017, 07:48 AM   #10
A.J.
A.J.'s Avatar
Well hell the mounting is the easy part it was hacking away with my dremel I was dreading. Thanks again @JacRyann I really need to be getting started lol.
Old August 7th, 2017, 11:32 AM   #11
I think you have to hack off bottom of fender but leave some at top to hold licence-plate and turn-signals.
Dremel may be too small for this. Cutting disc melts plastic fender and it just sticks to disc. Smaller teethed cutter will work, but it's almost not big enough to penetrate.
I draw a line for cut, then use jig-saw. Or a sawz-all.Or angle-grinder. Or you can hand-cut it with hacksaw. Many options. You can even take the Alcatraz approach and nibble off little at time with end-nippers or dykes. Any mistakes will be minor and easily corrected.
Old August 23rd, 2017, 01:23 AM   #12
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Did you ever do it?!?!?
Here's what I did to the factory fender. The license plate holder was a piece that was cut off too!!
The Bike | The Truck
Old August 23rd, 2017, 04:28 AM   #13
Ram Jet
Ram Jet's Avatar
I read this post a-little late. I just had my tail light off and noticed a transparent red rectangle glued to the underside of the center tail light lens. You could try poping that out and cutting a piece of CD clear plastic jewel case to fit and glue that in to light your license plate. I would think any plastic styrene cement (Testors?) would work.
Bill
Old March 1st, 2018, 03:37 PM   #14
Dab
Motorcycle(s): 1996 ninja 250
totally works i did this to my old oem style tail light and routed the signals into the pods on either side of the main tail light i might still have the part kicking around if you want to buy it as I've updated the look since
Dab is offline   Reply With Quote
Old March 5th, 2018, 08:58 AM   #15
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
I think I read some where here in the USA the turn signals have to be at least a certain distance apart. Those very nice holes in the brake light assembly are not meant for use as turn signals in the US. What they are really good for is place to put a couple of very bright LEDs hooked to a brake flasher unit. The kind of flasher that strobes for a few seconds and then goes constant on until you let off the brakes.
Superbright LEDs has all the parts including the flasher units. I have been using them for years on several of my bikes. Very simple install in most cases. The LEDs could be just hot glued into the ninja brake light assembly. Same for the flasher controller.
Cafe Racer is offline   Reply With Quote
Old March 5th, 2018, 05:49 PM   #16
Dab
I never had a problem here up in Canada but you could be right about the states
Old March 5th, 2018, 07:31 PM   #17
According to DOT FMVSS 108, turn signals on bikes able to go +30mph has to be 16" apart minimum. There are also photometric measurements of minimum and maximum brightness. I've found a lot of LED signals to be too dim.
Old March 5th, 2018, 09:28 PM   #18
Ram Jet
Ram Jet's Avatar
I remember removing all the turn signals on my 73' Kaw 500 triple. I don't think drivers today would have a clue if you used hand signals. I turned the empty tail light sockets on my Ninja into additional stop lights.
Bill
Bill
