July 16th, 2013, 07:33 PM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2008 Ninja 250r Posts: 288
Throttle Play
So i went to ride my bike for the first time in a few days.. and I noticed my throttle had a little play in it, meaning I can turn the throttle a good amount before it is actually engaging and revving the engine.
Honestly.. I don't know if it was like that before (a few days ago) or not. I've also noticed that the throttle tube on the bar is kinda loose, and it slides a mm or 2 left or right. Is it bad to have that play there (in either direction), and how can I fix it whether it is bad or not. Thanks!
2008 Kawasaki Ninja 250r | Yoshimura Stainless Full Exhaust | Pazzo Levers | Puig Double Bubble | DynoJet Stage 2 | K&N Intake | |
July 16th, 2013, 07:39 PM | #2 |
It's not a bad thing, kinda a good thing to have a few mm's of play to account for bumps and such.
You can adjust the cable via then endpoints.
July 16th, 2013, 08:24 PM | #3 |
Join Date: Apr 2013 Motorcycle(s): 2013 600RR, 2009 250r Posts: 130
I have some play in mine. It's actually been that way since I got it. If I'm at a light I naturally put it right to where it will engage when I roll it on. Never been an issue for me. I've heard that too tight can cause problems, so I just have left it as is.
July 16th, 2013, 11:01 PM | #4 |
Join Date: Apr 2013 Motorcycle(s): 2010 250r SE (without stupid tribal decals) Posts: 110
Mine does it too, nothing to worry about dude. Normal.
"It sounds like a lawnmower." "Shut up no it doesn't." |
July 17th, 2013, 11:58 AM | #5 |
Alright, Thanks again guys!
I wont worry about it then.
July 18th, 2013, 06:31 PM | #6 |
Board Member
I run very little play. Its to tight when the idle changes by turning the bars lock to lock.
[motorcycle-usa.com] - Cole Seely Play By Play at Atlanta I 2015 | Ninjette Newsbot | Motorcycling News | 0 | February 24th, 2015 04:52 AM |
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
More play in throttle? | rasta | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 10th, 2014 12:16 AM |
Throttle Play Adjustment | Liist | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 14th, 2012 05:26 AM |
Throttle & Throttle Cable Smoothness | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 1st, 2009 01:50 PM |
