Old June 15th, 2012, 12:31 AM   #1
Luvninja
Luvninja's Avatar
Motorcycle(s): 05 Ninja 250
As ninjette users requested. Info on ninja mod (picture heavy)
I found enough time to write up some info about my modded pregen ninja 250. First a little background story
Why did I change the look you ask, Well once upton a day I thought I'd take a small trip following some "scenic roads" sign in my town. I basically just followed the signs for about 100 miles or so until I got lost and tried to come back home. Once I knew where I was I decided to make a quick stop by a bridge I had seen earlier so I could snap some pics... Bad idea, I parked on a small incline and when I came back to get on, the bike tipped over, RIGHT INTO A POLE! Scratched tank and dented it. All that was affected was the tank and I ended up changing the WHOLE bike
BEFORE PICS
DENT THAT STARTED IT ALL
Winter came around and I had my chance to do to my bike what I always wanted, make it my own, unique. All the fairings were in great shape so I purchased a whole set of fairings and tank for close to nothing. I took the dented tank to a shop and had them fix it. Meanwhile I stripped my bike down and started sanding down the fairings.
There are no pictures of the process of the modded front fairing. But I think everyone can get the idea with the following pictures. This was done with fiber glass and some Bondo to smooth things out. To put the new headlight in there obviously needed to be things cut and added.
Now the next big thing was that the headlights are too wide to fit between the current mounts for the stock headlight. So they needed to go, I ordered another headlight bracket and swapped them (I like having the extra, non modded, original pieces). I cut the mounts and also had to cut the mounts for the mirrors (red).
Now you are probably wondering how I mounted the headlight onto the bike. Well I didn't and haven't. With the mounts on the bracket cut, it left a nice smooth surface for the back of the headlight to rest on (green) and it doesn't fall trough the bottom because it sits ontop of the mounts where the fairing attaches to the bracket (White). The fairing fits pretty snug on the headlight also, so it keeps it from moving at all. I plan on fixing up something where it actually bolts onto the bracket.
Next I changed up the turn signals. I decided I wanted something different. So I smoothed out where the stock signals go and cut out the shape for the ZX14 turn signals that I ordered from Ebay. I had to fill in some cracks with fiberglass and it was a pain in the ass, especially when I realized that the back of the turn signals were so f*cking big that it interfered with the forks, when I turned it would hit pretty bad. So I took the lights apart and just used the cover of the headlight, bulb assembly and wires and crafted my own back and mounts for it.
CZroe asked
Originally Posted by CZroe View Post
I plan to mount them along the front edge where they always go on OEM bikes (probably DOT requirement; can more easily be seen from side + front). Any reason why you chose to mount there instead? Will I have issues mounting where I want?
I don't have a good reason of where I mounted them other than I didn't want to try to even that whole part out and then cut out another spot. I was lazy basically Which in the end, was more work. I think how you want it to be will be better because the backing of the signals won't hit anything. You might actually get to use the whole thing you paid for, cause I didn't ! HAHA
So then I painted everything.
Then put everything back on my poor naked bike, that by this time was naked for 2 months.
Put some tinted brake and turn signal covers
And where did I get the windscreen? Same one, except it's under the fairing but had to be cut shorter to fit. Also the "dash" had to be shaved a bit, so the windscreen could fit.
After that ALL DONE!
P.S I have no clue how the headlight is wired, I had a professional deal with that.
During this whole time I had no clue what I was doing... Never painted a vehicle before (unless you count a scooter @ age 12 with spray paint... started chipping within a week). Never really worked with fiberglass, I basically got lucky. It's not perfect but I'm pretty damn happy with it.
Next project... make it better. Aside from all the original fairings I have another set which I plan to mod a tiny bit differently
Oh yea, I'm a girl BTW. I keep getting refered to as a HE on here
Last futzed with by Luvninja; June 19th, 2012 at 02:28 PM.
Luvninja is offline   Reply With Quote
Old June 15th, 2012, 12:37 AM   #2
Avenged7Fold
Ninjette Noob
Avenged7Fold's Avatar
Motorcycle(s): 2004 YZF-600r ---- 2006 Kawasaki Ninja 250r
I'll admit, I'm tired and I didn't read a word you said. With my picture book reading abilities, I will say that it looks very good now. Great work
Avenged7Fold is offline   Reply With Quote
Old June 15th, 2012, 12:47 AM   #3
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
that's actually interesting
ninja250r81 is offline   Reply With Quote
Old June 15th, 2012, 06:16 AM   #4
Thanks for the detailed post, Gabriela.
What brand and type of headlight did you use?
Old June 15th, 2012, 06:48 AM   #5
flynjay
flynjay's Avatar
Great work!
What did you use for paint?
I'm just about to start painting mine. I'm thinking rustolem thinned and sprayed through a gun (if I can find a color i like).
