Old June 3rd, 2013, 11:37 AM   #1
indr
Coil Wiring
What are the colours of the wires running to the left and right coils (when sitting on the bike)? I'm redoing the wiring and the diagram shows a red wire from the kill switch going to both coils. And a green and a black wire from the IC. One going to each coil. Just wanted to confirm which goes where.
indr is offline   Reply With Quote
Old June 3rd, 2013, 12:19 PM   #2
I don't think that it matters, both coils shoot at once (Wrong info, please read below).
What is important is the polarity that feeds the coil little tabs.
Old June 3rd, 2013, 12:40 PM   #3
indr
Are you sure?
I thought there was a firing order. And only during the TDC part of the stroke since that's when the a/f mixture reaches max compression.
Old June 3rd, 2013, 12:50 PM   #4
Sorry, you are correct, they fire 180 degrees apart; hence they follow a #1 - #2 sequence.
Red goes to both (connected to the lower tag in both coils).
Black goes to coil #1 (left when seating in the bike).
Green goes to coil #2 (right when seating in the bike).
The ignition system is a "wasted spark" type.
http://en.wikipedia.org/wiki/Wasted_spark
Last futzed with by Motofool; June 4th, 2013 at 06:32 AM.
Old June 4th, 2013, 09:21 AM   #5
indr
Would you be able to visually confirm it, please? I have a feeling it was the other way around. Unless you already did. In which case, thank you!
Old June 4th, 2013, 10:01 AM   #6
Yes, I walked to my bike and verified it.
Mine is a pre-gen, but I believe it works alike for the new-gens'.
You are welcome
Sorry about the initial confusion, I forgot the details of the wasted spark.
Old June 4th, 2013, 12:15 PM   #7
indr
Another thing: The colors are reversed on the old and new gen wiring diagrams.
Old: https://pbs.twimg.com/media/BL8Dr9oCAAACEQB.jpg
New: https://pbs.twimg.com/media/BL8D9SOCAAA9Jx1.jpg
Old June 4th, 2013, 02:04 PM   #8
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Give me a little while to pop off my body panels and ill comfirm.
Old June 4th, 2013, 02:57 PM   #9
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Right side red bottom green top
Left side red bottom black top
Old June 4th, 2013, 03:55 PM   #10
there are two separate coils which means it is not a wasted spark. if it was wasted spark they would only use a single coil and run through both plugs. the wiring harness is built with different length wires for the two coils. so with the harness in its correct position, only one set of wires will reach the far coil. polarity for the coil *really* doesn't matter since its a charge coil. when the field collapses it doesn't matter what polarity it was charged with, it still only has one escape. the spark plug. but they tell me its bad for the coil itself to run it backwards. i don't think that's true though.
Old June 4th, 2013, 04:20 PM   #11
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
If you want I could probably take a pic of each side as well
Old June 4th, 2013, 05:46 PM   #12
I will have my race fairings off later, I can get some pics if it will help. Although I think Jason has you covered.
Old June 4th, 2013, 06:06 PM   #13
willis9076
Motorcycle(s): 2012 250R
I believe it is a wasted spark system but since it is a 180° twin, it needs separate coils. I have been using an induction tachometer to monitor my RPM's and I have to set it at 1 spark per revolution in order for it to read correctly.
On a side note, I have been trying to diagnose the CDI overheating issue since my bike reads 1000 RPM over when it is warm outside. Based on my preliminary findings, I do not believe that there is an issue with my CDI but rather my Tachometer (YMMV). My secondary tach is receiving its signal from the spark plug wire and it is always reading correctly even when the tach in the dash is reading 1000 over. Since the stock tach signal wire is the same as the black wire going into the coil, I can assume that the plug is not firing any faster or slower than the CDI output signal.
My current hypothesis is that the heat is causing the timebase in the tach (either crystal or ceramic resonator?) to drift. I will eventually try and post my findings in a more appropriate thread.
PS does anyone have pics of the circuit board of the stock tachometer?
willis9076 is offline   Reply With Quote
Old June 5th, 2013, 09:23 AM   #14
indr
No need for pics. The reason the parts diagram shows the Right coil on the left and vice versa is to show the proper splicing from the kill switch. I.e. the red wire goes from the kill switch first to the right coil and then to the left.
Zx coil over plugs alex.s Pictures 24 October 30th, 2015 04:26 PM
coil and plug wire help gantt 2008 - 2012 Ninja 250R Tech Talk 7 March 5th, 2015 07:50 AM
Ground to coil? nickadolph 2008 - 2012 Ninja 250R Tech Talk 16 June 7th, 2013 05:28 PM
coil question MaliZ 1986 - 2007 Ninja 250R Tech Talk 3 March 19th, 2013 03:09 PM
Coil wiring? expat 2008 - 2012 Ninja 250R Tech Talk 2 February 26th, 2012 07:57 PM
