Old June 4th, 2023, 06:06 PM   #161
Hey, what coating & colour is that on flywheel cover?
Old June 5th, 2023, 08:59 PM   #162
punishum808
punishum808's Avatar
Motorcycle(s): Suzuki JPN Katana 750 , 1994 Suzuki Pro Stock Motorcycle , 2001 Ninja 250
Its a powder coat, some tan color with a matte clear.
punishum808 is offline   Reply With Quote
Old June 5th, 2023, 09:09 PM   #163
punishum808
So this is the complete motor. Still a lot of work on the chassis and custom parts that are being fabricated.
Stay Tuned.
ALoooooHA, Book UM Danno
Old June 10th, 2023, 11:12 PM   #164
punishum808
More custom pieces than you can imagine.
More than has ever been done before.
A custom linkage that has roller bearings, anodized AND is half a pound LIGHTER.
Old June 11th, 2023, 06:43 AM   #165
Guaire
Motorcycle(s): 2005 EX250, 2014 Royal Enfield Continental GT
Looks like a super-motor.
The custom linkage doesn't cross over to the stock location, I assume?!
Guaire is offline   Reply With Quote
Old June 11th, 2023, 10:39 PM   #166
punishum808
Its a direct replacement. Thanks to Danno I used a Newgen swingarm set up.
Old June 12th, 2023, 02:24 PM   #167
punishum808
Billet
The axles and pivot were custom made. Combined it lost nearly 2.5 pounds.
Last futzed with by punishum808; June 12th, 2023 at 04:14 PM.
Old June 14th, 2023, 08:25 PM   #168
punishum808
Got Brace?
Custom brace . . .
Old June 16th, 2023, 07:08 PM   #169
Wow, that's a piece of art!!! Original piece is solid hunk of steel! Very agricultural... but gets job done! So when you opening on-line store selling all these goodies?
Old June 18th, 2023, 03:15 PM   #170
punishum808
More Brace
Test fit the new brace. It fit like a glove. We also know the dimensions for Newgen front ends too.
Old June 19th, 2023, 01:37 PM   #171
punishum808
More Mock Up
Test fitting all the things up front.
Old June 21st, 2023, 10:41 AM   #172
punishum808
The weight of even the triple top retaining bolt is very heavy. So this is what we came up with.
All our pieces are anodized. This is why it has an iridium look.
Old June 23rd, 2023, 07:09 PM   #173
punishum808
Triple Top
This triple tree top is 5 ounces lighter than stock.
Old June 26th, 2023, 07:21 PM   #174
punishum808
'Breaking News'
The official fuel system for our 2 wheeled projects on PunishUM Motorsports on Motortrend TV is the industry leaders 'Lectron Fuel Systems'.
This is the first set of their latest technology, the Billetron series with Power Jets that was custom built for our shows 250 Ninja.
Stay Tuned as this build just keeps getting better and better.
Mahalo
Last futzed with by punishum808; June 27th, 2023 at 12:05 AM.
Old June 28th, 2023, 01:08 PM   #175
punishum808
So the red bolt is one you can pick up on Ebay, verses the one we had made. The one we made is -5 grams lighter and a better quality aluminum from 7050 billet stock.
Old June 29th, 2023, 10:57 AM   #176
csmith12 is online now   Reply With Quote
Old July 1st, 2023, 06:50 PM   #177
punishum808
Old July 1st, 2023, 07:00 PM   #178
punishum808
So we had tried to use the generic alum top bolt from ebay but still prefer the custom one made.
Changes the whole look completely. And it shaved off -5 ounces.
Old July 4th, 2023, 12:26 PM   #179
punishum808
Lectrons
Trial fitting the custom built Lectron Fuel Systems carbs for the 250 Ninja.
This is a one off set and they machined it to fit the stacks we made.
Old July 8th, 2023, 03:48 PM   #180
punishum808
We Have a Problem
Due to the size of the bowls on a Billetron Lectron carb the oem boots will not work. As you can see from this pic there is No Way it will mount.
Old July 8th, 2023, 04:07 PM   #181
More specific info required....is spacing between carbs adequate to allow mounting? NOPE, unfortunatlely too wide, back to the drawing board.
Old July 9th, 2023, 01:06 AM   #182
punishum808
Stay tuned for future posts.