Old June 15th, 2012, 06:56 AM   #6
315kid
315kid's Avatar
Motorcycle(s): 2005 kawi 250r
Lol when i see Gabriela I think "omg that is the coolest guys name ever"
Smmmmmoooooooooth
315kid is offline   Reply With Quote
Old June 15th, 2012, 08:11 AM   #7
Momaru
Momaru's Avatar
Looks like the OEM new-gen headlight
Love the mods Gabriela, they look sharp and definitely alter the look of the bike. I never would've guessed it's your first time with fiberglass & essentially so with paint.
Proud member of the Blue Army
Old June 15th, 2012, 10:56 AM   #8
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
You need a girly avatar that's why like @ally99
AFM #676
Supersports are for n00bs
Old June 15th, 2012, 11:33 AM   #9
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
Your name was my first clue, but I guess I just see the obvious... LOL
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old June 15th, 2012, 01:56 PM   #10
That's because we are all sexist and unable to believe that a woman could possibly pioneer a DIY.
But, seriously: Nice job! Ultimately, I hope to get away with using the stock headlight, but almost all of this is relevant to what I want to do (especially the fiberglass work).
OK. Where do I buy FG and how do I use it? I don't have a clue! I have some ancient FG curtains (cloth) I could cut up, but what do I use to harden it and, if it's not appropriate, where did you buy the right stuff? Does it adhere to ABS well? Can I use it along with ABS cement and Bondo to repair seriously damaged ABS fairings?
How is the aim? Is it still adjustable?
Next I changed up the turn signals. I decided I wanted something different. So I smoothed out where the stock signals go and cut out the shape for the ZX14 turn signals that I ordered from Ebay. I had to fill in some cracks with fiberglass and it was a pain in the ass, especially when I realized that the back of the headlight was so f*cking big that it interfered with the forks, when I turned it would hit pretty bad. So I took the lights apart and just used the cover of the headlight, bulb assembly and wires and crafted my own back and mounts for it.
Wait. Are we talking about the turn signal housings or the headlight housing? If you have pics of the signal mounting, I'd love to see it. My only idea was hot glue.
I plan to paint right over the windscreen. Would it be difficult to use FG to smoothly blend the windscreen into the fairing?
OK, this is getting freaky. That's another similarity with my project that I didn't know about until after I ordered mine!
That said, it is VERY hard to find a cheap smoke brake light lens now! Most places are out of stock and the ones that still have it seem to know what they have: a discontinued/rare and valuable item. I noticed that an eBay seller had two listings for blue brake light lenses and, sure enough, one was supposed to be smoke. There were only two left and shipping was almost a deal-breaker, so I ordered the last two. I'm sure someone will be looking for it, so I can make a little money to put toward mine and they will save a little (split the difference).
Edit: Awesome! My smoke turn signals have arrived along with my new anodized footpegs. The signals are a lot larger than I thought. I know Lockhart Phillips sells some ZX14/EX650 replacements that are lower-profile (don't pop out as far; they call it "Euro"), but I did not realize that the triangular dimension covered so much area. These are going to look nice! These things are freakin' hard to remove the bulbs on. It seems to be from imperfections in the mating plastic, which the original signals probably didn't have.
Last futzed with by CZroe; June 15th, 2012 at 03:54 PM.
Old June 19th, 2012, 02:27 PM   #11
Luvninja
Luvninja's Avatar
I found FG at my local auto shop. It said how to mix it. I recommend youtube videos.
There's a knob on the back of the headlight that adjusts the beam of light.
And I was talking about the turn signals... Ooops, I'll fix that.
I mounted the turn signals by using some small screws, screw bolt and plastifix. I put the screws head against the fairings (treads up) and secured it by using plastifix. Basically plastic once it cures. Then I drilled some holes on my makeshift back panel for the turn signals, put the treads through the hole and then screwed on the bolt. I will get pictures of it someday...
Be sure to post up some pics of your bike when your done.
Old June 19th, 2012, 02:31 PM   #12
Stingray1000
Gabby, You should trade wif me
Old September 5th, 2012, 10:00 PM   #13
@Luvninja do you have your oem headlight still?
Old September 6th, 2012, 12:16 AM   #14
Luvninja
Luvninja's Avatar
Yup, I try to keep all the original parts of my ninja.
Old September 6th, 2012, 03:25 AM   #15
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
Can you take more photos all around the new look?
Yasko is offline   Reply With Quote
Old September 6th, 2012, 06:22 AM   #16
Would you be interested in selling your stock headlight or are you looking to keep it just in case?
http://www.ninjette.org/forums/showthread.php?t=113490
Old September 10th, 2012, 08:01 PM   #17
Luvninja
Luvninja's Avatar
I'll see if I can get out tomorrow and take all around shots of the bike.
Yea I'm just going to keep it around just in case. If something happened to the new fairing I'd have to put on the original headlight until I fixed it or made a new one.
Old September 10th, 2012, 08:10 PM   #18
understandable, no worries!
Old September 28th, 2012, 02:48 PM   #19
Aeather
Motorcycle(s): 2005 250R Ninja
I have a question. For the front fairing and headlight. Where did you buy the head light and fairing? Did you also buy all new 08+ fairings or just the front fairing and headlight?
