Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old June 2nd, 2015, 11:21 AM   #1
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Air horn install (Stebel Nautilus Compact)
Just wanted to post a few pics of my air horn install...
I took a few measurements from my 300 based on where I figured I could attach the horn and where I wanted it to mount up (away from wires, the engine and fairings), went to Home Depot and picked up some steel "corner bracing", I got lucky and it fit perfectly on an existing bolt...
The horn couldn't attach directly to the brace because of the size/shape so I used a piece of flat steel and some hard ware to attach it (with blue Loctite)...
After a few test runs it seems great so the next time I have the fairings off I will add an additional piece of flat steel from another hole on the corner brace just for extra strength.
Side view...
I purchased the Universal Plug-n-Play Wiring Harness for a quick and easy install, I routed the wires down the side of the bike to the battery...
All back together you can just see it through the fairing...
slolane is offline   Reply With Quote
Old June 2nd, 2015, 11:53 AM   #2
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Before and after video of sound check?
Riding it like I financed it.
Old June 2nd, 2015, 12:16 PM   #3
slolane
Motorcyclist
slolane's Avatar
I didn't do a video, years ago when I did the same mod on my 250's I couldn't capture the sound well to show the difference. I would describe this as a small freight train though and worth the $40-60 investment to me.
Old June 2nd, 2015, 12:45 PM   #4
VictorChimba
VictorChimba_KNB
Cool. Wanna do it on my 250r
VictorChimba is offline   Reply With Quote
Old June 2nd, 2015, 12:52 PM   #5
slolane
Motorcyclist
slolane's Avatar
Thank you.
On my 250's I bought a bracket sold my another Ninjette forum member, back in like 2010, I can't remember his name. It was a perfect fit and mounted it on the inside of the upper right fairing. He provided a bracket and bolt that mounted right up to an empty threaded hole. Maybe someone else remembers him/his name and could help direct you if he's still around.
Old June 2nd, 2015, 04:42 PM   #6
slolane
Motorcyclist
slolane's Avatar
I looked it up and found I bought the bracket for my 250 from kevlar250, his pics are still up...
http://s678.photobucket.com/user/ron...view=slideshow
Hope that helps.
Old June 2nd, 2015, 04:47 PM   #7
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Nice job on the bracket, James! It's a work of art.
Old June 2nd, 2015, 06:45 PM   #8
VictorChimba
VictorChimba_KNB
Hope that helps.
Wow. Thanks a lot man!
Old June 3rd, 2015, 06:21 AM   #9
slolane
Motorcyclist
slolane's Avatar
Thanks, I got lucky on this one.
You are welcome, not sure if he is still around but even if not you have some photos to go on for your install.
Old June 3rd, 2015, 06:54 AM   #10
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
air horn too
I have the same air horn.. makes my Ducati Monster S4 much cooler..!!!
it is so loud I started using hearing protection more often... LOL
I do not have it on my track 250...
by the way, great mod as you make it look clean.. sweet job.
Qomomoko is offline   Reply With Quote
Old June 3rd, 2015, 11:32 AM   #11
slolane
Motorcyclist
slolane's Avatar
Ohhh, I love Ducati Monsters, some friends have em, fun bikes.
I hear ya (pun intended) on the hearing protection, my new helmet is pretty quiet so I'm good as is but it is loud.
LOL, put one on your track bike! In a battle to pass someone just lay on that bad boy.
Old June 3rd, 2015, 12:33 PM   #12
Ghostt
Ghostt's Avatar
On my PreGen I mounted it to the stock OEM horn bracket, just had to bend it. It peeks out under the front fairing facing forward, so the sound is aimed straight ahead. The relay is mounted on the backside of the bracket.
A worth while investment for sure, I would personally recommend it to anyone.
violente et ignorantia
ZX-2R BLOG
Old June 3rd, 2015, 01:40 PM   #13
slolane
Motorcyclist
slolane's Avatar
Nice Ghostt, well done!
Old June 3rd, 2015, 03:36 PM   #14
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
@Ghostt should the air horn be angled lightly? that way the air horn would be fighting less air pressure while moving? Just a thought.
My Cafe Racer Build
My intro post
Old June 3rd, 2015, 03:43 PM   #15
Ghostt
Ghostt's Avatar
Good question, I have no idea LOL.
I would be hopefully it is in a low pressure area where it is
ZX-2R BLOG
Old June 10th, 2015, 10:55 AM   #16
reggae5
reggae5's Avatar
Motorcycle(s): 2013 Ninja 300
With a little bit of cutting on the inside shield I mounted mine using the existing flange on the radiator.
reggae5 is offline   Reply With Quote
FS: Deluxe Wiring Kit for Stebel Nautilus Compact Air Horns tagged "motorcycle" 7 tim Amazon Postbot Amazon - Popular Motorcycling Items 0 October 30th, 2013 07:00 PM
FS: Stebel Nautilus Compact Motorcycle Air Horn - Loud - Chrome tagged "motorcycle" 1 Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
[twisted throttle] - Honda VT750 Shadow Aero (2004) with Stebel Compact Nautilus Air Ninjette Newsbot Motorcycling News 0 March 1st, 2012 09:20 AM
[twisted throttle] - Stebel Nautilus Air Horn installed on a 1994 Yamaha Vmax Ninjette Newsbot Motorcycling News 0 September 22nd, 2011 01:40 PM
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn FrugalNinja250 1986 - 2007 Ninja 250R Farkles 8 June 23rd, 2011 05:37 AM
