November 15th, 2012, 11:09 PM | #1 |
clean carbs?
So I am guessing I need to clean the carbs.
The Ninja ended up sitting for a few weeks, only a month at most. When I started it up again it was not doing too well. It would start revving go up to like 3k then back down to about 1k, and it would just keep doing this. The only way I could get the bike to run was to keep the choke fully open. So I thought the gas might have gone bad, but it had only been a month. But I removed the gas and ran the bike until it went kaput. Then put in new gas with stabil and sea foam. Yet now it is still doing the same. The bike will rev up really high when it gets warmed with full choke but as soon as I back down even a little the bike basically just dies. It is a 2012, with only 1500 miles on it. I am guessing that I need to clean the carbs, just wanted to double check before I started digging in there. |
November 15th, 2012, 11:10 PM | #2 |
Yes, clean the carbs.
When in doubt about odd starting/idling/running issues after sitting, clean the carbs |
November 15th, 2012, 11:59 PM | #3 |
Have you ridden it yet? Sometimes it needs nothing more than a decent 30+ minute ride to clear out what ails it. Idling it or even revving it with no load in neutral doesn't do the trick.
November 16th, 2012, 06:10 AM | #4 |
I posted in another thread just a day or so ago that I hadn't ridden mine in 1.5 months. And boy or boy... it was harder to start and it run like crap for the first 20 mins or so but after that it was all good. I hope your luck is similar.
November 16th, 2012, 06:30 AM | #5 |
well i will try to give it a run, but it is getting really cold around here.
November 25th, 2012, 01:07 PM | #6 |
If you are planning on letting it sit all winter don't bother cleaning the carbs til spring. Because likely you'll have to do it again then anyway. Find a shop that has an ultra sonic dunk tank, they clean carbs better than anything I've seen.
November 25th, 2012, 09:52 PM | #7 |
Or just buy some stabil and stabilize the gasoline in the tank.
December 2nd, 2012, 12:06 PM | #8 |
putting stabil in won't help if the carbs are ALREADY dirty, it's a preventative not a cure.
December 2nd, 2012, 02:12 PM | #9 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
The Sea Foam does help.
If you pull it apart a soak in Pine Sol is awesome for cleaning gunk out and off carbs. I'd run that tank of sea foam thru it first though. |
I think I need to clean my carbs.. | Hero Danny | 1986 - 2007 Ninja 250R Tech Talk | 44 | June 9th, 2014 02:06 PM |
How to clean carbs with a fuel treatment/seafoam?? | Floki | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 19th, 2014 12:24 PM |
When to clean carbs and Adjust Valves | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 10th, 2013 03:58 PM |
How hard is it to clean the carbs on the ninja? :( NOOB! | drdriftking007 | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 27th, 2012 06:04 AM |
got 250, need to clean carbs...advice please | ryu hayabusa | 1986 - 2007 Ninja 250R Tech Talk | 50 | October 5th, 2010 06:14 PM |
