Old April 27th, 2014, 09:07 AM   #1
auntymunga
auntymunga's Avatar
Motorcycle(s): 2008 250r Ninja
rear view camera
Here's how I installed the rear view camera:
Firstly, you find one online in your country and buy it. It should obviously be for a car and come with a screen and camera. My set cost $40.
Secondly, you need to remove all your fenders, covers, seats basically everything.
Now which wires you cut into is going to be determined by how you want to use the camera. I want it to turn on and stay on when my bike's ignition is on therefore I decided to use a lighting connector. Here's a photo of the one I used:
(it's the small center one)
I was installing a few things at the same time, so we put them all together and soldered it.
After that, we tested everything got power and was working (it was) so we covered all the connections in electrical tape.
Put all the bike back together and voila!
We did use a meter to test that there was enough current coming through that connection. We didn't have to extend any wiring because it was all long enough and we made sure none of the cabling was going to be damaged by anything while in use.
I used my trusty heavy-duty velcro to attach the monitor to the windshield so I can unplug it while I'm at a shop or in an area they might steal it
auntymunga is offline   Reply With Quote
Old April 27th, 2014, 09:32 AM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Ah! I've wondered what the city light looked like. US versions don't have that.
How does the screen look in daylight? Still enough to spot a car coming up behind you or is the glare too much?
<-- Linky
Old April 27th, 2014, 09:48 AM   #3
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
This is a very cool project for only $40
could you post some more pics of where you put the velcro with the camera detached?
and same question as nevadawolf: how's it in daylight?
but also, how is it when it's dark? no problems with the headlights?
ah, my questions keep coming: would it be possible to save the recorded image? Could be nice when touring with friends
EDIT: did you do something to reduce vibrations? I'm talking about both the camera for stable image, as the screen for damage...
I can not be a true player by playing around.
the big mike is offline   Reply With Quote
Old April 27th, 2014, 10:08 AM   #4
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Ride fast enough you don't need a rear camera.
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old April 28th, 2014, 01:41 AM   #5
auntymunga
auntymunga's Avatar
I'll make a video for you! Hopefully be up tonight
Old April 28th, 2014, 07:06 AM   #6
auntymunga
auntymunga's Avatar
Okay so here is the video for you:
A couple of things:
Firstly, no it doesn't record. I have probably the most basic one, but if you want to do that and you have a spare gopro around you could get this from gopro: http://gopro.com/camera-accessories/...omposite-cable with a monitor and then use it as a rear view camera and it can record I'll have a think about a cheaper option as well for you
Secondly, daylight seems fine. I was a little nervous on the video because I am usually the one behind it The video link doesn't show everything as true to life as it is. It really good for such a cheap setup. When the sun is directly above shining on it, sure, it's not great, but since that doesn't happen all the time I think it's great. As for night time, I am going to take a ride later and do a second video which I will post here.
Thirdly, as for protecting it, I am still trying to decide. It's not raining here in Johannesburg at the moment because it's winter so I have a few months to decide what to do about it. Suggestions?
And finally: as for the shaking, the gopro was shaking whereas the monitor and camera are pretty firm. I think that the velcro is a great idea for that. You can stick it in positions that there isn't any give. I hope that made sense.
Anywhoo more videos to come.
Old April 28th, 2014, 07:23 AM   #7
NevadaWolf
NevadaWolf's Avatar
Brillant! This a great mod, thanks so much for finding and installing an inexpensive version. The one you got also doesn't draw a whole lot of power so its inexpensive there too. Now I am really really tempted to cover the blind spot directly behind me.
And puppy!!
<-- Linky
Old April 28th, 2014, 07:30 AM   #8
auntymunga
auntymunga's Avatar
And puppy!!
Puppy!!!!!
Old April 28th, 2014, 07:48 AM   #9
Old April 28th, 2014, 10:50 PM   #10
the big mike
Big surprise! Thank you for the video
I like it when people take their time to give elaborate answers on questions, I never expected a video though.
Old April 29th, 2014, 12:59 AM   #11
auntymunga
auntymunga's Avatar
Night video!!!!
Again, the gopro moves more than anything and the angle isn't great but in real life I can easily tell when vehicles are behind me and what they're doing. In the video I went past streets that had lamp post and streets that didn't. You can tell it is a lot better when there are street lights but again at night people have their lights on so it's not too bad. I figured out a proper mount for my gopro so I'll record another day shoot but all is well and I love my little rear view camera.
Only weird thing is the lines on the screen but I think that's from my wiring, I think the other electronics are messing with it so I'll probably fix that in the future.
Old April 29th, 2014, 01:51 AM   #12
NinjaZX6R123
Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R
Cool mod. I've seen a guy with this setup. He used..
This camera with no guidelines: http://www.amazon.com/Esky-EC170-06-...d_bxgy_e_img_y
With this monitor 4.3" version (they have 3.5" as well): http://www.amazon.com/Rearview-Monit...D+TFT+with+cam
Looking at his camera I could see both left and right lane. He said he hardly used his rearview mirrors. He had to make his own fuse box? But I'm sure you can buy one like this: http://www.amazon.com/Shkciglightout...FJQV8Q6AD6P90C
One of these days I'll try this setup, but I would probably hook up a GPS before I do a camera.
