April 19th, 2012, 07:34 AM | #1 |
Tachometer not working or going crazy
Hey this site is really useful and has answered most of my ninjette questions but a search hasnt really found an answer to my current problem.
My tachometer sometimes just sits at zero rpm even though the engine is revving properly. At other times whilst at speed, it'll move past the redline and fluctuate between 7000rpm to past red line. The engine rpms are fine. If i blip the throttle, the tacho will jump 4000rpm even though in reality it only increases a little. Any idea what is wrong or what can be done to fix this?? Many thanks in advance! |
April 19th, 2012, 09:30 AM | #2 |
Join Date: Sep 2011 Motorcycle(s): 2011 Ninja 250R SE Posts: 78
Has it been raining recently? Sounds like water has gotten into the tach and causing the power or ground to go crazy. It happened on my bike. Dry it out and it should return to normal.
April 19th, 2012, 09:39 AM | #3 |
Jigglin' your Jiglets
MOTM - Apr '13
You might need a new battery
April 20th, 2012, 06:00 AM | #4 |
Yeah it has been raining. It dried out today and worked normally for most of the ride, but at one stage i noticed that the tacho did not work at all. it just sat at 0rpm. could this mean a new battery is needed?
April 20th, 2012, 06:06 AM | #5 |
My old 92 did this. New battery and cleaned terminals and problem was solved. Not sure which fixed it for me. Check yours and let us know please.
April 30th, 2012, 05:48 AM | #6 |
My tachometer has acted like that when I ran the battery completely dead and pop-started it and it has acted similarly when condensation formed inside.
April 30th, 2012, 06:17 AM | #7 |
Your symptoms and remedy may lie in here- http://www.ninjette.org/wiki/Battery
"- if your lights on the Ninja 250 begin to flicker or your gauges or engine speed start to act erratically, check your battery connections" You also may want to check your tach connections. |
September 1st, 2014, 08:46 PM | #8 |
Join Date: May 2013 Motorcycle(s): 10 Ninja 250 Posts: 172
Bump for this...
Ive been experiencing this for the past few rides. I got worse today almost to the point where the throttle no longer worked. I noted that in neutral the light was not super bright green, more like a dull green. So i bumped my butt on the seat to hit the battery and the neutral green turned bright again. It did this intermittently till I got home. I popped the seat off to discover the ground terminal screw was loose. I tightened it up and hopefully it shall fix my problem. |
September 1st, 2014, 09:11 PM | #9 |
Tighten it with a socket or wrench; not just a screwdriver. Loose battery connections cause all kind of ills, and it's not uncommon for them to rattle loose if not torqued properly.
Tachometer options | Konaunit1 | Ninjettes At Speed | 30 | July 22nd, 2014 03:39 PM |
tachometer issues | 00NissanNinja | 2008 - 2012 Ninja 250R Tech Talk | 11 | July 12th, 2012 02:14 AM |
Tachometer Accuracy | longhorn | 2008 - 2012 Ninja 250R Tech Talk | 2 | January 4th, 2012 09:10 PM |
Inaccurate tachometer? | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 28th, 2011 07:17 AM |
09 ninja tachometer | kyle98927 | 2008 - 2012 Ninja 250R Tech Talk | 9 | June 30th, 2009 10:12 AM |
