December 23rd, 2012, 08:07 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2007 BMW F800S; 2012 Ninja 250; 2013 Moto Guzzi V7 Stone, 2016 Triumph Street Triple Rx; 1996 Ducati 900 SS CR Posts: 77
Ninja 300 engine in new gen 250 chassis?
Anyone know if the new 300 engine will bolt right in to a new gen 250 frame? Would be a neat option for those who wear out the 250 engine to simply add a used 300 engine.
December 23rd, 2012, 08:22 AM | #2 |
I don't know.
I believe that the hardest part would be to find a used 300 engine, since there are not as many units rolling as 250s'.
December 23rd, 2012, 10:44 AM | #3 |
The engine is now rubber-mounted so the engine mounts are probably different. They beefed up the frame specifically because the engine is no longer a stressed member of it, so I wouldn't just use the new mounts even if they just bolted on.
Last futzed with by CZroe; December 23rd, 2012 at 08:26 PM. |
December 23rd, 2012, 11:31 AM | #4 |
Def interested in getting a hold of one to see if i can design a frame around it using software.
Do the plated bore engines not respond well to being used as a structural member?
December 23rd, 2012, 11:52 AM | #5 |
What a plated bore engine is?
December 23rd, 2012, 11:58 AM | #6 |
I heard that the bore is plated with a super hard substance, instead of using a metal liner like the 250 motors.
Was wondering if that played a role in the decision to remove it as a structural member.
December 23rd, 2012, 12:00 PM | #7 |
I see, thanks !
December 23rd, 2012, 12:06 PM | #8 |
Jigglin' your Jiglets
MOTM - Apr '13
Yes it will bolt right in, I have tested this. Please buy a 300 engine and confirm for me. Thank you
December 23rd, 2012, 12:14 PM | #9 |
For some reason,My grammar seems to diminish when i type on a phone, lol
December 23rd, 2012, 01:51 PM | #10 |
MOTM - Sep '18, Feb '16
It will fit. And I am going to punch it out to 325 and run it on nitrous and ethanol.
December 23rd, 2012, 02:10 PM | #11 |
You got one already!!!!1!!
December 23rd, 2012, 02:45 PM | #12 |
No but I am looking. Thinking about using a 500 ninja frame and building the bike around the fuel system. I can go to 350cc once I go over 249 .
December 23rd, 2012, 02:50 PM | #13 |
MOTM - Sep '14
December 23rd, 2012, 05:46 PM | #14 |
December 23rd, 2012, 08:29 PM | #15 |
It may just be marketing spin, but their official reason was to reduce vibration and make it feel like a more expensive bike. They said the same thing about why it now directs hot air down and out but I think it might have had something to to with the heat causing the tank to form a vacuum when allowed to rest after a full warm up.
December 23rd, 2012, 08:46 PM | #16 |
No but they are getting cheaper every day. I found a 94 with 17 inch wheels and a running motor for 500 bucks. I don't need the body work, motor ,tank wiring or lights. Just the frame ,fork, swing arm and wheels. And rear brakes. so I figure a clapped out 500 that has fallen over and does not run any more is like free.
Sorry about jacking the thread.
December 28th, 2012, 07:01 AM | #17 | |
Chris
Join Date: Aug 2012 Motorcycle(s): BLACK!!! '08 250R Posts: 957
"How to install a 300 in a new gen frame!" Jiggles, If anyone sends you a 300 engine, I get your old engine as a finders fee!!!! (the least you can do )
Some roads are too good to waste on four wheels! Riding in a car is like watching a movie... Riding on a motorcycle is like being in one.... |
February 6th, 2014, 02:46 AM | #18 |
LOL I actually clicked your faulty url, there is lots of 2013 ninja 300 engines on ebay as low as $500 -$1300
February 6th, 2014, 05:55 AM | #19 |
Board Member
there was a thread started on this: http://www.ninjette.org/forums/showthread.php?t=153624
also, "plated bore" motors are designed to be stronger and lighter than their counterparts. Every superbike and supersport uses the motor as a stressed member. The NiSi plating is SUPER strong. I truly do hope this works. The 500 motor caused WAY too many issues. |
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. | AFazakerley | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 5th, 2016 02:03 PM |
guy slapped 250 2t dirt bike engine in a pre gen | subxero | General Motorcycling Discussion | 10 | July 5th, 2014 09:58 PM |
Ninja 300 engine in a 250? | old3 | General Motorcycling Discussion | 8 | December 23rd, 2013 06:34 PM |
Pre gen-new gen engine differences | baxtc1 | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 3rd, 2013 04:43 PM |
