Old June 11th, 2012, 08:14 PM   #1
SmithSwede
Motorcycle(s): 2007 BMW F800S; 2012 Ninja 250; 2013 Moto Guzzi V7 Stone, 2016 Triumph Street Triple Rx; 1996 Ducati 900 SS CR
Gas Mileage: New vs Old Gen
I gather that the old gen Ninjas get consistently better gas mileage than the new gen. Is there any consensus about why that is?
I know the new gen engine was modified a bit to favor the mid range, but I would think that would benefit the new gen's efficiency in normal riding. Is it the catalytic exhaust on newer Ninjas? Richer carb jetting from factory? What?
I have a 2012 with about 4500 miles. I'm getting about 43-46 mpg on my daily commute, which is 90% interstate and fast surface roads, cruising approx 65 to 70+ mph. It jumps to 55 mpg when I run 55-60 mph on same route when it's raining. Have not tried the 15 tooth front sprocket.
Not complaining--just curious. Bike has **deeply** impressed me in many ways, but it is not getting the crazy high gas mileage I had read about. And yes, everything is adjusted right--clean air filter, carbs balanced, good plugs, loose valve clearance, correct tire pressure, etc.
SmithSwede is offline   Reply With Quote
Old June 11th, 2012, 09:12 PM   #2
gitoy
Motorcycle(s): 04 ninja 250, 05 zzr 600 (sold), 07 cbr600rr
i have an 04 with a 15 tooth and i consistently get over 60mpg...i commute and hit the twisties about half and half...
the new ones are slightly heavier so that is one factor for lower mileage...
gitoy is offline   Reply With Quote
Old June 11th, 2012, 09:20 PM   #3
AlanDog
AlanDog's Avatar
Motorcycle(s): 2019 Ninja 400, 2009 KLX250-SF, 2014 Zero S
I have an pregen and what I notice is the huge variation in gas mileage depending on how aggressive I ride. Some people might say 'I'm only commuting', but *how* you commute makes a big difference. I know going 65 mph vs. 80 mph on the freeway makes a huge difference. In fact, I get better gas mileage in the twisties now versus on the freeway, just because I've learned I don't have to totally wind out the engine to get around corners and in contrast I'm going faster on the freeway just because I'm more comfortable going 75 now... YMMV!
AlanDog is offline   Reply With Quote
Old June 11th, 2012, 09:34 PM   #4
MikeJames21
MikeJames21's Avatar
Motorcycle(s): 08 Ninja 250r, passion red
hmmm idk, i get 58mpg all day long on my 08. with a 15t front sprocket, k&n pod filter, full exhaust, stock warm up jet, 110 main jet, tuned w/ a wideband afr meter... i do lots of spirited riding. i shift at 6g, 8g or 12g there is no inbetween lol...
my gf, had an 05, it had pod filter and jetted and it only got 45-50mpg.. she didn't even ride it hard ever.
so, i thought the new ones got more mpg?
My 2Fiddy updated 6-12-12
MikeJames21 is offline   Reply With Quote
Old June 11th, 2012, 11:48 PM   #5
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
what afr meter do you have on there?
is it hard to install?
PsHYk is offline   Reply With Quote
Old June 12th, 2012, 09:06 AM   #6
SmithSwede
Yes, I'm curious about the air fuel meter as well, because I wonder if an aftermarket exhaust might improve my mileage. If the thing is set up too rich for large throttle openings, maybe the extra flow would lean things out and improve mileage.
But don't want to lean it out too much--would be nice to know for sure that the thing is jetted properly.
Old June 12th, 2012, 12:42 PM   #7
Bill N
Motorcycle(s): 250 Ninja
On my 2008 I get a solid 58+ MPG on my commutes which is 50% stop and go traffic. If I cruise on the hwy at 60 MPH I get 60+ MPG. Cruising at 65 to 75 yields lower 50's. It's a stock bike/standard gearing.
Bill
Bill N is offline   Reply With Quote
Old June 12th, 2012, 12:46 PM   #8
MikeJames21
i have an innovate mtx-l wideband. $168.95 shipped
to install it, you have to drill a hole in your exhaust, weld a bung in, run the wires, and hook up a power and ground. i have mine tapped into my cig lighter to charge my phone, which is ran straight to the battery with a switch to turn it on and off.
here's some good info for those wanting to know more.
http://www.ninjette.org/forums/showthread.php?t=79223 <- post 12 has a few links w/ good info.
http://www.ninjette.org/forums/showthread.php?t=36042 <- has a youtube video and a afr chart
good luck guys!
Old June 12th, 2012, 12:58 PM   #9
jjb84
Motorcycle(s): 2009 Ninja 250
i have the same issue.
Out here in cali, commuting on the freeway consists of basically a minimum of 80mph speeds. with that, i basically get less than 50mpg.
I tried doing the 65mph thing, and did get around 65mpg. So yes, if commuting means "higher speeds", your gas mileage suffers.
Thinking about getting the 15T too. Anyone have any links or brands/names to look at? Considering buying it this week.
jjb84 is offline   Reply With Quote
Old June 12th, 2012, 01:07 PM   #10
MikeJames21
18.25 shipped on ebay for a JT 15t, just got mine a couple weeks ago. shipped fast. easy to install, especially if you have an impact... the how to says it's a pain to get off, you have to use a board to hold the wheel, yadda yadda, no.. just zip that sucker off w/ an impact, piece of cake.
Gas Mileage: Beyond the Basics tnr4 General Motorcycling Discussion 39 July 28th, 2013 09:08 AM
Low Gas Mileage, why? Dhillon92 2008 - 2012 Ninja 250R Tech Talk 32 July 27th, 2013 04:51 PM
Impressive gas mileage A7xschecter6661 General Motorcycling Discussion 12 October 10th, 2011 01:57 PM
New Gen Tire Mileage Nemy 2008 - 2012 Ninja 250R Tech Talk 66 November 8th, 2009 06:07 PM
gas mileage motorcycle_munge General Motorcycling Discussion 23 May 16th, 2009 01:54 PM
