Old June 13th, 2020, 07:07 AM   #1
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Hello from Seattle
Hi Folks,
I'm new to motorcycles and just bought a 2008 Ninja EX250J with 8K miles on it. I have been working on cars for years but this is my first bike and I intend to open it up and clean it and do maintenance (and repairs if needed).
Previous owner has not driven it much due to work schedule, so the bike has a hard start when engine is cold. Looks like it needs fuel to enter the bowl based on what I have read so far in this forum.
Will need your advice and help once I get started.
Thanks!
arthury is offline   Reply With Quote
Old June 13th, 2020, 07:25 AM   #2
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
arthury! Glad you found us...
Postwhores are COOL! ~Allyson
Old June 13th, 2020, 07:33 AM   #3
arthury
arthury's Avatar
Thanks!
I went to the official Kawasaki website and they are out of stock for Service Manual.
What do you recommend for the best service manual?
Old June 13th, 2020, 02:43 PM   #4
Hi Arthur and welcome to Ninjette!
Old June 14th, 2020, 06:33 PM   #5
It sounds like you may have multiple issues.
1. if not getting fuel in float-bowls, petcock may be issue. There's tiny filter inside fuel-line between tank and carbs. If it's inserted backwards, it can crumple up and restrict flow. Also measure vacuum going to petcock, might not be getting enough to open. Or petcock's diaphragm may be leaking, and not opening. A lot of people spend A LOT of time working on carbs when petcock is issue. So measure actual flow-rate out of petcock to pinpoint this issue. How much petrol do you collect in 30-seconds from petcock?
2. sticky float valves can also give you low flow. If bike's been sitting a while, drying petrol can actually glue the valves to their seats. But this is a binary issue, yes/no, bike will not start at all if float-valves are stuck. No way to diagnose this without disassembly. Although you can do quick test by draining each bowl into measuring cup and seeing what volume you get per side if it matches what should be in there.
Quick search for "clean carbs ducatiman" will give you some threads for others with similar problems.
Old June 14th, 2020, 06:52 PM   #6
arthury
arthury's Avatar
Thanks for the detailed diagnostic paths laid out for me.
I will look into these and report back when I find something.
Appreciate this help a million!
Old June 16th, 2020, 05:39 AM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Old June 16th, 2020, 06:07 AM   #8
arthury
arthury's Avatar
I've started it once everyday and let it idle for 2-3 mins and rev it a little gradually after it warmed up.
The startup problem seems to have disappeared.
I have received the paperwork history for the bike and looks like I have to do some proper maintenance. The following have not been done since 2014 (4K miles ago):
- Coolant and brake flush
- carb cleaning
Valve adjustments have never been done before or not recorded for 8K miles.
Brake pads and pressure plates have not been inspected.
Battery was replaced once in 2014. So, I need to take out the battery to inspect the voltage and charge if necessary.
Old June 16th, 2020, 09:14 AM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old August 2nd, 2020, 07:52 AM   #10
Welcome!
Old August 2nd, 2020, 12:18 PM   #11
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Hi from the east side neighbor!
"most folks racing this bike get it in a competitive state of being with much less invested than you've already put in Saturn." - Alex
Old August 2nd, 2020, 02:28 PM   #12
arthury
arthury's Avatar
Thanks, for all the warm messages.
I have since replaced all the fluids and replaced the front brake hose with a Galfer stainless one. All is good with little Ninja.
Old August 2nd, 2020, 02:29 PM   #13
arthury
arthury's Avatar
Hi, I’m actually in Sammamish... ha ha
Old August 5th, 2020, 08:37 PM   #14
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Welcome, what a coincidence when first got my 08 black 250 it also had 8k miles.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old August 5th, 2020, 08:56 PM   #15
arthury
arthury's Avatar
Indeed, what a coincidence!
And, looks like you are also a CBR owner.
2 Wheelers: 2008 Ninja 250R; 2005 CBR1000RR
4 Wheelers: 2018 M3; 2015 M235xi
Old November 11th, 2020, 03:57 PM   #16
Snake
Snake's Avatar
I’m a little late but ....hello and welcome !
Old November 12th, 2020, 04:04 PM   #17
Ceeloo Yello
Motorcycle(s): 250
Welcome
Hello from Seattle! MichaelS214 New Members 18 July 5th, 2019 03:51 PM
Hello from Seattle Kingosiris999 New Members 8 February 11th, 2016 06:20 PM
New from Seattle loganlexow New Members 8 January 19th, 2013 07:41 AM
Seattle, WA Noob ichibunkid.206 New Members 13 June 30th, 2011 04:44 PM
New Rider in Seattle nick2049 New Members 12 May 23rd, 2010 01:26 AM