Old July 9th, 2023, 10:27 AM   #183
punishum808
When ever working with anything never done before you have to accept that things are just not going to fall into place.
So I took a look at my 1428, 8 second, 200 hp dragbike to point me in the right direction.
Btw, these Miks are being replaced with fresh Lectrons also. They made them with clear bowls, Power Jets and the Lectron boots as well.
The Magura throttle has less than one inch of travel from 0 to wfo.
Old July 12th, 2023, 11:08 AM   #184
punishum808
Problem Solved
So i figured it out and now the custom Lectrons will work.
Old July 12th, 2023, 02:11 PM   #185
Oohh. aaaahhh... drool...
Old July 14th, 2023, 05:46 PM   #186
punishum808
Mahalo
Old July 14th, 2023, 05:52 PM   #187
punishum808
There hasnt been a nice and one that works manual tensioner for a Pre Gen.
So guess what? We made one.
Old July 19th, 2023, 02:28 PM   #188
punishum808
Experimenting with the swingarm.
We already have a better than stock caliper but the aftermarket bracket did NOT provide the proper clearance. Btw, it stated that it was made for this exact application. Unfortunately it wasn't as advertised.
So now we are designing our own one of a kind bracket to get the proper caliper to wheel clearance.
We are also designing our own axle blocks as the ebay one which is nice as it holds a slider but its thickness is much more than the stamped oem one.
Old July 23rd, 2023, 10:09 AM   #189
punishum808
With the custom fender we also had to make some custom fasteners as well. A lot of cutting to get the fender to sit correctly had to be done so things like tire warmers can be used on the racing slicks.
Old July 25th, 2023, 11:07 AM   #190
superkain
Motorcycle(s): k6 GSX-R 750, 2008 Ninja 250R
Very nice!
superkain is offline   Reply With Quote
Old July 25th, 2023, 07:05 PM   #191
punishum808
Originally Posted by superkain View Post
Very nice!
Mahalo
Old July 25th, 2023, 07:11 PM   #192
punishum808
More Ti as even the motor mount bolts, shifter bolts, every nut or bolt is ti/22 or al/13.
Last futzed with by punishum808; July 25th, 2023 at 09:22 PM.
Old July 30th, 2023, 05:15 PM   #193
punishum808
Silicone hoses require proper clamps. If you use the off the shelf clamps from your auto parts store you will damage silicone hoses in the long run.
Old September 10th, 2023, 03:07 AM   #194
punishum808
ALoooooHA
Its been a few months but the progress still continues.
So the carbs spacing has been solved. The attention to detail was necessary to be able to over come the obstacles when its never been done before.
Old September 15th, 2023, 01:13 PM   #195
punishum808
ALoooHA
So now test fitting the new radiator and will be mounting an external oil cooler too that will have an fittings and braided lines. All the bolts are aluminum.
Test with the bodywork on and it all fit nice and tidy.
Old September 25th, 2023, 10:00 AM   #196
So awesome!!!
Ever think about magnesium valve and case covers???
Old September 26th, 2023, 10:52 AM   #197
punishum808
So awesome!!!
That would be cool but if you don't work in that material all the time it is dangerous.
"It provides a hazard for CNC machinists: the chips and dust from machined magnesium are highly flammable."
Old September 30th, 2023, 03:56 PM   #198
punishum808
Even the motor mounts are titanium in the rear and the front one is a custom billet bolt. All are drilled for safety wiring.
Old October 5th, 2023, 12:12 AM   #199
punishum808
ALooooHA,
Have put the new canister we shortened and fabricated so it attaches onto the rear sets like a race bike should. The whole exhaust is ceramakote.
Old October 10th, 2023, 05:45 AM   #200
punishum808
[webbikeworld.com] - Harley-Davidson Announces New Parts for Customizing You Bike Ninjette Newsbot Motorcycling News 0 March 19th, 2020 07:30 AM
[motorcyclistonline] - Harley-Davidson Custom Kings Dealer Customizing Contest: Sport Ninjette Newsbot Motorcycling News 0 March 1st, 2016 10:21 AM
Customizing Accessories bbbrandy19 General Motorcycling Discussion 12 March 24th, 2011 10:13 AM
