Old October 4th, 2012, 06:33 PM   #1
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Bike not wanting to rev past ~5k while driving
So I'm just driving along just fine and all of a sudden my bike gets this bogged down sound and it won't go past 5k rpms in any gear, as if the rev limiter is kicking in. I did get it up to 7k on a long straightaway but very briefly. I looked at the spark plugs and they look fine. I put a new fuel filter on tonight and rode it (after the problem started; old filter was warped), same problem (slightly better). I synced the carbs because I was planning on that anyways as well.....
The bike DOES however, redline in neutral! Not sure if it does with the clutch pulled in while in gear though........ The oil was topped off before I rode and I got a good 40 miles in before the problem started happening..... any ideas?
Old October 4th, 2012, 07:41 PM   #2
What else has changed? New exhaust? Check airbox and filter. Did the bike sit for a while?
Old October 4th, 2012, 08:01 PM   #3
FvnnyL3tt3r1ng
Nothing really. I drive this bike every day.
Old October 4th, 2012, 08:03 PM   #4
Bad tank of gas?
Old October 4th, 2012, 08:06 PM   #5
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Did you check your air filter?
AFM #676
Supersports are for n00bs
Old October 4th, 2012, 08:07 PM   #6
93etgocart
93etgocart's Avatar
Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250
my cbr did this when the rings blew out. Not saying thats it but just an experience
93etgocart is offline   Reply With Quote
Old October 4th, 2012, 08:36 PM   #7
FvnnyL3tt3r1ng
I didn't. I have a K&N air filter I don't remember how tight of a fit it was....
Old October 4th, 2012, 08:38 PM   #8
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Check it, see if its wet, dirty, or has engine oil in the airbox
AFM #676
Old October 4th, 2012, 08:38 PM   #9
FvnnyL3tt3r1ng
Bad tank of gas?
Never had a bad tank of gas in my life so I wouldn't know what that's like. I just don't get why I can redline in neutral but not in gear while driving........
Old October 4th, 2012, 08:39 PM   #10
Jiggles
Jiggles's Avatar
MOTM - Apr '13
If you were running really rich (clogged air filter) that would be one reason
AFM #676
Old October 4th, 2012, 08:50 PM   #11
If it sounds funny, and suddenly has half power, it sure seems like you're running on only one cylinder.
Old October 5th, 2012, 01:03 AM   #12
FvnnyL3tt3r1ng
I think so too but why
Old October 5th, 2012, 03:43 AM   #13
Mice build a nest in the airbox? Sounds like a starvation problem, gas or air. My vote is on gas.
Old October 5th, 2012, 10:22 AM   #14
FvnnyL3tt3r1ng
Checked air filter and it looked fine.
Is it possible that something in the fuel line clogged the carbs?? It happened while I was driving....
Old October 5th, 2012, 10:33 AM   #15
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
Plugged main jet?
Something clogged up one or both?
GeorgeRYoung is offline   Reply With Quote
Old October 5th, 2012, 10:35 AM   #16
Panda
not an actual panda
Plugged up snorkel?
Old October 5th, 2012, 11:32 AM   #17
it sounds like only one of your main jets is clogged.
run it then mist the headers with water. one will boil and evaporate the water instantly while the other will take considerably longer. the one that is cooler is the one you want to look at.
Old October 5th, 2012, 12:10 PM   #18
FvnnyL3tt3r1ng
I take it now would be a good time to learn how to rebuild or at least clean my carbs since the bike is about 12 years old and I'm almost certain has never been cleaned before............
Old October 5th, 2012, 12:45 PM   #19
FvnnyL3tt3r1ng
Glad I chopped my airbox last week.
Old October 5th, 2012, 08:44 PM   #20
FvnnyL3tt3r1ng
When doing the carb cleaning, are there kits I can buy with nice replacement parts such as gaskets/screws/needles/washers? What are the minimum tools needed to do this job? I already have carb cleaner but I'd be up for replacing any o-rings/gaskets if they're cheap enough...
Old October 5th, 2012, 11:08 PM   #21
DaBlue1
DaBlue1's Avatar
Did you by chance remove the carb boots at all? If so, you may want to check them for leaks. Too much air can also cause the symptoms you have.
http://www.ninjette.org/wiki/Troubleshooting_Guide
Poor Running at Low Speed:
Fuel/air mixture incorrect:
Carburetor holder loose
Air cleaner duct loose
Old October 6th, 2012, 11:15 AM   #22
FvnnyL3tt3r1ng
Good point! I have been noticing a little lag in the past month or so though come to think of it because I remember saying to myself that I'd have to learn how to clean the carbs soon.
It still gets me that it won't go about ~5k rpms even in first gear though....but fine in neutral/clutch in
Old October 6th, 2012, 01:33 PM   #23
.....It still gets me that it won't go about ~5k rpms even in first gear though....but fine in neutral/clutch in
Because the engine has lost the torque now.
The resistance of the tires and mass of the bike is enough to move the rpms' back to the zone of better torque (lower rpms').
Did you check if one cylinder is dead (cold)?
Wasn't this the bike having spark only on one side?
