April 14th, 2013, 01:26 PM | #1 |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250r Posts: 27
Fluttering noise coming from front of bike.
Hello, ninjette community.
A couple of weeks ago I started noticing a noise coming from the front of the bike, a noise that sounds similar to a flag quickly flapping in the wind. My 2011 250r has almost 25,000 miles and I can hear the noise between 3-5 thousand RPMs. I'm not sure if the sound goes away after 5,000 or I simply can't hear it over the engine anymore. I'm thinking it's the valves but I'm not 100% sure. I haven't have a valve adjustment in a while so that would lend credence to that theory. I haven't had a problem with how the bike runs, though. If anyone has had a similar problem please let me know. |
April 14th, 2013, 02:31 PM | #2 |
So, it is not related to the speed of the bike? Can you reproduce it even when not rolling, just by reving up?
April 14th, 2013, 02:56 PM | #3 |
It's not based on speed or load. I can choke the bike between there and hear it and rev the bike myself to hear it. It's usually more noticeable on decel than excel.
April 14th, 2013, 03:01 PM | #5 |
^^^^ definitely worth looking at. A quick lube and you will know.
April 14th, 2013, 03:13 PM | #6 | |
Have you checked that your exhaust headers are tight and leak-free? Have you serviced your cam chain tensioner? Have you checked the bolts that anchor the engine to the frame? Have you checked the bolts that keep the plastics together?
April 14th, 2013, 03:19 PM | #7 |
What kind of mods do you have on the bike?
Have you put your head close to the engine while it is idling? Does it sound like a popping on decel? |
April 14th, 2013, 03:31 PM | #8 |
Oh man getting a lot more back than I thought. I'll need to check those out, I do plan on changing my plugs within the next week. I haven't put my head down by the engine and revved only about the tank.
April 14th, 2013, 03:46 PM | #9 |
MOTM - Mar '13, Jun '14
Next time you hear it pull in the clutch and see if it stops (making the noise). Check all the bolts on the fairing and fender.
April 14th, 2013, 03:56 PM | #10 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Man, you guys are smart. Seriously, I wish I had the mechanical knowledge you all do.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
April 14th, 2013, 04:20 PM | #11 |
If all else is exhausted, it also could be coming from your visor.
April 14th, 2013, 04:26 PM | #12 |
Board Member
Fairing bolt missing?
April 14th, 2013, 06:36 PM | #13 |
Clutch doesn't make a difference the noise comes with a load or without. That would dispute the visor or fairings as well.
April 14th, 2013, 07:13 PM | #14 |
Board Member
While moving...standing still or both?
Whining/howling noise coming from bike | blades8306 | 2008 - 2012 Ninja 250R Tech Talk | 15 | October 3rd, 2012 03:57 PM |
Quiet squeaking noise coming from gas tank? | ajcadoo | 2008 - 2012 Ninja 250R Tech Talk | 13 | February 27th, 2012 09:25 AM |
Ticking/Clicking noise coming off throttle | patw | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 4th, 2011 04:01 PM |
Help: Prominent noise coming from the rear? | NinjaBlake | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 18th, 2011 05:34 PM |
Help - squeaking noise coming from front wheel / fork? | muffinman | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 17th, 2009 05:11 PM |
