April 28th, 2013, 06:53 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Do these mirrors fit?
http://www.amazon.com/Integrated-Mir...or+turn+signal
Looking at these mirrors and wondering if anyone has any experience with them. Thanks Kevin |
May 1st, 2013, 04:58 AM | #2 |
If you get them could you let us know? Also what kind of quality they are.
May 1st, 2013, 09:28 AM | #3 |
I just noticed today that they have adjustable slots for the bolt positions. Might buy em and ditch the front turn signals too.
May 1st, 2013, 12:10 PM | #4 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
They'll fit but they'll make your ass look fat.
May 1st, 2013, 02:55 PM | #6 |
I just dont want to make it fit by ghetto fabbing it............
May 1st, 2013, 05:20 PM | #7 |
Join Date: Feb 2012 Motorcycle(s): 06 250 rat, 20 400 krt Posts: 55
i had to use longer bolts, but got them to fit.
May 1st, 2013, 05:43 PM | #8 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 257
Plus you have to either buy Y connectors from that modmy250(?) site which is probably the easiest, or you can splice into the current signal wires. I'd suggest the Y connectors tho.
Also, how is the rear view with these? Better than the stock mirrors? |
May 1st, 2013, 05:47 PM | #9 |
Xero do they look right on the bike? Like a correct angle etc?
May 1st, 2013, 05:55 PM | #10 |
Just realized this was under pregen farkles lol granted the bolt pattern is probably the same
May 1st, 2013, 07:27 PM | #11 |
Xero some pics would be awesome
May 11th, 2013, 03:10 PM | #12 |
Join Date: Sep 2012 Motorcycle(s): 2008 Ninja 250R Posts: 149
I have them and they will fit with some modification, what you need to do is replace the mount with your original one.....
replace this (requires some sanding down to fit) with this from your original mirrors |
May 11th, 2013, 05:49 PM | #13 |
Well that's easy. Might have to consider this upgrade in the future
May 12th, 2013, 04:08 PM | #14 |
DIY - ebay universal fit / Bike It Trojan Style Indicator Mirrors | Gregular | 2008 - 2012 Ninja 250R Tech Talk | 34 | June 28th, 2009 10:50 AM |
What others mirrors fit?? | BlackKarma | 1986 - 2007 Ninja 250R Tech Talk | 25 | February 19th, 2009 07:47 PM |
