Old September 6th, 2012, 05:02 PM   #1
Mbomb
Motorcycle(s): Ex-250r
Oil change question
After doing an oil change I put 2quarts in watching the level in the view circle as I did so. After 1.7 quarts the circle was full and I started the bike. The oil light went off but watching the level in the circle it went down to the point you couldn't see any oil. So I added the rest of oil essentially adding 2 quarts total oil. The level in the circle went up til I started the bike again. It dropped a little and now it is only filling up the bottom 1/3 of the view circle. Does it need more oil? The oil cap says 1.9 L which is little less than 2qts. There are no leaks that I can see. Thanks.
Mbomb is offline   Reply With Quote
Old September 6th, 2012, 05:12 PM   #2
when the engine runs, the oil pump pumps oil from the bottom crank case into the internal passages of the engine and up into the head.
check the oil level with the bike completely level when the bike is cold and not running
Old September 7th, 2012, 03:57 PM   #3
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
oil level needs to be check when engine is not running. bike must be completely level
broilmebk is offline   Reply With Quote
Old September 7th, 2012, 04:44 PM   #4
Old September 7th, 2012, 05:53 PM   #5
post whore
Old September 8th, 2012, 12:08 AM   #6
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
post whore
Crash whore
AFM #676
Supersports are for n00bs
oil change - question! vmlp 1986 - 2007 Ninja 250R Tech Talk 5 June 5th, 2012 08:04 PM
oil change question ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 8 April 19th, 2012 06:46 PM
Oil change question. Will this work? kaiserz 2008 - 2012 Ninja 250R Tech Talk 3 May 2nd, 2011 06:45 PM
I did my 1st oil change question! Duvivr6 2008 - 2012 Ninja 250R Tech Talk 19 July 7th, 2009 08:19 AM
Oil change question JCCJMM_ 1986 - 2007 Ninja 250R Tech Talk 4 December 4th, 2008 05:38 PM