Old October 6th, 2012, 03:11 PM   #24
FvnnyL3tt3r1ng
No actually I forgot to try the spray-water-on-the-header method someone recommended but the spark plugs looked fine and idk if this says anything but both the exhausts out of the pipes are coming out (warm). I'm not positive but as I was just removing the air box I think one side of the carbs intake may have been loose...... The airbox also had a little oil on it at the bottom. So the bike puts out the same amount of torque per RPM?
Old October 6th, 2012, 03:12 PM   #25
FvnnyL3tt3r1ng
That wasn't my bike it was member "249cc"
Old October 6th, 2012, 04:05 PM   #26
Check the boots that connect the carbs to the airbox. Are those spring clamps on there good and snug? Are they leaking air? Did they come off completely?
This sounds like the same thing that happened to a friend's bike. The airbox popped off and it would suck under WOT, but we could baby it up to redline with small throttle openings.
and trust me, your bike with make it to darn near redline on one cylinder. It just takes a while. Been there, done that
Old October 6th, 2012, 04:29 PM   #27
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Check electrical connections to the coils. Wiggle the connectors while motor is running, any change and you found the problem.
Old October 6th, 2012, 09:28 PM   #28
FvnnyL3tt3r1ng
I'm looking through my ninja haynes manual, and I see this: "Also make sure that the end of the carburetor vent tube is not placed near the air intake. This will cause fuel starvation, resulting in poor performance above 3,500 rpm and a maximum engine speed of 5,000 rpm." (P. 4-5)
Source: Haynes Service & Repair Manual Kawasaki Ninja 250, Haynes North America Inc, Newberry Park, CA.
Old October 6th, 2012, 09:58 PM   #29
FvnnyL3tt3r1ng
Do I really have to spend $60 to rebuild my carbs??? How in the world is there nothing cheaper
http://www.ebay.com/itm/92-05-KAWASA...f74a05&vxp=mtr
Old October 6th, 2012, 11:24 PM   #30
For $60, just buy a entire new petcock assembly. The rebuild kit is normally ~$30
Old October 7th, 2012, 12:03 AM   #31
FvnnyL3tt3r1ng
I don't follow? Are you recommending I buy a petcock assembly to get more bang for my buck?
Old October 7th, 2012, 08:42 AM   #32
Oh, wow I somehow got it in my head that you wanted to rebuild the petcock and I was suggesting you just replace the petcock instead of repairing it.
I'm sorry about any confusion I caused.
Old October 7th, 2012, 11:09 AM   #33
FvnnyL3tt3r1ng
Np.
Is it possible to POD the bike with stock exhaust and jets or do I have to rejet?
Old October 7th, 2012, 11:14 AM   #34
Stock exhaust, yes. Stock jets, no. You'll likely be running a 108 or 110 main jet with a pod intake and stock exhaust.
If I were you, I'd get your bike figured out and fixed before you start making changes. It's easier not to introduce more variable into the mix when you're fixing things.
Old October 7th, 2012, 07:34 PM   #35
FvnnyL3tt3r1ng
Just got done with the valve clearance for the first time. Glad it's all over and done; I will definitely be buying the kawi tool to do it next time! Hope I did it right I set them all to the looser end of the spec... They were all tight so it needed to be done anyway. Probably the first the bike has ever seen @ 12.5k miles.
Old October 7th, 2012, 07:44 PM   #36
Good! That should help a lot if it's the first one that's been done. Mine always starts better after a valve job.
Old October 8th, 2012, 10:36 PM   #37
FvnnyL3tt3r1ng
Took carbs apart tonight and cleaned them. Looks like there is a tear on the outer rim of one of the diaphrams but I put it back together the best I could and hopefully it will work.
My decelleration cable seems it may be broken as there is no pullback from it at all......hopefully this isn't the case. It can be pulled a couple of inches without retracting any.... I will try the adjustment procedure and hope for the best for that as well.
Old October 9th, 2012, 06:37 AM   #38
Decel cable should be cheap to replace.
There's a DIY from theduck on how to fix those diaphragms. I think that's what's causing your issues. You could try gorilla glue or a bicycle tube repair kit. I'll look around for that DIY for you.
EDIT: I found the DIY for you. http://www.kawiforums.com/ninja-250r...patch-diy.html
Old October 9th, 2012, 09:51 AM   #39
FvnnyL3tt3r1ng
Ok thanks! I'll try this out if my bike still messes up. I'm about to crank it up in a minute actually to sync the carbs but I have to throw a new chain on before I can ride it.
Old October 9th, 2012, 10:16 AM   #40
FrugalNinja250
Fix the torn diaphragm first, it will change everything else. Remember, known problems are the low-hanging fruit and you want to get them *all* out of the way before proceeding to the more complex issues.
08 has low power and will not rev past 10k Donnyd21 2008 - 2012 Ninja 250R Tech Talk 9 September 17th, 2014 06:11 PM
Bike wouldn't rev past 6k, then died 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 9 May 9th, 2014 04:17 PM
Won't rev past 5k :( hoodadooda 2008 - 2012 Ninja 250R Tech Talk 7 December 24th, 2012 08:56 PM
Engine Won't Rev Past 12k fujimumu 2008 - 2012 Ninja 250R Tech Talk 8 May 19th, 2010 03:35 PM
Driving a cage after driving a bike brian997 General Motorcycling Discussion 23 December 21st, 2008 01:01 AM
