August 31st, 2012, 02:41 AM | #1 |
Join Date: Dec 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R Posts: 23
Starter problem?
Hi guys,
When I start the bike each morning or when it has not been used for some time this happens: 1. Insert key 2. Turn on the bike 3. Turn on the engine kill switch 4. Press my thumb on the starter button And ... What i hear is a faint KKkkkksszzzkzzz sound coming from somewhere under the seat ( not really sure ) and it takes about 3 to 4 seconds before the starter starts to crank the engine. What could be causing this? Battery needs replacement? Charger not working properly? |
August 31st, 2012, 04:38 AM | #2 |
Clean and tighten your battery connections. Check to ensure nothing is shorting out or pinched.
Should be a simple fix.
Starter Relay/Starter Problem | Time Mage | 1986 - 2007 Ninja 250R Tech Talk | 13 | July 13th, 2012 05:02 AM |
Electrical Problem with brakes/starter | d.c.george | 2008 - 2012 Ninja 250R Tech Talk | 15 | June 16th, 2012 11:04 PM |
