Old June 30th, 2012, 03:59 PM   #1
arnoldc6
arnoldc6's Avatar
Motorcycle(s): 09 ninja 250r
bad battery or simply bad posture?
I have this habit or starting the engine before I retract the kickstand and let it warm up for a bit. But when i was starting it up yesterday (with kickstand down), it gave absolutely no respond. None of the indicator lights lite up , and the push start button wasn't responding either. However when i sat on it and straighten it up, everything works like normal again.
Prior to this, once in a while when i am starting it up, the lights (headlight and indicators) sometimes do flash a bit.
I always keep my gas tank at least 1/4 full so it should has anything to do with gas level.
Does it sounds like a battery problem to you guys? I am very new to riding so right now i have no idea what to do.
arnoldc6 is offline   Reply With Quote
Old June 30th, 2012, 04:02 PM   #2
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
You sure you didn't just forget to disengage the engine kill switch?
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Old June 30th, 2012, 04:06 PM   #3
Check the connections to the battery. Loose?
Old June 30th, 2012, 04:29 PM   #4
arnoldc6
arnoldc6's Avatar
lol i did do that a few time but that shouldn't be long enough to drain the battery..
thanks for the advice cs. I am gonna go work on the connections when i receive my tool kit- wouldn't get it till two weeks later.
Old July 1st, 2012, 09:27 AM   #5
edxmon
edxmon's Avatar
Im not sure what a drained battery has to do with anything. All you said is that when you try to turn it on without sitting on it it won't start, while if you sit on it it start up fine. If the battery was drained it wouldnt turn on no matter what.
You either have a faulty contact of forgot to to disengage the kill switch. Also, the headlights dimming while you try to turn it on is normal to a certain extent and the current draw is greater than when the bike is running.
Old July 1st, 2012, 10:37 AM   #6
This
Bad Fork Seals or Bad Bushings? Jono General Motorcycling Discussion 5 March 26th, 2015 08:12 PM
Bad driver & bad rider. Guess who gets hurt... akima Videos 27 July 12th, 2013 12:26 AM
Lane splitting.... bad bad bad oblivion007 Videos 29 May 8th, 2012 11:42 AM
good and bad tire - or good and bad riding? Domagoj Riding Skills 11 September 17th, 2010 07:30 AM
[superbikeplanet.com] - How Bad Is The Melandri Situation? This Bad. Ninjette Newsbot Motorcycling News 0 June 12th, 2008 01:11 PM
