November 5th, 2012, 03:10 PM | #1 |
Join Date: Oct 2012 Motorcycle(s): 2012 Kawasaki Ninja 250r Posts: 20
New pics, Clip-ons and Tyga full System w; MGP Growler
Last futzed with by WolfgangCG; November 10th, 2012 at 11:13 AM. |
November 6th, 2012, 04:17 PM | #2 |
fo shizzle!
November 6th, 2012, 06:59 PM | #3 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Stupid question inc....
Does the pipe where it meets the can have the same diameter as OEM? I want to put aftermarket headers on my bike but am trying to find a less expensive alternative than the LeoVince headers. Last futzed with by Panda; November 7th, 2012 at 09:17 AM. Reason: terrible english |
November 6th, 2012, 11:28 PM | #4 | |
The outlet of the header will not meet up with the stock muffler, it is a bit bigger in diameter. I also have the MGP Growler from Hotbodies which I had to custom fit and weld to the header. I don't have the GP Corsa system from Leo Vince. I almost got the Leo system but I like the deeper tone from the Growler, nice thing about the Leo though, it comes with a silencer specifically for that can. Good luck on your mission to find the right exhaust for you. |
November 7th, 2012, 09:19 AM | #5 |
not an actual panda
Thanks for the info! I may have to suck it up and just buy the LV header.
November 7th, 2012, 09:34 AM | #6 |
Buy whatever header you want. Take the pieces to Midas, they can make an adapter.
November 7th, 2012, 11:55 AM | #7 |
not an actual panda
Is it pricey?
November 7th, 2012, 02:00 PM | #8 |
You can also go to NAPA and order the reducer that fits for about $20 or $30 bucks. Just make sure to measure the inlet to the growler and the outlet to the header before you place an order
November 7th, 2012, 02:14 PM | #9 |
Nope, bout $20-$30 bucks.
And I totally forgot about napa having that kind of stuff.
November 7th, 2012, 02:25 PM | #10 |
not an actual panda
Awesome, thanks guys. Definitely my next farkle.
November 8th, 2012, 07:32 PM | #11 |
Just curious but why don't you buy the full system with muffler of TYGA Performance? Is it cost or design? I'd like to know so we can offer something to you guys which is plug and play. We have an exciting new range of mufflers on their way soon which may be of interest.
November 8th, 2012, 07:39 PM | #12 | |
November 8th, 2012, 08:08 PM | #13 |
Thanks for the info Wolfgang. The invoice is for customs purposes so that in countries with import duty they don't get stung too much. Don't worry, you were definitely charged the correct price. Even in Thailand, you can't make a stainless full system for a two cylinder bike for a hundred dollars! Understood if you already bought the Growler that you didn't need another muffler.
November 9th, 2012, 04:40 PM | #14 |
Join Date: Nov 2012 Motorcycle(s): 08 Ninja 250 Posts: 31
can you tell a difference in sound with the tyga headers? i put on my mgp growler today and love it!! haha whats the difference in sound/ if any? thanks!
November 9th, 2012, 06:22 PM | #16 |
You can definitely hear a difference in sound, it has a much more aggressive and deeper tone. You can also feel the difference in performance. I definitely recommend it.
November 9th, 2012, 08:30 PM | #17 |
Our dyno and independent dyno tests show a useful power increase over the stock headers. You can see an independent dynograph here:
http://www.ninjette.org/forums/showt...highlight=tyga http://tyga-performance.com/site/pro...oducts_id=1788 |
November 9th, 2012, 08:41 PM | #18 |
Love my kittehs!
Join Date: Apr 2012 Motorcycle(s): 2011 Ninja 250R SE Posts: 266
On a different note, are those Woodcraft clip-ons? What is the model number or type you used? They look really good on there and were they difficult to install? Price?
November 9th, 2012, 08:58 PM | #19 |
Yes sir, they are Woodcraft clip-ons. If you go to their website and go to clip-ons section just look up the ones that specifically fit the Ninja 250r. They were $179.99 and they were fairly easy to install. I didn't even think of taking pics during the install, that's my bad. You do have to drill a hole in each handle bar. Use a measuring tape and the stock handles to match up the holes. Make sure to line up everything correctly so that when you turn the bars at full lock that nothing rubs. There is very little room so be sure to check everything before you tighten everything up and use lock-tite. They do look and feel great, haven't been able to go for a decent ride since the install due to a surgery that I had on Tuesday but I can't wait to get back on.
November 9th, 2012, 09:11 PM | #20 |
Love my kittehs!
Thank you very much sir!
November 9th, 2012, 09:16 PM | #21 |
No prob, good luck, enjoy and ride safe
November 20th, 2012, 08:36 PM | #22 | |
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250R Posts: 72
November 20th, 2012, 08:39 PM | #23 | |
November 20th, 2012, 10:08 PM | #24 | |
There you will find the header that I purchased, I did not want to give up my Growler either. The job that i did is not necassary, but I did not want to wait and order a reducer so I took my header and the Growler after I test fit them to make sure how the Growler would sit on the header to a custom exhaust shop and had them blow up the end of the header a bit, add a small sleeve of 2" pipe over the end of the header and weld it, then I got them to weld the Growler to the new end (homemade reducer) and sounds great with no leaks. I gave the guy $50 for his time and labor. There is deffinitely an increase in power in the low and mid range, but I would advise you to get a jet kit, a K&N air filter and remove the snorkel. That is how i set mine up and it wants to go, throws me back slightly, that is why i got the race clip-on handlebars to lean in a bit more. You will feel a difference and if you like the Growler now you will love the sound you get with the Tyga header. Enjoy and let me know if you end up going with that option and what you think. |
Room for Ninja 300 clip-ons - lots of pics | adouglas | 2013 - 2017 Ninja 300 Tech Talk | 36 | August 28th, 2013 12:29 PM |
Full Exhaust System on a MGP Growler, possible? | SSANGHA | 2008 - 2012 Ninja 250R Tech Talk | 18 | November 7th, 2012 04:27 PM |
Tyga vs AreaP full system | 675Raisinator | Ninjettes At Speed | 20 | February 8th, 2012 09:12 AM |