NinjaZX6R123 is offline   Reply With Quote
Old April 29th, 2014, 03:17 AM   #13
auntymunga
auntymunga's Avatar
Yeah that setup is pretty much like mine but without having to use a fuse box. I can see both lanes as well and don't use my mirrors anymore. I would say use the smaller screen so that it can rest on the wind shield so it doesn't shake too much. I have the 4.3" and I would have preferred slightly smaller just from an aesthetic point of view. Here's the link to the one I bought in SA:
http://www.bidorbuy.co.za/item/14460...Low_Price.html
It would be great if you could have a gps and rear view camera working off the same screen.
Old April 29th, 2014, 05:42 AM   #14
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
https://www.youtube.com/watch?v=NplyUgp2KN0 is a video review from a guy who did this on his 500 a few years ago. He mounted his monitor higher up on the windscreen, parallel with the mirrors (see 9:20). He said this worked very well and provided a natural mirror view all the way across from mirror to monitor to mirror.
My car's headunit supports a rearview camera so I picked up a cheap Pyle setup (camera and monitor) from Woot, planning to just use the camera. Then I discovered that other style cameras might be easier to mount on my car, so I might end up not using the Pyle parts at all. I've been really tempted to put it on the bike, but haven't yet.
Old April 29th, 2014, 05:44 AM   #15
auntymunga
auntymunga's Avatar
Good idea and thanks for the vid
Old April 29th, 2014, 07:21 AM   #16
NevadaWolf
NevadaWolf's Avatar
I'm lazy and my Youtube app is annoying soo.... Here's InvisiBill's video
<-- Linky
Old April 29th, 2014, 04:55 PM   #17
reroka
Biker Noob
reroka's Avatar
Motorcycle(s): 2004 Honda Shadow 750 Aero
Very nice, a good thing to have while cruising on long rides.
reroka is offline   Reply With Quote
Old April 30th, 2014, 03:21 AM   #18
auntymunga
auntymunga's Avatar
For sure! I actually love it in the city because I have a much better view of what is happening behind me so I don't have to strain my neck as much
Old April 30th, 2014, 03:28 AM   #19
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
I love your accent!
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old April 30th, 2014, 03:29 AM   #20
auntymunga
auntymunga's Avatar
Originally Posted by Kscreations08 View Post
I love your accent!
Haha thanks I'm from South Africa so I suppose it is a bit strange
Old April 30th, 2014, 04:01 PM   #21
File Type: jpg eyes.in.the.back.of.my.head.achievement.jpg (35.8 KB, 2 views)
Old May 2nd, 2014, 01:23 AM   #22
auntymunga
auntymunga's Avatar
That's awesome
Sad story: I've had my 360 for a while (as in 6 years) and then due to some trickery from the tech goblins I lost my profile points I had like 14k (not bad for someone who doesn't get a chance to play that often) Emo was an understatement! I tried contact Microsoft to help but they weren't very helpful. I think the call centre in SA isn't that clued up. Now I just play my PS3 because I can't bring myself to start again. Sigh.
Old July 25th, 2014, 10:09 AM   #23
agentbad
agentbad's Avatar
Neat heres another.
http://imgur.com/a/mxrwf
Old July 25th, 2014, 03:14 PM   #24
Hero Danny
Inline 4!!!
Hero Danny's Avatar
That's pretty cool, nice mod for $40
Be careful. Remember you are
invisible
Old July 25th, 2014, 08:31 PM   #25
NinjaZX6R123
That was so random. PC master race checking in.
Not a big fan of 360. Would rather play PS3, but if you're into gaming, PC is the ultimate.
Old July 27th, 2014, 04:12 PM   #26
auntymunga
auntymunga's Avatar
I gots my PS3 (love) and last week upgraded to PS4, ergo why I've been missing on the forum
Old July 27th, 2014, 04:13 PM   #27
auntymunga
auntymunga's Avatar
Originally Posted by agentbad View Post
Neat heres another.
Sweet
Old July 27th, 2014, 07:42 PM   #28
Hero Danny
Inline 4!!!
Hero Danny's Avatar
I love my xbox 360, I've been a member for 9 years.
I'll be getting the xbox one. I'm a big halo fan. Also I have a huge gaming community that I enjoy that is on the xbox platform.
I know people have their opinions, I have a gaming PC as well, it is beast but it is lack luster compared to the consoles... Imo consoles are like our little bikes, they are not as powerful, but they are loads of fun.
I've never been big on play station *shrugs*
invisible
Old August 21st, 2014, 03:25 PM   #29
Someone makes a plug and play backup camera for the 250. I haven't followed all the links in the thread to know if any of them point to it because I am on mobile, but I will request that someone on a proper PC look it up and link it.
It replaces the tag light assembly.
Old August 21st, 2014, 04:02 PM   #30
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
$350.00
http://www.watchyoursix.com/ninja-25...ter%20250r.htm
Seems pretty steep even though it comes with a replacement wind screen.
iamjacob is offline   Reply With Quote
Rear view camera for your 2fiddy psych0hans 2008 - 2012 Ninja 250R Farkles 11 October 7th, 2012 04:05 PM
Rear-view camera giveaway Toly General Motorcycling Discussion 1 May 5th, 2011 12:07 PM
Rear view camera for newgens JeffM 2008 - 2012 Ninja 250R Farkles 7 April 17th, 2011 09:21 PM
[topix.net] - A Camera's View Of The LA Supercross Ninjette Newsbot Motorcycling News 0 January 25th, 2011 01:51 AM
Testing update - Rear view camera Gregular 2008 - 2012 Ninja 250R Farkles 23 March 27th, 2009 10:19 AM
