#1 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
Ummm, the other week after work...
***Do you HAVE to take the gas tank OFF, to safely change the spark plugs?*** I took off the side fairings to change out the spark plugs. Well i noticed theres NO ROOM to do so, unless you need a "special wrench or socket". Those spark plug boots are Looong man! ![]() Rather than risk dropping something into the spark plug cavity, i just put the boots back on, the fairings and called it a day. I dont have a garage where i live, i live on a dirt road thats like 20 feet from the apartment. So working on the bike puts the Hoaring amount of DUST in the air, in danger of settling into engine areas if worked on outside. ![]() Cant work on it at work, afterwork. Owner doesnt want your crap in the way if you end up, having to leave your vehicle overnight, etc. *As far as long labor hours are req'd for maintance/repairs* I've changed oil in my bike and my car, at work, after work. Thats NP, but quite simply, I dont have the luxary of working on vehicles in a timely fashion, where it can sit there for weeks if need-be! ![]() thanks. |
#2 |
Join Date: Apr 2010 Motorcycle(s): 09 Ninja 250R Posts: 13
I did mine without taking off the gas tank.
Use the tool from your factory included tool kit. It's got an articulated part in the middle so you can sneak it in under the tank, get it into the spark plug hole and then straightens out when its fully down in there. Sounds dirty but it works. |
#3 |
The wrench from your toolkit is the only way to go. The ONLY way.
And it works like a charm. Easy. |
#4 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
Use the tool provided in the bike's toolkit. It's the only thing that works without removing the gas tank and the cylinder head cover.
Heck, even if you did remove the gas tank and the cylinder head cover, use the tool. If you really need "ratcheting" abilities, just use a 14mm (I think) ratcheting combination wrench on the nut on the tool.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
#5 |
Join Date: Sep 2014 Motorcycle(s): 2004 Ninja 250 Posts: 342
Question:
Are there two spark plugs on a pregen?
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle. |
#6 |
I'm crazy,your excuse is?
#7 |
I only ordered 1. Have to order another one.
Changed out spark plugs after winter. Give gas and dies. | Twitchy Stitch | 1986 - 2007 Ninja 250R Tech Talk | 56 | March 2nd, 2015 04:02 PM |
Which spark plugs? | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 23rd, 2013 09:13 PM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
removing gas tank - petcock question | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 25th, 2011 11:23 AM |
Spark plugs... | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 23rd, 2010 04:02 PM |