Aeather is offline   Reply With Quote
Old September 28th, 2012, 04:47 PM   #20
Luvninja
Luvninja's Avatar
I bought the headlight used from craigslist but the fairings are NOT from a new gen. The front fairing is just modded.
Old September 29th, 2012, 06:18 PM   #21
Aeather
Ah. How much did the head light cost you? And the front fairing is stock then? Well was stock.
Old September 29th, 2012, 06:24 PM   #22
Luvninja
Luvninja's Avatar
the headlight cost me like $90. and yes it was stock.
Old October 1st, 2012, 05:53 PM   #23
Aeather
And then how did you modify the head light to have that "triangle" added onto the fairing?
Old October 1st, 2012, 08:39 PM   #24
The rest of the updated look comes from the windscreen being mounted underneath.
Old October 1st, 2012, 11:54 PM   #25
Luvninja
Luvninja's Avatar
I know it's long, but my first post (at the top of the page) gives a pretty good idea of how it was done.
Old October 9th, 2012, 02:58 PM   #26
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
Wow, Gabliela, nice work!
250rr is offline   Reply With Quote
Old February 6th, 2013, 01:45 AM   #27
ninjaryda
ninjaryda's Avatar
Motorcycle(s): 2007 250r
So the headlight is from a newgen 250?
ninjaryda is offline   Reply With Quote
Old February 6th, 2013, 04:05 AM   #28
psych0hans
psych0hans's Avatar
Fantastic job done!!! Gabriela is a very pretty name and now you have a pretty bike to boot... Lol cheers!!!
Old February 6th, 2013, 11:15 PM   #29
Luvninja
Luvninja's Avatar
It was from a 2009 ninja 250
Old February 6th, 2013, 11:17 PM   #30
YunMing
Motorcycle(s): (Sold) 2007 Red Ninja 250r, 2003 Cbr 600 F4i
Have you worked on your next project yet
YunMing is offline   Reply With Quote
Old February 6th, 2013, 11:36 PM   #31
Luvninja
Luvninja's Avatar
Unfortunately no, I have a whole set of fairings waiting to be modded and no time. With work and finishing up my last few quarters of pre reqs for nursing I just don't have much time. But hopefully this summer I can get something done. I'd like to have the time to sketch something out, just something simple but different than what I already have.
Old February 6th, 2013, 11:39 PM   #32
YunMing
Interesting i'd like to see what you do next.
Old May 28th, 2014, 02:25 PM   #33
Hero Danny
Inline 4!!!
Hero Danny's Avatar
I've been thinking about your headlight mod ever since I first saw it over a week ago. And I feel like I have to ask, has anybody else done this mod? I would LOVE to see a write-up of it. I think the only thing about the old ninja's I don't like is the headlight... And it would be a very fun DIY project to fix it.
Be careful. Remember you are
invisible
Old May 28th, 2014, 05:24 PM   #34
misfitsailor
Ninjette Jockey
misfitsailor's Avatar
Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP
Awesome Job! Now you have something really unique!
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?.
misfitsailor is offline   Reply With Quote
Old May 28th, 2014, 05:44 PM   #35
Finally ordered everything I think I need to get started. Not sure how I'll duplicate her windscreen mod without knowing how to do fiberglass bodywork but I will try!
Old May 28th, 2014, 05:48 PM   #36
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Oh man, I think I love you. Please let me know how this turns out. A good step by step write up or a video would be awesome!
invisible
Old May 28th, 2014, 06:13 PM   #37
I'll capture as much as I can with my wearable Looxcie camera but that doesn't mean I can edit it we'll enough to be watchable.
Last futzed with by CZroe; June 9th, 2014 at 05:58 PM.
Old May 28th, 2014, 07:13 PM   #38
Hero Danny
Inline 4!!!
Hero Danny's Avatar
It's fine, even if you could just do a thorough write up that tells us exactly what we need and what to do, that would be excellent!
-Also pictures are a huge help
invisible
Old May 28th, 2014, 07:14 PM   #39
Hero Danny
Inline 4!!!
Hero Danny's Avatar
invisible
Old May 28th, 2014, 08:22 PM   #40
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
You dug up a pretty good thread! Looking forward to updates.
The Bike | The Truck
iplante's 2013 Ninja build (Picture heavy) iplante 1986 - 2007 Ninja 250R Farkles 62 May 20th, 2014 08:48 AM
Ninjette users vs fixer uppers IF13 General Motorcycling Discussion 7 October 13th, 2013 07:06 PM
Hello Kitty tank bag! (picture heavy) mcnuggett Cargo Space 56 April 16th, 2013 07:50 PM
I tooked Peektures of Whitey and me! [Picture heavy...] Mr.E Pictures 21 February 8th, 2013 05:23 PM
Scorpion Eternity Jacket Review. (Soon to be picture Heavy.) Mr.E Motorcycle Gear 6 June 4th, 2011 11:42 PM
