June 6th, 2013, 11:05 AM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2012 Ninja 250 Posts: 10
Cost of 600 Mile Service
My local dealership quoted me $ 470.00 plus parts for the 600 mile service. Is this what I should expect to pay for this service?
June 6th, 2013, 11:09 AM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
No, the 600mi service is a glorified oil change, you can do it yourself for about $30. It requires checking fluid levels and bolts and changing the oil. And $470 from the dealer is ****ing crazy, I've been quoted in the $200s for it which is still insane. You're basically only paying for labor and it shouldn't take more than 1-2hrs
June 6th, 2013, 11:20 AM | #3 |
i got quoted under $200, but did it myself
June 6th, 2013, 11:21 AM | #4 |
dirty boy
MOTM - Apr '14
^ +1
I got quoted like $240 from my stealership, $100/hr for labor such a rip off. |
June 6th, 2013, 11:24 AM | #5 |
Thanks for the responses. $ 470.00 seems crazy for a service. I may need to try to do this one myself.
June 6th, 2013, 11:28 AM | #6 |
dirty boy
MOTM - Apr '14
if you are not familiar with doing the work on the bike research and think everything through before you dig in so you can hopefully see flaws in your plan before they happen.
You can always call around some other dealers and look for a lower quote if you are not comfortable doing it all yourself. good luck either way |
June 6th, 2013, 11:28 AM | #7 |
MOTM - Apr '13
Look in your manual what needs to be done for the 600mi service
June 6th, 2013, 11:36 AM | #8 |
I will check out the manual and see if it looks like something I can do.
June 6th, 2013, 11:40 AM | #9 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
I've never worked on anything mechanically and managed to do all of the maintenance on the bike (minus the valve adjustment) by myself, with the help of the abundance of tutorials and help from this forum.
June 6th, 2013, 11:53 AM | #10 |
lol @470
June 6th, 2013, 12:19 PM | #11 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
I paid $200 at dealer, You CAN'T DO IT YOURSELF if the bike is financed and under warranty. after that you can do all of the rest of check up's and oil changes yourself. If you don't take it to a dealer for 600 mi service it will void your warranty. Look it up
June 6th, 2013, 12:33 PM | #12 | |
MOTM - Apr '13
Now it is true that they can deny a warranty claim if they can prove that you neglected or ****ed up the service that you did. I.e. engine seized because you never changed the oil. Here is kawasakis warranty faq, go ahead and point out to me where it says it will void your warranty if you don't take it to a Kawi dealer for the first 600mi http://www.kawasaki.com/helpcenter/h....aspx#service2
June 6th, 2013, 12:46 PM | #13 |
TIL my stealership is ripping me off. Unless you have lots of disposable income, regular motorcycle maintenance can be crushing. Get a factory service manual, and with the help of the DIYs here, and others, learn to do a majority of it yourself. You'll save thousands over the life of your bike (and fairly quickly).
June 6th, 2013, 12:47 PM | #14 | |
they can probably eek themselves out of replacing a chain if they can prove that the way you maintained it caused the failure, or that you incorrectly changed your oil so you starved your bearings. same thing with modifying a bike or a car. You can do whatever you want to it, as long as the modification isn't the cause of the failure. you put on engine mods and blew a transmission... maybe, but they have to prove it wasn't a manufacturing defect. there are landmark rulings out there for this stuff. manufacturers and dealers are well aware of this. if they tell you otherwise, you need to talk to someone else who actually understands the way the world works. |
June 6th, 2013, 12:52 PM | #15 |
Fast-Guy wannabe
MOTM - Jan '13
Ill do it for $300
June 6th, 2013, 02:31 PM | #16 |
Join Date: Mar 2013 Motorcycle(s): 2012 Ninja 250 2013 GSXR 600 Posts: 96
got mine done for $120.00 canadian
I could do it myself but want 100% bullet proof warranty coverage and for $120.00 i dont care Ill do it for free all you have to do is fly me in........ |
June 6th, 2013, 02:33 PM | #17 | |
MOTM - Apr '13
I might've done it for $120 just cuz I'm lazy
June 6th, 2013, 02:38 PM | #18 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
a full service is going to cost me 380 (including all parts they said) so 470 is just insane.
I did the oil change myself. I had a slight issue with the bolt (and had to order a new bolt) but still, much cheaper than taking it to the dealership. |
June 6th, 2013, 02:42 PM | #19 |
MOTM - Apr '13
Use a full six point wrench next time or a socket wrench. None of those open ended or 12 pt pieces of **** strippers
June 6th, 2013, 02:46 PM | #20 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Well since you think any thing you read or are told is the truth pay me the sum of 1000000000000000.00 us or your warranty is void
Hey Unregistered never go faster than your brakes can be applied... |
June 6th, 2013, 02:55 PM | #21 |
Daily Jap rider
when something goes wrong and kawasaki doesn't want to pay up because you didn't follow their warranty policies, you really want to have a litigation fight for months, possibly years, with them. They are not known for their wonderful customer service. I have been waiting for 3 1/2 months for a tach from them on warranty and that is with them saying it is something that is their fault. Just sayin that $200 is a small price to pay to stop a future headache
June 6th, 2013, 03:03 PM | #22 | |
June 6th, 2013, 03:24 PM | #23 | |
Daily Jap rider
June 6th, 2013, 04:01 PM | #24 | ||
MOTM - Apr '13
June 6th, 2013, 04:21 PM | #25 |
June 6th, 2013, 04:22 PM | #26 |
MOTM - Apr '13
I'm too lazy to take the 300 to the shop though so I'll just do it myself
600 mile service | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 14th, 2012 07:48 PM |
600 mile service? | beqwarrior | 2008 - 2012 Ninja 250R Tech Talk | 10 | November 4th, 2011 07:10 AM |
Is the 600 mile service necessary? | Lil_Green_Demon | 2008 - 2012 Ninja 250R Tech Talk | 41 | August 28th, 2011 10:49 AM |
600 mile service. | tinng321 | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 8th, 2009 03:23 PM |
600 mile service next week. | py2e | General Motorcycling Discussion | 8 | April 28th, 2009 09:36 PM |
